1N4007W
1N4007W
    JSMSEMI(杰盛微)
    SMF(SOD-123FL)
    SOD123FL 30A
1N4007W 数据手册
1N4001W THRU 1N4007W Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 1 A PIN FEATURES ▪For surface mounted applications ▪Low profile package ▪Glass Passivated Chip Junction ▪Ideal for automated placement ▪Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: A1-A7 Simplified outline SOD-123FL and symbol MI JS MECHANICAL DATA ▪Case: SOD-123FL ▪Terminals: Solderable per MIL-STD-750, Method 2026 ▪Approx. Weight: 15mg / 0.00053oz CR Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. O Symbols 1N4001W 1N4002W 1N4003W 1N4004W 1N4005W 1N4006W 1N4007W Units Parameter V RRM V RMS Maximum DC Blocking Voltage V DC Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM Maximum Instantaneous Forward Voltage at 1 A VF Typical Junction Capacitance Typical Thermal Resistance (1) (2) Operating and Storage Temperature Range 600 800 1000 V 35 70 140 280 420 560 700 V 50 100 200 400 600 800 1000 V 1 A 30 A 1.1 V IR 5 50 μA Cj 8(TYP.) pF RθJA 90 °C/W T j , T stg -55 ~ +150 °C r T a =125 °C 400 to T a = 25 °C 200 uc nd Maximum DC Reverse Current at Rated DC Blocking Voltage 50 co Maximum RMS voltage 100 mi Se Maximum Repetitive Peak Reverse Voltage (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.jsmsemi.com 第1/3页 1N4001W THRU 1N4007W Fig.2 Typical Instaneous Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current ( μ A) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 175 100 T J=150°C T J=125°C 10 1.0 T J=75°C 0.1 T J =25°C 1N4007W 0.01 0 JS MI TJ = 10 TJ = 0.7 0.9 1.0 1.1 Instaneous Forward Voltage (V) 100 T J=25°C 10 1 0.1 1.0 10 100 Reverse Voltage (V) co uc nd Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 35 30 25 20 to 15 10 05 r Peak Forward Surage Current (A) Junction Capacitance ( pF) 0°C 0°C 15 0.6 mi 0.1 0.5 Se TJ = 2 5° C O Instaneous Forward Current (A) CR 0.8 0.2 800 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 0.5 600 Instaneous Reverse Voltage (V) Case Temperature (°C) 1.0 400 200 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.jsmsemi.com 第2/3页 1N4001W THRU 1N4007W PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND HE VM e E MI CR Top View Bottom View O D E e g HE 0.20 2.9 1.9 1.1 0.9 3.8 max 1.1 min 0.9 0.12 max 43 7.9 min 35 4.7 2.6 1.7 0.8 0.7 3.5 114 75 43 35 150 28 138 102 67 31 uc nd The recommended mounting pad size Marking 1.2 (47) A1 1N4002W A2 Unit: mm (mil) www.jsmsemi.com r 1N4001W 1N4003W 1.2 (47) 2.0 (79) Marking code to Type number 1.2 (47) ∠ 7° co mil C mi mm A Se UNIT g pad g A pad JS D E A A3 1N4004W A4 1N4005W A5 1N4006W A6 1N4007W A7 第3/3页
1N4007W 价格&库存
很抱歉,暂时无法提供与“1N4007W”相匹配的价格&库存,您可以联系我们找货
1N4007W
    • 50+0.04291
    • 200+0.04023
    • 600+0.03755
    • 2000+0.03486
    • 5000+0.03218
    • 10000+0.03030
    库存:19
