OR-3023S
OR-3023S
    ORIENT(奥伦德)
    SOP-6
    光隔离器 可控硅 输出 5000Vrms 1通道 SOP6
OR-3023S 数据手册
Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X ORIENT Photocoupler Product Data Sheet Name: MOC302X(Byname:OR-302X) Customer:_________________ Date:_________________ Add:Block A 3rd Floor No.4 Building Tian An Cyber Park Huang Ge Rd, Long Gang Dist, Shenzhen, Guangdong, 518172 Web: www.orient-opto.com Copyright© 2018 Orient .All rights Reserved 1 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 1. Features (1) Isolation voltage between input and output Viso : 5,000V rms (2) 6pin non zero-cross optoisolators triac driver output (3) High repetitive peak off-state voltage VDRM : Min. 600V (4) High critical rate of rise of off-state voltage( dV/dt : MIN. 1000V / s ) (5) Dual-in-line package : MOC3020, MOC3021, MOC3022, MOC3023 (6) Wide lead spacing package : MOC3020M, MOC3021M, MOC3022M,MOC3023M (7) Surface mounting package : MOC3020S, MOC3021S, MOC3022S, MOC3023S (8) Tape and reel packaging : MOC3020S-TA, MOC3021S-TA, MOC3022S-TA, MOC3023S-TA,MOC3020S-TA1, MOC3021S-TA1, MOC3022S-TA1, MOC3023S-TA1 2. Description The MOC302X consists of a non zero crossing photo triac, optically coupled to a gallium arsenide infrared emitting diode. The MOC302X is housed in the DIP6 package and guarantees insulation thickness.Therefore, the MOC302X meets the reinforced insulation class requirements of international safety standards. 3.Application Range •AC Motor Drives •AC Motor Starters •Static power switch •Lighting Controls •Solenoid/Valve Controls •Solid State Relays •Temperature Controls 4. Absolute Maximum Ratings (Ta=25℃) Parameter Input Forward Current Junction Temperature Reverse Voltage Power Dissipation Off-State Output Terminal Voltage Peak Repetitive Surge Current Output (PW=1ms,120 pps) Junction Temperature Collector Power Dissipation Total Power Dissipation *1 Insulation Voltage Working Temperature Deposit Temperature *2 Soldering Temperature Symbol Rated Value Unit IF TJ VR P 50 125 6 100 mA ℃ V mW V DRM 400 V I TSM 1 A TJ PC Ptot Viso Topr Tstg Tsol 125 300 330 5000 -40 ~ + 100 -55 ~ + 150 260 ℃ mW mW Vrms ℃ Notes: *1 AC for 1 minute, R.H.= 40 ~ 60% R.H. In this test, pins 1, 2&3 are shorted together, and pins 4, 6 are shorted together. * 2 For 10 seconds Copyright© 2018 Orient .All rights Reserved 2 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 5. Electrical Optical Characteristics at Ta=25°C Parameter Input Output Symbol Condition Min Typ.* Max Forward Voltage VF IF=20mA --- 1.2 1.6 V Reverse Current IR VR=6V --- 0.05 10 μA 1.Peak Blocking Current, Either Direction IDRM V DRM = 400V --- 10 100 nA Peak On-State Voltage, Either Direction VTM ITM=100mA Peak --- 1.7 3.0 V 2.Critical rate of Rise of Off-State Voltage dv/dt Vin=240Vrms 1000 --- --- V/us --- --- 30 --- --- 15 --- --- 10 --- --- 5 --- 200 --- MOC3020 3.Led Trigger Current,Current MOC3021 Couple Required to Latch Output, Either Direction MOC3022 IFT Main Terminal Voltage = 3V MOC3023 Holding Current, Either Direction IH Unit mA uA *1.Test voltage must be applied within dv/dt rating. *2. This is static dv/dt. Commutating dv/dt is a function of the load-driving thyristor(s) only. *3. All devices are guaranteed to trigger at an IF value less than or equal to max IFT . Therefore,recommended operating IF lies between max IFT , 30 mA for MOC3020, 15 mA for MOC3021, 10 mA for MOC3022, 5 mA for MOC3023, and absolute max IF (50mA). Copyright© 2018 Orient .All rights Reserved 3 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 6.Naming Rule NOTE: (1) Manufacturer denotes Shenzhen Orient Tech Ltd . Co ., Ltd. (2) denotes IFT Rank Code ,0=MOC3020;1=MOC3021;2=MOC3022;3=MOC3023. (3) denotes Week code. (4) denotes Year code. (5) denotes Anode. (6) MOC302 denotes Device Part Number. (7) Unit:mm Copyright© 2018 Orient .All rights Reserved 4 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 7. Package Dimension (1).MOC302X (2).MOC302X M Copyright© 2018 Orient .All rights Reserved 5 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X (3).MOC302X S 8. Taping Dimensions (1).MOC302XS-TA Copyright© 2018 Orient .All rights Reserved 6 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X (2).MOC302XS-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment Package Type MOC302XS series(TA/TA1) Quantities(pcs) 1000 Copyright© 2018 Orient .All rights Reserved 7 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 9.Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin ) 150˚C - Temperature Max (TSmax ) 200˚C - Time (min to max) (ts) Soldering zone 90±30 sec - Temperature (TL ) 217˚C - Time (tL ) 60 sec Peak Temperature(TP) 260˚C Ramp-up rate 3˚C / sec max. Ramp-down rate Copyright© 2018 Orient .All rights Reserved 3~6˚C / sec 8 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X (2) .Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature 380+0/-5˚C Time 3 sec max Copyright© 2018 Orient .All rights Reserved 9 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 10.RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Copyright© 2018 Orient .All rights Reserved 10 A0 Shenzhen Orient Tech Ltd . Co ., Ltd MOC302X 11. CHARACTERISTICS CURVES (TYPICAL PERFORMANCE) Copyright© 2018 Orient .All rights Reserved 11 A0 Shenzhen Orient Tech Ltd . Co ., Ltd Copyright© 2018 Orient .All rights Reserved 12 MOC302X A0
OR-3023S 价格&库存
很抱歉,暂时无法提供与“OR-3023S”相匹配的价格&库存,您可以联系我们找货
