SMF5.0A
SMF5.0A
    JSMSEMI(杰盛微)
    SMF(SOD-123FL)
    SOD123FL SMT 5V 9.2V
SMF5.0A 数据手册
SMF系列-A/CA Surface mount transient voltage suppressor power 200 watts Stand-Off Voltage: 5.0V~220V FEATURES PINNING • For surface mounted applications in order to PIN optimize board space. • Low profile package DESCRIPTION 1 Cathode 2 Anode • Glass passivated junction 1 • Low inductance 2 Unipolar • Plastic package has Underwriters Laboratory JS Flammability Bipolar MECHANICAL DATA MI Top View ▪Case: SOD-123FL Simplified outline sSOD-123FL and symbol CR ▪Terminals: Solderable per MIL-STD-750, Method 2026 ▪Approx. Weight:15mg 0.00048oz O Se Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Peak Pulse Power Dissipation on TA=2 5°C (Note 1,2,5, Fig1) Value Unit P PPM 200 W I FSM 20 A see Table 1 A 1 W -55 to +150 °C (UNI) Peak Pulse Current on 10/1000 us waveform (Note 1 ) Fig 2 Steady State Power Dissipation (Note 4) I PPM P M(AV) T J,T STG Operating Junction and Storage Range RθJA Typical Thermal Resistance to uc nd Peak Forward Surge Current (Note 3) Symbol co mi Parameter 180 °C r NOTES 1. Non-repetitive current pulse per Fig 3 and derated above T A=25°C per Fig 2 2. Mounted on 5mm 2 copper pads to each terminal 3. 8.3ms single half sinewave, or equivalent square wave duty cycle=4 pulses per minutes maximum 4. lead temperature at T L=75°C 5. Peak pulse powe. waveform is tp=10/1000us 6. A transient suppressor is selected according to the working peak reverse voltage(V RWM), Which Should be equal to or greater than the DC or continuous peak operating voltage level www.jsmsemi.com 第1/4页 SMF系列-A/CA Characteristics at Ta = 25°C Table 1 Test Current Breakdown Voltage Type Marking Reverse Leakage Max. Clamp Voltage Peak Pulse Current I R @ V RWM V C @ I PP I PP A V BR @ I T V RMW IT Min Max Bi Uni Bi V V V mA μA V SMF5.0A SMF5.0CA AE CAE 5 6.4 7 10 200 9.2 21.7 SMF6.0A SMF6.0CA AG CAG 6 6.67 7.37 10 100 10.3 19.4 SMF6.5A SMF6.5CA AK CAK 6.5 7.22 7.98 10 75 11.2 17.9 SMF7.0A SMF7.0CA AM CAM 7 7.78 8.6 10 50 12 16.7 SMF7.5A SMF7.5CA AP CAP 7.5 8.33 9.21 1 50 12.9 15.5 SMF8.0A SMF8.0CA AR CAR 8 8.89 9.83 1 25 13.6 14.7 13.9 Uni SMF8.5CA AT CAT 8.5 9.44 10.4 1 10 14.4 SMF9.0CA AV CAV 9 10 11.1 1 5 15.4 13 SMFl0A SMFl0CA AX CAX 10 11.1 12.3 1 2.5 17 11.8 S M F 11 A S M F 11 C A AZ CAZ 11 12.2 13.5 1 2.5 18.2 11 SMF12A SMF12CA BE CBE 12 13.3 14.7 1 2.5 19.9 10.1 BG CBG 13 14.4 15.9 1 1 21.5 9.3 BK CBK 14 15.6 17.2 1 1 23.2 8.6 BM CBM 15 16.7 18.5 1 1 24.4 8.2 CBP 16 17.8 19.7 1 1 26 7.7 CBR 17 18.9 20.9 1 1 27.6 7.2 CBT 18 20 22.1 1 1 29.2 6.8 20 22.2 24.5 1 1 32.4 6.2 MI JS SMF8.5A SMF9.0A SMF13CA SMF14CA SMF15A SMF15CA SMF16A SMF16CA BP SMF17A SMF17CA BR SMF18A SMF18CA BT SMF20A SMF20CA BV CBV SMF22CA BX CBX 22 24.4 26.9 1 1 35.5 5.6 CBZ 24 26.7 29.5 1 1 38.9 5.1 28.9 31.9 1 1 42.1 4.8 31.1 34.4 1 1 45.4 4.4 O SMF22A CR SMF13A SMF14A SMF24CA SMF26A SMF26CA CE CCE 26 SMF28A SMF28CA CG CCG 28 SMF30A SMF30CA CK CCK 30 33.3 36.8 1 48.4 4.1 SMF33A SMF33CA CM CCM 33 36.7 40.6 1 1 53.3 3.8 SMF36A SMF36CA CP CCP 36 40 44.2 1 1 58.1 3.4 SMF40A SMF40CA CR CCR 40 SMF43A SMF43CA CT CCT 43 47.8 SMF45A SMF45CA CV CCV 45 50 SMF48A SMF48CA CX CCX 48 53.3 58.9 SMF51A SMF51CA CZ CCZ 51 56.7 62.7 SMF54A SMF54CA DE CDE 54 60 66.3 SMF58A SMF58CA DG CDG 58 64.4 71.2 SMF60A SMF60CA DK CDK 60 66.7 73.7 SMF64A SMF64CA DM CDM 64 71.1 78.6 SMF70A SMF70CA DP CDP 70 77.8 86 1 CDR 75 83.3 92.1 1 1 44.4 49.1 1 64.5 3.1 52.8 1 1 69.4 2.9 55.3 1 1 72.7 2.8 1 1 1 77.4 2.6 1 1 82.4 2.4 1 1 87.1 2.3 1 1 93.6 2.1 1 1 96.8 1.8 1 1 103 1.7 to uc nd co mi Se SMF24A BZ 1 113 1.5 1 121 1.4 1 126 1.4 137 1.3 SMF75CA SMF78A SMF78CA DT CDT 78 86.7 95.8 1 SMF85A SMF85CA DV CDV 85 94.4 104 1 1 SMF90A SMF90CA DX CDX 90 100 111 1 1 146 1.2 SMFl00A SMFl00CA DZ CDZ 100 111 123 1 1 162 1.1 SMF110A SMF110CA EE CEE 110 122 135 1 1 177 1 SMF120A SMF120CA EG CEG 120 133 147 1 1 193 0.9 r SMF75A DR SMF130A SMF130CA EK CEK 130 144 159 1 1 209 0.8 SMF150A SMF150CA EM CEM 150 167 185 1 1 243 0.7 SMF160A SMF160CA EP CEP 160 178 197 1 1 259 0.7 SMF170A SMF170CA ER CER 170 189 209 1 1 275 0.6 SMF180A SMF180CA ET CET 180 201 222 1 1 292 0.5 SMF200A SMF200CA EX CEX 200 224 247 1 1 324 0.5 SMF220A SMF220CA E22 CE22 220 246 272 1 1 356 0.5 www.jsmsemi.com 第2/4页 SMF系列-A/CA PEAK PULSE POWER(PPP)OR CURRENT(Ipp) DERATINGIN PERCENTAGE% Fig.2 Forward Current Derating Curve 100 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 JS P PPM ,PEAK PULSE FORWARD ,kW Fig.1 Peak Pulse Power Rating Curve 0.1 0.1 1 10 100 1000 10000 100 80 60 40 20 0 25 50 75 100 125 150 175 T A ,AMBIENT TEMPERATURE,°C td,PULSE WIDTH ,us CR MI Fig.4 Maximum Non-Repetitive Peak Forward Surge Current 120 T A =25°C 100 Peak Value Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp O I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 4.0 30 25 20 15 10 05 T J =T J max 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz r to uc nd co T,TIME,ms 3.0 mi Se I ppm ,Peak Pulse Current (%) t f =10usec I FSM ,PEAK FORWARD SURGE CURRENT, AMPERES Fig.3 Pulse Waveform www.jsmsemi.com 第3/4页 SMF系列-A/CA PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND VM g A MI e E g pad JS D E A pad HE CR Top View O Bottom View D E e g HE 0.20 2.9 1.9 1.1 0.9 3.8 max 1.1 min 0.9 0.12 max 43 7.9 min 35 4.7 2.6 1.7 0.8 0.7 3.5 114 75 43 35 150 28 138 102 67 ∠ 7° co 31 uc nd The recommended mounting pad size 2.0 (79) to 1.2 (47) 1.2 (47) r 1.2 (47) mil C mi mm A Se UNIT Unit: mm (mil) www.jsmsemi.com 第4/4页
SMF5.0A 价格&库存
很抱歉,暂时无法提供与“SMF5.0A”相匹配的价格&库存,您可以联系我们找货
SMF5.0A
    • 20+0.13175
    • 200+0.12325
    • 500+0.11475
    • 1000+0.10625
    • 3000+0.10200
    • 6000+0.09605
