产品编码对照表
PRODUCT CODE COMPARATIVE TABLE
MMKP82
124
○产品类别 Type of capacitor
1
类别 model
代码 Code
型号 model
代码 Code
MPP
MMKP
KP
J 3A
CBB21
CBB22
KP
KP
KP
22
型号:MMKP82
01
MER
CL21
PPS
CBB81
PE
PE
PS
PS
CBB28
PPN
CBB13
X2
MPB
PN
PN
PX
PC
PS
MMKP82
○产品容量代码 Capacitance code (EIA Code)
2
代码 Code
容量换算
代码 Code
Capacitance
容量换算
代码 Code
Capacitance
容量换算
Capacitance
101
100pF
0.1nF
0.0001uF
103
10,000pF
10nF
0.01uF
105
1,000,000pF
1,000nF
1uF
102
1,000pF
1nF
0.001uF
104
100,000pF 100nF
0.1uF
106
10,000,000pF
10,000nF
10uF
○产品容量误差 Tolerance (EIA Code)
3
误差 Tol.
代码 Code
±1%
F
±2%
G
±3%
I
±5%
J
○产品额定电压 Rated Voltage
±10%
K
±20%
M
–10%~ 0%
L
0%~+10%
P
–5%~+10%
U
–10%~+5%
V
0%~+20%
W
4
电压 Voltage
代码 Code
63
100
125
250
275
310
350
380
400
450
630
800
1000
1200
1250
1600
2000
3000
1J
2A
2B
2E
2C
2H
2K
2L
2G
2W
2J
2D
3A
3I
3B
3C
3F
3G
○产品本体脚距 Lead Space
5
本体脚距 Lead Space
代码 Code
5
05
7.5
07
10
10
○辅助码(内部识别码) Accessories Yards
6
NO.
1
2
说明
15
15
22
24
24
25
25
26
26
27.5
27
31
31
Descriptions
每个规格第一料号时用“01" Each specification first edit with" 01"
同种规格原料、外观及尺寸有差异时用“01,02,03...”进行区分
The same specifications appearance and size differ with non-simultaneous 01, 02, 03 to distinguish
Guideline of notabilia for the usage of plastic film capacitors
塑胶薄膜电容器的使用上注意事项及指导
Plastic film capacitors use organic films for their dielectrics, thus the capacitors may fume of flame, depending on the circuit conditions they are in, when they are
damaged by applying over-voltage or over-current.
塑胶薄膜电容器使用有机薄膜为介质,当使用超过额定电压及额定电流,可能产生火焰,导致电容损坏,故请使用于正确的电路。
1. Circuit Design 电路设计
① Please use capacitors within the range of their characteristic ratings, only after confirming their operating and mounting
environments.
请确认电容器的使用范围仅止于明定之额定特性规范,请先确认电容器使用之环境是否符合规范。
请依照适合的作业条件选择相对应的电容器使用。
② In case of selecting a capacitor, please select the most suitable one which fits to your operating conditions.
③ An applying voltage to a capacitor, including the peak of surge and ripple voltage (D.C. voltage + A.C. Peak), cannot be exceeded the
rating voltage.
电容器之应用电压,包括突波和纹波电压的峰值 直流电压 交流峰值 不可超过额定电压。
④ Do not apply a current over its permissible level. Also, make sure the check the surrounding temperature and inherent temperature
rise of a capacitor since a permissible current can be restricted by those factors.
切勿使用超出电容器可承载之电流并检查电容器周围之温度,因有许多因素会影响电流之变化,进而造成电容器之温度上升。
⑤ Do not conduct a rapid charge and discharge to a capacitor which may lead to characteristics degradations or break down of the
capacitor.
请不要对电容器进行快速的充电和放电,此可能会导致电容器之特性退化或损坏。
安装
请不要使用任何超过电容导线可承受之张力进行插件。
② Please mount a capacitor where it dose not contact any other heating parts, high voltage parts and other parts.
请确认电容器使用环境,避免接触任何其他升温热物件 高压和其他部分料件。
③ Please conduct soldering process by strictly following the specified conditions.
进行焊接过程实,请严格遵循指定之焊接条件。
3.Storing and handling 储存和处理
① A storage needs to be kept indoors at -10~+30℃ and relative humidity of under 75% without any sudden temperature changes,
direct sunlight and corrosive gas around.
需保存于
,相对湿度低于 并确保没有任何突然的温度变化,避免直接阳光之曝晒及接触腐蚀性气体之环境。
② Do not apply and exceeding vibration, shock (dropping) and pressure.
不应过度震动、碰撞和及外力的冲击。
③ According to normal conditions, the storage time exceeds 12 months, and all capacitor characteristics must be checked before production and use.
按正常条件储存时间超出12个月时间,生产使用前需检查。
2. Mounting
① Do not apply any exceeding tension or torsion to lead wires of a capacitor, during the mounting process.
-10 ~ 30℃
75%
东莞市科雅电子科技有限公司
3/8
产品规格说明
PRODUCT SPECIFICATIONS
NO. 项目 ITEM
承认范围
1
SCOPE
型号: MMKP82
说明 DESCRIPTIONS
本规格适用于科雅之要求
This specifications cover the requirements of KYET
双面金属化聚丙烯薄膜电容器 MMKP82
Metallized Polypropylene Film capacitor
2
各测量皆于标准大气下进行 STANDARD ATMOSPHERIC CONDITIONS FOR MAKING MEASUREMENTS
2.1
环境温度 AMBIENT TEMPERATURE
2.2
相对湿度 RELATIVE HUMIDITY(R.H.)
2.3
大气压力 AIR PRESSURE
86
106
86 kpa to 106 kpa
2.4
工作温度范围
于-40℃至+105℃间,电容可在额定电压下持续运作
-40℃ to +105℃ for which the capacitor can be operated continuously at rated
3
3.1
3.2
3.3
3.4
3.5
4
OPERATING TEMPERATURE RANGE
结构 CONSTRUCTION
电介质
喷金层
导线
环氧树脂
塑料外壳
DIELECTRIC
METAL SPRAY
LEAD WIRE
EPOXY RESIN
PLASTIC CASE
打印 MARKING
℃ 至 35℃ (如对结果有任何疑问,该测量环境温度应为+20 ± 5℃之间)
℃ to 35℃ (If there is any doubt on the results, the measurements shall be made
at +20 ± 5℃)
45%至 75% (如对结果有任何疑问,该测量相对湿度应为 60% to 70%之间)
15
15
45%to 75% (If there is any doubt on the results, the measurements shall be made at
60% to 70%)
千帕至
千帕之
voltage.
双面金属化聚丙烯薄膜 Metallized Polypropylene
Film
特殊焊料
镀锡铜线
UL V-0 耐燃等级
UL V-0 耐燃等级
Special Solder
4.1
制造商标志
MANUFACTURER'S SYMBOL
4.2
型号或材质
TYPE OR MATERIAL
“MMKP82” stands for “Metallized Polypropylene
Film”
4.3
电容类别
CAPACITOR CLASS
“MMKP”
“KP”
“KPstands for “MMKP” class
4.4
静电容量
NOMINAL CAPACITANCE
EIA
Capacitance Expressed in 3-digit (EIA) code.
4.5
容量容许差值 TOLERANCE
J (±5%) , K(±10%) , M(±20%)
4.6
额定电压
400,630,1000,1600,2000 VDC
4.7
RATED VOLTAGE
工作温度范围
Operating Temperature
Range
4.8
散逸因素(损耗角正切)
4.9
绝缘电阻
Insulation Resistance
东莞市科雅电子科技有限公司
表示为”科雅电子科技有限公司 KYET ELECTRONICS CO., LTD”
“MMKP82”代表“双面金属化聚丙烯”材质
参照图片 example
代表
类别
容量用 三码表示
-40
℃~105℃
Max 0.1%(at 1KHZ, 25℃)
CR≤0.33µF IR≥10000MΩ
UR≤100V
CR
0.33 F IR 5000M / F UR 100V
> μ
Ωμ
4/8
产品规格说明
型号:MMKP82
5
NO.
5.1
电气特性
项目 ITEM
ELECTRICAL CHARACTERISTICS
耐压 (TV)
说明 DESCRIPTIONS
引线之间
Between Terminals
Between Terminals
&Enclosure
5.3
5.4
应无异常
2 倍额定电压+500V,测试 2 到 5 秒
最小值 2000VDC
Shall be no abnormality
Withstand
Voltage
引线与外壳之间
5.2
应无异常
施加 1.6 倍额定直流电压测试 60 秒(电压应
以不超过 150V/s 的速率从零升高到试验电
压,时间应从达到电压时计算,在结束时,
电压应减少到接近零,并且电容器应通过一
个适当的电阻放电)
介质损耗 (DF)
于 1KHz 时 ≤ 0.001(0.1%)
Dissipation Factor
≤ 0.001(0.1%) at 1 KHz
容量 (CAP)
+20 ± 5 )
Within the tolerance specified
绝缘电阻 (I.R.)
≥10,000 Mohm (C≤0.33uf)
≤0.33uf
≥10,000M
≥5,000 Mohm*uF/C (C>0.33uf)
>0.33uf
环境温度(于
(at +20 ± 5℃).
Capacitance
容值
容值
Ω
Ω
时,绝缘电阻
时,绝缘电阻
Apply 1.5*Ur (DC) for 60 sec (Should be no
more than 150V/s rate increased from zero to
the test voltage, testing time, meets the test
voltage should be calculated at the end of the
trial, the voltage should be reduced to zero
and the capacitor through a resistor of
appropriate discharge.
Apply 2*Ur+500V for 2 to 5 sec.
Min. 2000VDC
测量频率
测量电压
测量频率
测量电压
: ±2% ;
: ≤1 rms
Measuring Frequency: ±2%
Measuring Voltage: ≤1 Vrms..
: ±2% ;
: ≤1 rms
测试电压 100 伏
充电时间 60±5 秒。
Vt=100 VDC
Charge Time : 60±5 sec.
≥5,000M *uF / C
5.5
6
6.1
焊料覆盖面积应超过导线表面
圆周 90%。
焊料附着性
Soldering Property
焊接温度为: +260 ± 5℃
浸焊时间为: 2 ± 0.5 秒
More than 90% of circumferential
surface of lead wire shall be
covered with new solder.
Soldering temperature: +260 ± 5
Immersion duration: 2 ± 0.5 sec.
应无异常。
沿着引出方向,施加 1 公斤力量,保持 10±1
秒。
机械特性 MECHANICAL CHARACTERISTICS
引线强度
引线强度
Tensile Strength
Terminal
Strength
东莞市科雅电子科技有限公司
Apply 1.0Kg for 10 ± 1 sec. to the terminal in
the axial direction and acting in a direction
away from the body.
5/8
产品规格说明
型号: MMKP82
7
NO.
耐久性特性 ENDURANCE CHARACTERISTICS
项目 ITEM
外观
Appearance
耐压
Withstand Voltage
7.1
Temperature
Cycle
介质损耗
绝缘电阻 (I.R.)
应满足
NO.5.1
shall satisfy NO.5.1
应当无显著变化
容值变化率 △
变化率小于
介质损耗
于 1KHz 时: 最大值为 0.002 (0.2%)
外观
应当无显著变化
Withstand Voltage
容值变化率 △
应满足
NO.5.1
Shall satisfy NO.5.1
变化率小于
±5%
Within ±5% of the value before test
介质损耗
绝缘电阻 (I.R.)
东莞市科雅电子科技有限公司
After test, allow it stay alone for 1.5 ± 0.5 Hrs.
at ordinary condition before making
measurements.
试验温度: +100 ± 2℃
测试时间: 16 ± 1 小时
Test Temperature: +100 ± 2
Test Duration: 16 + 1/-0 hrs.
Shall be no remarkable change
( C/C)
Capacitance Change Rate
Dissipation Factor
℃ for 3 min.
2. -40 ± 3℃ for 10 min.
3. +20 ± 2℃ for 3 min.
4.+100 ± 2℃ for 10min.
5. +20 ± 2℃ for 3 min.
1. 20 ± 2
的限制值在
≥50%
NO.5.4
≥50% of the limit value of NO.5.4
耐压
Test Temperature Cycle: Total 5 cycles.
Each cycle includes
@ 1KHz: 0.002 (0.2%) max.
Appearance
Cold
Resistance
应满足
NO.5.1
±5%
绝缘电阻 (I.R.)
共 5 次温度循环测试,循环条件:
1. +20 ± 2℃ 持续 3 分钟
2. -40 ± 3℃ 持续 10 分钟
3. +20 ± 2℃ 持续 3 分钟
4. +100 ± 2℃ 持续 10 分钟
5. +20 ± 2℃ 持续 3 分钟
试验后放置于室内 1.5 ± 0.5 小时后再进行量
测。
( C/C)
Dissipation Factor
耐干寒试验
的限制值在
外观
Withstand Voltage
Dry Heat
Resistance
≥50%
NO.5.4
耐压
耐干热试验
Appearance
7.3
容值变化率 (△C/C)
变化率小于 ±5%
温度变化循环 Capacitance
Change Rate
Dissipation Factor
7.2
说明 DESCRIPTIONS
应当无显著变化
试验温度: -40 ± 3℃
测试时间: 2 ± 1 小时
Test Temperature: -40 ± 3
Test Duration: 2 ± 1 hrs.
的限制值在
≥50%
NO.5.4
6/8
产品规格说明
NO.
项目 ITEM
外观
说明 DESCRIPTIONS
应当无显著变化
耐压
应满足 NO.5.1
Appearance
Withstand Voltage
7.4
耐湿绝缘
Damp Heat
容值变化率 △
( C/C)
介质损耗
Dissipation Factor
绝缘电阻 (I.R.)
7.5
振动试验
Vibration
Resistance
型号: MMKP82
变化率小于
±5%
的限制值在
≥50%
NO.5.4
外观
应无机械性损伤
连接强度
不得为短路或开路连接。
连接点应稳定。
外观
应当无显著变化
印字标志应清晰
端子间的耐电压值
应满足 NO.5.1
Appearance
Connection strength
Appearance
Withstand Voltage
Between Terminals
容值变化率 △
Shall be no mechanical damage.
Shall be no short-circuiting or open.
The connection shall be stable.
Soldering
Heat
Resistance
变化率小于
( C/C)
±5%
Within ±3% of the value before test
介质损耗
Dissipation Factor
绝缘电阻 (I.R.)
连接元件
Connection of Element
东莞市科雅电子科技有限公司
Test Humidity: 90% to 95% R.H.
Test Duration: 2 ± 1 hrs..
measurements.
频率变化: 10-55-10Hz
振动距离: 1.5 毫米.
试验方向: X,Y,Z
试验时间:每个方向 2± 1 小时
Frequency Change : 10-55-10 Hz
Vibration Distance:1.5 mm.
Test Direction : X,Y,Z
Test Duration : 2± 1hrs each direction
Shall be no remarkable change.
The marking shall be legible.
焊接耐热
7.6
试验温度:+40 ± 2℃
试验湿度:90%至 95%相对湿度
试验时间:2 ± 1 小时
测。
Test Temperature: +40 ± 2℃.
的限制值在
≥50%
NO.5.4
应稳定
预热温度: 85 ~100℃
预热时间:最大为 60 秒
温度升高:最大为 3℃/秒
锡炉温度: +260 ± 5℃
浸焊时间: 2 ± 1 秒
浸焊深度:导线根部 4 ± 0.8 毫米
测。
Preheat Temp. : 85~100℃
Preheat Duration : 60 sec. max.
Temperature Increase by 3℃/sec. max.
Soldering Temperature : +260 ± 5℃
Immersion Duration : 2 ± 1sec.
Immersion Depth : 4 ± 0.8mm from roots. After
test, allow it stay alone for 1.5 ± 0.5 Hrs. at
measurements.
Shall be stable
7/8
产品规格说明
NO.
7.7
项目 ITEM
耐久寿命
Endurance
外观
Appearance
耐压
容值变化率 (△C/C)
变化率小于 ±10%
Within±10% of the value before test
介质损耗
1KHz
@ 1KHz
Cr ≤1uF : 0.008 (0.8%) max.
Cr >1uF : 0.005 (0.5%) max.
绝缘电阻 (I.R.)
耐湿负荷
Moisture
Resistant
Loading
性能 PERFORMANCE
应当无显著变化
应满足 NO.5.1
Withstand Voltage
Dissipation Factor
7.8
型号: MMKP82
于
时: 最大值为
的限制值在
≥50%
NO.5.4
外观
Appearance
耐压
应当无显著变化
应满足 NO.5.1
Withstand Voltage
容值变化率 (△C/C)
变化率小于 ±5%
介质损耗
Dissipation Factor
绝缘电阻 (I.R.)
东莞市科雅电子科技有限公司
的限制值在
≥50%
NO.5.4
测试条件 TEST CONDITIONS
试验温度: +85 ± 2℃
测试电压: 额定电压
试验时间 小时
每小时将电压升至额定电压,持续 0.1 秒
每个电容分别通过一个 47Ω±5 %.电阻。
Test Temperature: +85± 2℃
: 16
Test Voltage: 100% * rated voltage.
Test Duration: 16 Hrs.
Once every hour the voltage For 0.1 sec. The
test voltage is applied to each capacitor
individually through a resistor of 47Ω±5 %.
试验温度: +40 ± 2℃.
试验湿度: 87%至 93%相对湿度
测试电压: 额定电压
试验时间 小时
测。
: 16
Test Humidity: 87% to 93% R.H.
Test Voltage: rated voltage.
measurements.
8/8
