SMF系列-A/CA
Surface mount transient voltage suppressor power 200 watts
Stand-Off Voltage: 5.0V~220V
FEATURES
PINNING
• For surface mounted applications in order to
PIN
optimize board space.
• Low profile package
DESCRIPTION
1
Cathode
2
Anode
• Glass passivated junction
1
• Low inductance
2
Unipolar
• Plastic package has Underwriters Laboratory
JS
Flammability
Bipolar
MECHANICAL DATA
MI
Top View
▪Case: SOD-123FL
Simplified outline sSOD-123FL and symbol
CR
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight:15mg 0.00048oz
O
Se
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Peak Pulse Power Dissipation on TA=2 5°C (Note 1,2,5, Fig1)
Value
Unit
P PPM
200
W
I FSM
A
see Table 1
A
1
W
-55 to +150
°C
(UNI)
Peak Pulse Current on 10/1000 us waveform (Note 1 ) Fig 2
Steady State Power Dissipation (Note 4)
I PPM
P M(AV)
T J,T STG
Operating Junction and Storage Range
RθJA
Typical Thermal Resistance
to
uc
nd
Peak Forward Surge Current (Note 3)
Symbol
co
mi
Parameter
180
°C
r
NOTES
1. Non-repetitive current pulse per Fig 3 and derated above T A=25°C per Fig 2
2. Mounted on 5mm 2 copper pads to each terminal
3. 8.3ms single half sinewave, or equivalent square wave duty cycle=4 pulses per minutes maximum
4. lead temperature at T L=75°C
5. Peak pulse powe. waveform is tp=10/1000us
6. A transient suppressor is selected according to the working peak reverse voltage(V RWM), Which Should be
equal to or greater than the DC or continuous peak operating voltage level
www.jsmsemi.com
第1/4页
SMF系列-A/CA
Characteristics at Ta = 25°C
Table 1
Test
Current
Breakdown
Voltage
Type
Marking
Reverse
Leakage
Max. Clamp
Voltage
Peak Pulse
Current
I R @ V RWM
V C @ I PP
I PP
A
V BR @ I T
V RMW
IT
Min
Max
Bi
Uni
Bi
V
V
V
mA
μA
V
SMF5.0A
SMF5.0CA
AE
CAE
5
6.4
7
10
200
9.2
21.7
SMF6.0A
SMF6.0CA
AG
CAG
6
6.67
7.37
10
100
10.3
19.4
SMF6.5A
SMF6.5CA
AK
CAK
6.5
7.22
7.98
10
75
11.2
17.9
SMF7.0A
SMF7.0CA
AM
CAM
7
7.78
8.6
10
50
12
16.7
SMF7.5A
SMF7.5CA
AP
CAP
7.5
8.33
9.21
1
50
12.9
15.5
SMF8.0A
SMF8.0CA
AR
CAR
8
8.89
9.83
1
25
13.6
14.7
13.9
Uni
SMF8.5CA
AT
CAT
8.5
9.44
10.4
1
10
14.4
SMF9.0CA
AV
CAV
9
10
11.1
1
5
15.4
13
SMFl0A
SMFl0CA
AX
CAX
10
11.1
12.3
1
2.5
17
11.8
S M F 11 A
S M F 11 C A
AZ
CAZ
11
12.2
13.5
1
2.5
18.2
11
SMF12A
SMF12CA
BE
CBE
12
13.3
14.7
1
2.5
19.9
10.1
BG
CBG
13
14.4
15.9
1
1
21.5
9.3
BK
CBK
14
15.6
17.2
1
1
23.2
8.6
BM
CBM
15
16.7
18.5
1
1
24.4
8.2
CBP
16
17.8
19.7
1
1
26
7.7
CBR
17
18.9
20.9
1
1
27.6
7.2
CBT
18
1
1
29.2
6.8
24.5
1
1
32.4
6.2
MI
JS
SMF8.5A
SMF9.0A
SMF13CA
SMF14CA
SMF15A
SMF15CA
SMF16A
SMF16CA
BP
SMF17A
SMF17CA
BR
SMF18A
SMF18CA
BT
SMF20A
SMF20CA
BV
CBV
SMF22CA
BX
CBX
22
24.4
26.9
1
1
35.5
5.6
CBZ
24
26.7
29.5
1
1
38.9
5.1
28.9
31.9
1
1
42.1
4.8
31.1
34.4
1
1
45.4
4.4
O
SMF22A
CR
SMF13A
SMF14A
SMF24CA
SMF26A
SMF26CA
CE
CCE
26
SMF28A
SMF28CA
CG
CCG
28
SMF30A
SMF30CA
CK
CCK
30
33.3
36.8
1
48.4
4.1
SMF33A
SMF33CA
CM
CCM
33
36.7
40.6
1
1
53.3
3.8
SMF36A
SMF36CA
CP
CCP
36
40
44.2
1
1
58.1
3.4
SMF40A
SMF40CA
CR
CCR
40
SMF43A
SMF43CA
CT
CCT
43
47.8
SMF45A
SMF45CA
CV
CCV
45
50
SMF48A
SMF48CA
CX
CCX
48
53.3
58.9
SMF51A
SMF51CA
CZ
CCZ
51
56.7
62.7
SMF54A
SMF54CA
DE
CDE
54
60
66.3
SMF58A
SMF58CA
DG
CDG
58
64.4
71.2
SMF60A
SMF60CA
DK
CDK
60
66.7
73.7
SMF64A
SMF64CA
DM
CDM
64
71.1
78.6
SMF70A
SMF70CA
DP
CDP
70
77.8
86
1
CDR
75
83.3
92.1
1
1
44.4
49.1
1
64.5
3.1
52.8
1
1
69.4
2.9
55.3
1
1
72.7
2.8
1
1
1
77.4
2.6
1
1
82.4
2.4
1
1
87.1
2.3
1
1
93.6
2.1
1
1
96.8
1.8
1
1
103
1.7
to
uc
nd
co
mi
Se
SMF24A
BZ
1
113
1.5
1
121
1.4
1
126
1.4
137
1.3
SMF75CA
SMF78A
SMF78CA
DT
CDT
78
86.7
95.8
1
SMF85A
SMF85CA
DV
CDV
85
94.4
104
1
1
SMF90A
SMF90CA
DX
CDX
90
100
111
1
1
146
1.2
SMFl00A
SMFl00CA
DZ
CDZ
100
111
123
1
1
162
1.1
SMF110A
SMF110CA
EE
CEE
110
122
135
1
1
177
1
SMF120A
SMF120CA
EG
CEG
120
133
147
1
1
193
0.9
r
SMF75A
DR
SMF130A
SMF130CA
EK
CEK
130
144
159
1
1
209
0.8
SMF150A
SMF150CA
EM
CEM
150
167
185
1
1
243
0.7
SMF160A
SMF160CA
EP
CEP
160
178
197
1
1
259
0.7
SMF170A
SMF170CA
ER
CER
170
189
209
1
1
275
0.6
SMF180A
SMF180CA
ET
CET
180
201
222
1
1
292
0.5
SMF200A
SMF200CA
EX
CEX
200
224
247
1
1
324
0.5
SMF220A
SMF220CA
E22
CE22
220
246
272
1
1
356
0.5
www.jsmsemi.com
第2/4页
SMF系列-A/CA
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
Fig.2 Forward Current Derating Curve
100
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1.0
JS
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
0.1
0.1
1
10
100
1000
10000
100
80
60
40
50
75
100
125
150
175
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
CR
MI
Fig.4 Maximum Non-Repetitive Peak
120
T A =25°C
100
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
O
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
4.0
30
25
10
05
T J =T J max
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
r
to
uc
nd
co
T,TIME,ms
3.0
mi
Se
I ppm ,Peak Pulse Current (%)
t f =10usec
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
Fig.3 Pulse Waveform
www.jsmsemi.com
第3/4页
SMF系列-A/CA
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
g
A
MI
e
E
g
pad
JS
D
E
A
pad
HE
CR
Top View
O
Bottom View
D
E
e
g
HE
0.20
2.9
1.9
1.1
0.9
3.8
max
1.1
min
0.9
0.12
max
43
7.9
min
35
4.7
2.6
1.7
0.8
0.7
3.5
114
75
43
35
150
28
138
102
67
7°
co
31
uc
nd
The recommended mounting pad size
2.0
(79)
to
1.2
(47)
1.2
(47)
r
1.2
(47)
mil
C
mi
mm
A
Se
UNIT
Unit: mm
(mil)
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“SMF15CA”相匹配的价格&库存,您可以联系我们找货
