MMBT2907A
PNP General Purpose Amplifier
FEATURES
Epitaxial planar die construction.
Complementary NPN type available
MMBT2222A.
Ideal for medium power amplification and switching.
MSL 1
2F
APPLICATIONS
This device is designed as a general purpose amplifier
SOT-23
JS
and switching.
The useful dynamic range extends to 600mA as a switch
MI
and to 100MHz as a amplifier.
O
CR
mi
Se
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Parameter
Collector-Base Voltage
VCEO
Collector-Emitter Voltage
VEBO
Emitter-Base Voltage
Total Device Dissipation
RθjA
RθjC
TJ, TSTG
V
-60
V
-5
V
-600
mA
300
mW
Thermal Resistance Junction to Ambient
417
°C/W
Thermal Resistance Junction to Case
250
°C/W
Junction and Storage Temperature
www.jsmsemi.com
-55 to +150
r
PD
-60
to
Collector Current -Continuous
Unit
uc
IC
Value
nd
VCBO
co
Symbol
°C/W
第1/5页
MMBT2907A
ESD RATING
Characteristic
Symbol
Value
Unit
JEDEC Class
Electrostatic Discharge - Human Body Model
ESD HBM
4,000
V
3A
Electrostatic Discharge - Machine Model
ESD MM
400
V
C
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Symbol
Test conditions
MIN
Collector-base breakdown voltage
V(BR)CBO
IC=-10μA IE=0
-60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-10mA IB=0
-60
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10μA IC=0
-5
V
Collector cut-off current
Base cut-off current
O
CR
MI
JS
Parameter
MAX
UNIT
ICBO
VCB=-50V IE=0
VCB=-50V IE=0 TA=125℃
-10
-10
nA
μA
ICEX
VCE=-30V,VBE(OFF)=-0.5V
-50
nA
IBL
-50
nA
Collector-emitter saturation voltage
VCE(sat)
IC=-150mA IB=-15mA
IC=-500mA IB=-50mA
Base-emitter saturation voltage
VBE(sat)
IC=-150mA IB=-15mA
IC=-500mA IB=-50mA
Transition frequency
fT
VCE=-20V IC=-50mA
f=100MHz
Output Capacitance
Cobo
VCB=-10V f=100kHz IE=0
8.0
pF
Input Capacitance
Cibo
VEB=-2V f=100kHz IC=0
30
Delay time
td
10
ns
Rise time
tr
VCE=-30V, IC=-150mA,
IB1=-15mA
r
pF
40
ns
Storage time
ts
225
ns
Fall time
tf
60
ns
DC current gain
75
100
100
100
50
300
-0.4
-1.6
V
-1.3
-2.6
V
uc
nd
co
mi
Se
hFE
VCE=-10V IC=-100μA
VCE=-10V IC=-1mA
VCE=-10V IC=-10mA
VCE=-10V IC=-150mA
VCE=-10V IC=-500mA
200
to
VCE=-6V, IC=-150mA
IB1=-IB2=-15mA
www.jsmsemi.com
MHz
第2/5页
MMBT2907A
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
O
CR
MI
JS
r
to
uc
nd
co
mi
Se
www.jsmsemi.com
第3/5页
MMBT2907A
O
CR
MI
JS
r
to
uc
nd
co
mi
Se
www.jsmsemi.com
第4/5页
MMBT2907A
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
A
SOT-23
Dim
Min
Max
A
2.70
3.10
B
1.10
1.50
C
0.90
1.10
D
0.30
0.50
E
0.35
0.48
G
1.80
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
E
K
B
JS
J
D
MI
G
CR
H
C
O
0.95
0.95
nd
co
mi
Se
SOLDERING FOOTPRINT
All Dimensions in mm
0.90
r
Unit : mm
0.80
to
uc
2.00
PACKAGE INFORMATION
Device
Package
Shipping
MMBT2907A
SOT-23
3000 pcs / Tape & Reel
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04925
- 200+0.04617
- 600+0.04310
- 2000+0.04002
- 5000+0.03694
- 10000+0.03478
