BAT54WS
BAT54WS
    JSMSEMI(杰盛微)
    SOD-323
    SOD323 200mW
BAT54WS 数据手册
BAT54WS Small Signal Schottky Barrier Diode Features Low turn-on voltage Fast switching Ultra-small surface mount package PN junction guard for transient and ESD protectio n Application to r Schottky barrier detector and switching diodes Mechanical Data Case: SOD-323 SOD-323 Terminals: Matte tin-plated leads; solderability-per MIL-STD-202, Method 208 Package BAT54WS SOD-323 Shipping Quantity Marking Code 3000 pcs / Tape & Reel L4 co Part Number nd Ordering Information uc Molding Compound: UL Flammability Classification Rating 94V-0 Symbol Value Unit VRRM 30 V VRWM 30 V VR 30 V VR(RMS) 21 V IF 200 mA Peak Forward Surge Current (1s single half sine-wave) IFSM 600 mA Repetitive Peak Forward Current IFRM 300 mA Symbol Value Unit PD 200 mW RΘJA 500 °C/W TJ -55 ~ +125 °C TSTG -55 ~ +150 °C Peak Repetitive Reverse Voltage DC Reverse Voltage CR O Working Peak Reverse Voltage Se Parameter mi Maximum Ratings (@ TA = 25°C unless otherwise specified) RMS Reverse Voltage JS MI Forward Continuous Current Thermal Characteristics Parameter Power Dissipation *1 Thermal Resistance Junction-to-Air *1 Operating junction Temperature Storage Temperature Range www.jsmsemi.com 第1/4页 BAT54WS Small Signal Schottky Barrier Diode Electrical Characteristics (@ TA = 25°C unless otherwise specified) Min. Typ. Max. Unit IR = 100μA 30 - - V VF1 IF = 0.1mA - - 240 mV VF2 IF = 1.0mA - - 320 mV VF3 IF = 10mA - - 400 mV VF4 IF = 30mA - - 500 mV VF5 IF = 100mA - - 1000 mV VR = 25V - - 2 μA - 5.0 ns - 10 pF Maximum Peak Reverse Current *3 IR Reverse Recovery Time trr Typical Junction Capacitance CJ IF = 10mA, IR = 10mA to 1mA RL = 100Ω VR = 1V, f = 1MHZ - JS MI CR O Se mi Notes: 1. Part mounted on FR-4 board with recommended pad layout 2. Pulse test, tp ≤ 300μs 3. Pulse test, tp ≤ 5ms - to r V(BR)R uc Forward Voltage *2 Test Condition nd Reverse Breakdown Voltage Symbol co Parameter www.jsmsemi.com 第2/4页 BAT54WS Small Signal Schottky Barrier Diode (@ TA = 25°C unless otherwise specified) JS MI CR O Se mi co nd uc to r Ratings and Characteristic Curves www.jsmsemi.com 第3/4页 BAT54WS Small Signal Schottky Barrier Diode Package Outline Dimensions (Unit: mm) K SOD-323 C A Dimension Min. Max. A 1.60 1.80 B 1.20 1.40 C 0.80 0.90 D 0.25 0.35 E 0.22 0.42 B D E to r H 0.02 0.10 J 0.05 0.15 K 2.55 2.75 uc J H nd Mountin Pad La out (Unit: mm) SOD-323 co 0.63 1.60 JS MI CR O 2.85 Se mi 0.83 www.jsmsemi.com 第4/4页
BAT54WS 价格&库存
很抱歉,暂时无法提供与“BAT54WS”相匹配的价格&库存,您可以联系我们找货
