Silicon Epitaxial Planar Zener Diodes
FEATURE
LL-34
In MiniMELF case especially for automatic insertion.
These diodes are also available in DO-35 case with
the type designation BZX55C...
0.063(1.6)
0.055(1.4)
0.020(0.5)
0.012(0.3)
0.020(0.5)
0.012(0.3)
0.146(3.7)
0.130(3.3)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
500
1)
Unit
Power Dissipation
Ptot
Junction Temperature
Tj
175
O
C
Tstg
- 55 to + 175
O
C
Symbol
Max.
Storage Temperature Range
1)
mW
Valid provided that electrodes are kept at ambient temperature
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
RθJA
Forward Voltage
at IF = 100 mA
1)
VF
0.3
1
1)
Unit
K/mW
V
www.jsmsemi.com
第1/8页
Electrical Characteristics
Notes:
@ TA = 25°C unless otherwise specified
1. Tested with pulses tp = 20 ms.
2. Valid provided that electrodes are kept at ambient temperature.
www.jsmsemi.com
第2/8页
Breakdown characteristics
Tj = constant (pulsed)
mA
50
Iz
ZMM...
Tj=25oC
ZMM1
40
30
Test current Iz
5mA
10
2
3
4
5
6
7
8
9
10 V
Vz
ZMM...
mA
30
Tj=25oC
ZMM10
ZMM12
Iz
ZMM15
ZMM18
ZMM22
ZMM27
Test current Iz
5mA
10
ZMM33
ZMM36
40 V
Vz
www.jsmsemi.com
第3/8页
mA
10
Iz
ZMM...
Tj=25oC
ZMM39
ZMM51
ZMM43
ZMM47
8
Test current Iz
5mA
6
4
2
40
50
60
70
80
90
100 V
Vz
Admissible power dissipation
versus ambient temperature
Forward characteristics
mA
10
ZMM...
mW
500
ZMM...
3
10 2
iF
Ptot
400
10
Tj=100oC
1
300
o
10
10
10
10
Tj=25 C
-1
200
-2
-3
100
-4
0.4
0.6
0.8
1V
VF
200oC
100
Tamb
www.jsmsemi.com
第4/8页
Pulse thermal resistance
versus pulse duration
Dynamic resistance
versus Zener current
Valid provided that the electrodes are kept
K/W
ZMM...
3
10
Tj=25oC
7
5
5
4
rthA
rzj
3
2
2
7
3
100
0.2
5
4
4
2
0.5
10
5
4
0.1
3
3
0.05
2
2
0.02
10
0.01
10
2v7
ZMM1
V=0
7
3v6
5
5
4
V=
2
tp
3
PI
T
10-5 10-4
-3
10
-2
10
10
tp
ZMM5v6
1
-1
0.1
10 S
1
2
5
1
2
5
10
2
Dynamic resistance
pF
1000
ZMM...
100
ZMM...
o
Tj=25 C
o
Tj=25 C
7
rzj
5
4
5
4
3
VR=1V
3
33
2
VR=2V
27
22
10
18
100
7
5
15
5
4
V R=1V
VR=2V
4
100mA
5
Iz
Capacitance versus
Zener voltage
2
5v1
2
T
1
4v7
4
tp
3
Ctot
ZMM...
1000
12
3
10
3
2
6v8/8v2
ZMM6v2
2
1
10
1
2
3
4 5
10
2
3
4 5
0.1
2
5
1
2
5
10
2
5
100mA
100V
Iz
Vz at Iz=5 mA
www.jsmsemi.com
第5/8页
Thermal differential resistance
versus Zener voltage
Dynamic resistance
3
ZMM...
10
7
rzth=RthA.Vz.
5
4
5
Vz
Tj
3
4
rzj
ZMM...
3
10
Tj=25oC
2
3
2
2
rzth
10
5
4
3
2
10
7
47v+51v
43v
39v
5
4
2
10
ZMM36
3
5
4
3
2
negative
2
10
0.1
2
3
4 5
1
2
3
10mA
4 5
positive
1
1
2 3
4 5
2
10
Iz
3 4 5
100V
Vz at Iz=5 mA
Temperature dependence of Zener voltage
Dynamic resistance
mV/K
25
ZMM...
100
ZMM...
7
5
rzj
Vz
Tj
4
3
5mA
Iz=1mA
20mA
15
2
10
10
7
5
5
4
3
1
o
Tj=25 C
Iz=5 mA
1
2
3
4 5
10
2
3
4 5
100V
Vz at Iz=5 mA
www.jsmsemi.com
-5
1
2
3
4 5
10
2
3
4 5
100V
Vz at Iz=5 mA
第6/8页
mV/K
Change of Zener voltage
versus junction temperature
V
ZMM...
100
ZMM...
9
Iz=5 mA
8
80
Vz bei Iz=5mA
7
Vz
Tj
Vz
60
51V
6
43V
5
36V
4
40
3
2
1
60
80
Iz=5 mA
-1
100V
60
80
100
Vz at Iz=5 mA
Tj
Change of Zener voltge from turn-on
up to the point of thermal equilibrium
V
ZMM...
0.8
X)
25
Vz=35
V
0.7
V
1.6
15
1.4
10
0.6
Vz
ZMM...
Vz=rzth.Iz
Iz=5 mA
1.2
Vz
0.5
1
8
0.4
0.8
7
0.3
0.6
6.2
0.2
0.4
5.9
0.1
0.2
5.6
-0.1
X)
-0.2
o
140 C
120
at Iz=5 mA
40
60
80
1
3.6
100
-0.2
4.7
120
-0.4
o
140 C
1
2
3
4 5
10
2
3
4 5
100V
Tj
Vz at Iz=5 mA
www.jsmsemi.com
第7/8页
V
ZMM...
5
Vz=rzth.Iz
4
Vz
3
Iz
=5 mA
2
1
Iz =2 mA
60
80
100V
Vz at Iz=5 mA
www.jsmsemi.com
第8/8页
很抱歉,暂时无法提供与“ZMM5V6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04283
- 200+0.04015
- 600+0.03747
- 2000+0.03480
- 5000+0.03212
- 10000+0.03025
