BT131-600
BT131-600
    JSMSEMI(杰盛微)
    TO92-3
    晶闸管 TO-92 双向 塑料表面贴装封装
BT131-600 数据手册
BT131-600 ‹ Features ·With TO-92 package ·For use in general purpose bidirectional switching and phase control applications, which is intended to be interfaced directly to microcontrollers,logic integrated circuits and other low power gate trigger circuits. QUICK REFERENCE DATA SYMBOL UNIT Repetitive peak off-state voltage 600 V Repetitive peak off-state voltage 600 V Average on-state current 1 A Non-repetitive peak on-state current 16 A PG(AV) Average gate power 0.5 W Tstg Storage temperature -40~150 ℃ 125 ℃ VRRM IT(AV) ITSM Operating junction temperature mi Se Tj PARAMETER O CR VALUE VDRM ‹ MI JS ‹ TO-92 ELECTRICAL CHARACTERISTICS (Tj = 25°C, unless otherwise specified) nd co SYMBOL PARAMETER CONDITIONS VDRM Repetitive peak off-state voltage ID=0.1mA 600 V VRRM Repetitive peak reverse voltage ID=0.5mA 600 V VD =12V; IT = 0.1A T2+ G+ uc IGT MIN Gate trigger current 3 T2- G- 3 r to On-state voltage IT=2A IH Holding current VD =12V; IGT = 0.1 A VD =12V ; IT = 0.1A VGT Gate trigger voltage www.jsmsemi.com UNIT 3 T2+ G- T2- G+ VT MAX mA 7 1.5 V 5 mA T2+ G+ 1.5 T2+ G- 1.5 T2- G- 1.5 T2- G+ 1.5 V 第1/2页 BT131-600 PACKAGE OUTLINE Plastic surface mounted package TO-92 TO-92 CR MI JS Dim Min Max A 4.4 4.7 B 4.3 4.7 C 3.43Typical D 0.38 0.55 E 1.1 1.4 O G 1.27 Typical H c mi Se J 14.1 14.5 0.36 0.51 All Dimensions in mm c du on r to www.jsmsemi.com 第2/2页
BT131-600 价格&库存
很抱歉,暂时无法提供与“BT131-600”相匹配的价格&库存,您可以联系我们找货
