S9014
Silicon Epitaxial Planar Transistor
FEATURES
Complementary to S9015
Excellent hFE linearity
J6
Power dissipation (PC = 0.2W)
to
r
APPLICATIONS
Per-Amplifier low level & low noise
mi
co
nd
uc
SOT-23
VCBO
VCEO
Value
Units
50
V
Collector-Emitter Voltage
45
V
Emitter-Base Voltage
5
V
Collector-Base Voltage
JS
MI
VEBO
Parameter
CR
O
Symbol
Se
MAXIMUM RATING @ TA=25℃ unless otherwise specified
IC
Collector Current -Continuous
100
mA
PC
Collector Dissipation
200
mW
-55 to +150
TJ, TSTG
Junction and Storage Temperature
www.jsmsemi.com
第1/5页
S9014
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Symbol
Test conditions
Collector-base breakdown voltage
V(BR)CBO
IC=100μA,IE=0
50
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=0.1mA,IB=0
45
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100μA,IC=0
Collector cut-off current
ICBO
VCB=50V,IE=0
ICEO
VCE=35V,IB=0
Emitter cut-off current
IEBO
VEB=3V,IC=0
DC current gain
hFE
VCE=5V,IC=1mA
Collector-emitter saturation voltage
VCE(sat)
IC=100mA, IB= 5mA
Base-emitter saturation voltage
VBE(sat)
Transition frequency
to
r
MAX
UNIT
200
V
0.1
μA
0.1
μA
0.1
μA
1000
mi
co
nd
uc
5
IC=100mA, IB= 5mA
0.3
V
1
V
VBE (on )
VCE=5V, IC=2mA
0.7
V
Cob
VCB=10V, IE=0, f=1MHz
3.5
pF
CR
O
Output capacitance
TYP
Se
Base-emitter on voltage
MIN
VCE=6V, IC= 20mA
f=30MHz
fT
150
MHz
JS
MI
CLASSIFICATION OF hFE(1)
Rank
L
H
Range
200-450
450-1000
www.jsmsemi.com
第2/5页
S9014
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
hFE
Static Characteristic
8
1000
Ta=100℃
18uA
Ta=25℃
12uA
10uA
8uA
2
6uA
100
4uA
IB=2uA
4
6
COLLECTOR-EMITTER VOLTAGE
VCEsat
(V)
COMMON EMITTER
VCE= 5V
1
10
COLLECTOR CURRENT
IC
VBEsat
IC
100
(mA)
IC
co
2
1
Ta=25℃
mi
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
0.1
Ta=100℃
Se
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
1
VCE
10
0.1
8
nd
uc
14uA
4
to
r
hFE
16uA
DC CURRENT GAIN
(mA)
20uA
6
IC
COLLECTOR CURRENT
COMMON
EMITTER
Ta=25℃
—— IC
Ta=25℃
Ta=100℃
β=20
β=20
CR
O
1
10
COLLECTOR CURRENT
(mA)
(mA)
IC
COLLECTOR CURRENT
Ta=25℃
COMMON EMITTER
VCE= 5V
0.3
fT
1000
1
0.1
0.0
10
IC
100
(mA)
—— IC
(MHz)
JS
MI
—— VBE
Ta=100℃
10
1
COLLECTOR CURRENT
0.6
0.9
fT
IC
100
IC
0.1
0.1
100
100
TRANSITION FREQUENCY
0.01
0.1
10
COMMON EMITTER
VCE=5V
Ta=25℃
1.2
1
0.1
1
COLLECTOR CURRENT
BASE-EMMITER VOLTAGE VBE (V)
www.jsmsemi.com
10
IC
100
(mA)
第3/5页
S9014
Cob - VCB
5
F=1MHZ
4.5
3.5
to
r
3
2.5
2
uc
1.5
1
10
15
30
CR
O
Se
mi
co
nd
VR(V)
JS
MI
Cj(PF)
4
www.jsmsemi.com
第4/5页
S9014
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
SOT-23
Min
Max
A
2.70
3.10
B
1.10
1.50
0.90
1.10
0.30
0.50
0.35
0.48
F
0.85
1.05
G
1.80
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
C
D
mi
co
nd
uc
E
to
r
Dim
0.95
CR
O
0.95
Se
SOLDERING FOOTPRINT
All Dimensions in mm
JS
MI
2.00
0.90
Unit: mm
0.80
PACKAGE INFORMATION
Device
Package
Shipping
S9014
SOT-23
3000pcs / Tape & Reel
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04050
- 100+0.03780
- 300+0.03510
- 500+0.03240
- 2000+0.03105
- 5000+0.03024
