BSS138
Plastic-Encapsulate MOSFETS
V(BR)DSS
ID
RDS(on)MAX
3.5Ω@ 10V
50V
SOT-23
0.22A
6.0Ω@4.5V
3
2.SOURCE
1
Equivalent Circuit
uc
3) Drive circuits can be simple.
4) Parallel use is easy.
5) ESD protected 2KV HBM
nd
Applications
Interfacing, switching (50V, 100mA)
co
ORDERING INFORMATION
Marking
Package Code
BSS138
SS/J1
SOT-23
Symbol
TA =25 o C unless otherwise noted
Se
Absolute Maximum Ratings
mi
Type No.
Parameter
V DSS
Drain-Source Voltage
V GSS
Gate-Source Voltage
ID
Drain Current
– Continuous
(Note 1)
Units
V
0.22
A
V
0.88
CR
O
– Pulsed
(Note 1)
Derate Above 25C
TJ , TSTG
Operating and Storage Junction Temperature Range
TL
Maximum Lead Temperature for Soldering
Purposes 1/16” from Case for 10 Seconds
JS
MI
Ratings
50
Maximum Power Dissipation
Thermal Characteristics
RθJA
3.DRAIN
2
to
r
Features
1) Low on-resistance.
2) Fast sw itching speed.
PD
1.GATE
Thermal Resistance, Junction-to-Ambient
(Note 1)
0.36
W
2.8
mW/C
−55 to +150
C
300
C
350
C/W
Package Marking and Ordering Information
Device Marking
Device
Reel Size
Tape width
Quantity
SS
BSS138
7’’
8mm
3000 units
www.jsmsemi.com
第1/5页
BSS138
T A = 25°C unless otherwise noted
Symbol
Parameter
Test Conditions
Min
Off Characteristics
Typ
Max
BV DSS
Drain–Source Breakdown Voltage
VGS = 0 V,
∆BV DS S
∆T J
Breakdow n Voltage Temperature
Coefficient
ID = 250 A,Referenced to 25C
IDSS
Zero Gate Voltage Drain Current
V DS = 50 V,
V GS = 0 V
0.5
A
V DS = 30 V,
V GS = 0 V
100
nA
V GS = 20 V,
V DS = 0 V
100
nA
1.6
V
On Characteristics
V GS(th)
∆V GS(th)
∆T J
72
(N ote 2)
0.8
Gate Threshold Voltage
VDS = VGS ,
ID = 1 mA,Referenced to 25C
Temperature Coefficient
V
mV/C
to
r
Gate–Body Leakage.
ID = 250 A
ID = 1 mA
uc
IGSS
50
Units
1.3
–2
VGS = 10 V,
I D = 0.22 A
3.5
VGS = 4.5 V,
I D = 0.22 A
6.0
ID(on)
On–State Drain Current
V GS = 10 V,
V DS = 5 V
g FS
Forward Transconductance
VDS = 10V,
I D = 0.22 A
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
RG
Reverse Transfer Capacitance
tr
Turn–On Rise Time
td(off)
Turn–Off Delay Time
tf
Turn–Off Fall Time
Qg
Total Gate Charge
Qgs
Gate–Source Charge
Qgd
Gate–Drain Charge
(Note 2)
CR
O
Turn–On Delay Time
V GS = 15 mV,
V DD = 30 V,
V GS = 10 V,
Se
Switching Characteristics
V GS = 0 V,
mi
V DS = 25 V,
f = 1.0 MHz
Gate Resistance
td(on)
co
Dynamic Characteristics
nd
Static Drain–Source
On–Resistance
RDS(on)
V DS = 25 V,
V GS = 10 V
f = 1.0 MHz
ID = 0.29 A,
RGEN = 6 Ω
I D = 0.22 A,
mV/C
Ω
0.2
A
0. 12
S
27
pF
13
pF
6
pF
9
Ω
2.5
5
ns
9
18
ns
ns
7
14
ns
1.7
2.4
nC
0.1
nC
0.4
nC
Drain–Source Diode Characteristics and Maximum Ratings
IS
Maximum Continuous Drain–Source Diode Forward Current
V GS = 0 V,
I S = 0.44 A (Note
Voltage
JS
MI
V SD
www.jsmsemi.com
2)
0.8
0.22
A
1.4
V
第2/5页
BSS138
Typical Characteristics
1
V GS = 10V
6.0V
4.5V
3.4
3. 5V
0.8
3
V GS = 2.5V
3.0 V
2.
0.6
62.
3.0V
2.5 V
1.
2
0.4
3.5V
0.2
2.0V
4
1
1
1.5
2
2.5
0.2
0.6
4.5V
0.4
6.0V
0.6
10V
0.8
1
ID , DRAIN CURRENT (A)
uc
V DS , DRAIN TO SOURCE VOLTAGE (V)
4.0V
to
r
81.
Figure 2. On-Resistance Variation with
Drain Current and Gate Voltage.
nd
Figure 1. On-Region Characteristics.
2
4.1
ID = 2 20mA
1.
10V
ID = 1 10mA
3.5
co
V GS =
81.
2.9
61.
T A = 125 oC
2.3
mi
41.
1.7
2
TA = 25 o C
1.1
-50
-25
25
50
75
Se
1
0.
100
125
0.5
150
6
0.
V DS =
T A
= -55 oC
6
8
10
Figure 4. On-Resistance Variation with
Gate-to-Source Voltage.
1
V GS = 0V
25 oC
0.1
125 o C
JS
MI
60.
10V
CR
O
Figure 3. On-Resistance Variation with
Temperature.
4
V GS , GATE TO SOURCE VOLTAGE (V)
T J , JUNCTION TEMPERATURE ( o C)
TA = 125 o C
50.
25 o C
0.01
40.
-55 o C
30.
0.001
20.
1
0.5
1.5
0.0001
2
2.5
3
3.5
Figure 5. Transfer Characteristics.
0.2
0.4
0.6
0.8
1
1.2
V SD , BODY DIODE FORWARD VOLTAGE (V)
Figure 6. Body Diode Forward Voltage Variation
with Source Current and Temperature.
www.jsmsemi.com
第3/5页
BSS138
10
100
ID = 220mA
V DS = 8V
f = 1 MHz
V GS = 0 V
25 V
80
8
30V
60
4
40
2
C ISS
C OSS
to
r
6
C RSS
0.4
0.6
0.8
1
1.2
1.4
1.6
10
3
100ms
1s
DC
0.1
2
mi
V GS = 10V
SINGLE PULSE
R θJA = 350 oC/W
T A = 25 oC
1
1
10
100
0.01
0.1
1
V DS, DRAIN-SOURCE VOLTAGE (V)
0.2
0.1
JS
MI
0.1
P(pk)
0.02
t1
0.01
t2
TJ - T A = P * R θJA (t)
Duty Cycle, D = t1 / t2
SINGLE PULSE
0.001
0.0001
0.001
1000
RθJA(t) = r(t) * RθJA
R θJA = 350 o C/W
0.05
0.01
100
Figure 10. Single Pulse Maximum
Power Dissipation.
CR
O
D = 0.5
10
t1 , TIME (sec)
Figure 9. Maximum Safe Operating Area.
1
SINGLE PULSE
RθJA = 350°C/W
T A = 25°C
co
1ms
10ms
Se
0.001
4
100s
0.01
50
uc
5
0.1
40
Figure 8. Capacitance Characteristics.
10
R DS(ON) LIMIT
30
nd
Figure 7. Gate Charge Characteristics.
1
VDS , DRAIN TO SOURCE VOLTAGE (V)
Q g , GATE CHARGE (nC)
0.01
0.1
1
10
100
1000
t1 , TIME (sec)
Figure 11. Transient Thermal Response Curve.
Thermal characterization performed using the conditions described in Note 1a.
Transient thermal response will change depending on the circuit board design.
www.jsmsemi.com
第4/5页
BSS138
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
A
SOT-23
E
K
A
B
B
0.95
1.10
E
0.35
0.48
G
nd
1.80
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
All Dimensions in mm
JS
MI
CR
O
0.95
0.90
Se
SOLDERING FOOTPRINT
1.50
0.50
mi
C
1.10
0.30
co
G
H
3.10
D
J
D
Max
2.70
uc
C
Min
to
r
Dim
2.00
0.90
Unit: mm
0.80
PACKAGE
INFORMATION
Device
Package
Shipping
BSS138
SOT-23
3000 pcs / Tape & Reel
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“BSS138”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.08835
- 200+0.08265
- 500+0.07695
- 1000+0.07125
- 3000+0.06840
- 6000+0.06441
