BZV55C6V8 L1G
BZV55C6V8 L1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    MINI-MELF_3.5X1.5MM
    台半 MINI MELF Zzk: 150Ω Pd: 500mW Izk: 1mA
BZV55C6V8 L1G 数据手册
BZV55C2V4 - BZV55C75 Taiwan Semiconductor 500mW, 5% Tolerance SMD Zener Diodes FEATURES KEY PARAMETERS ● Wide Zener voltage range selection: 2.4V to 75V ● VZ tolerance selection of ± 5% ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.4-75 V Test current IZT 5 mA PD 500 mW VF at IF=10mA 1 V TJ Max. 175 °C APPLICATIONS ● Low voltage stabilizers or voltage references ● Adapters ● On-board DC/DC converter Package Mini-MELF Configuration Single die MECHANICAL DATA ● ● ● ● Case: Mini-MELF Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: Indicated by cathode band Weight: 31mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage @ IF=10mA SYMBOL VALUE UNIT VF 1 V Power dissipation PD 500 mW Junction temperature range TJ -65 to +175 °C Storage temperature range TSTG -65 to +175 °C SYMBOL TYP UNIT RӨJA 300 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version: G1804 BZV55C2V4 - BZV55C75 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART NUMBER Min. TEST REGULAR TEST LEAKAGE CURRENT IMPEDANCE CURRENT CURRENT IR @ V R VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA µA V Nom. Max. Max. Max. BZV55C2V4 2.28 2.4 2.56 5 85 600 1.0 50 1.0 BZV55C2V7 2.51 2.7 2.89 5 85 600 1.0 10 1.0 BZV55C3V0 2.8 3.0 3.2 5 85 600 1.0 4 1.0 BZV55C3V3 3.1 3.3 3.5 5 85 600 1.0 2 1.0 BZV55C3V6 3.4 3.6 3.8 5 85 600 1.0 2 1.0 BZV55C3V9 3.7 3.9 4.1 5 85 600 1.0 2 1.0 BZV55C4V3 4.0 4.3 4.6 5 75 600 1.0 1 1.0 BZV55C4V7 4.4 4.7 5.0 5 60 600 1.0 0.5 1.0 BZV55C5V1 4.8 5.1 5.4 5 35 550 1.0 0.1 1.0 BZV55C5V6 5.2 5.6 6.0 5 25 450 1.0 0.1 1.0 BZV55C6V2 5.8 6.2 6.6 5 10 200 1.0 0.1 2.0 BZV55C6V8 6.4 6.8 7.2 5 8 150 1.0 0.1 3.0 BZV55C7V5 7.0 7.5 7.9 5 7 50 1.0 0.1 5.0 BZV55C8V2 7.7 8.2 8.7 5 7 50 1.0 0.1 6.2 BZV55C9V1 8.5 9.1 9.6 5 10 50 1.0 0.1 6.8 BZV55C10 9.4 10 10.6 5 15 70 1.0 0.1 7.5 BZV55C11 10.4 11 11.6 5 20 70 1.0 0.1 8.2 BZV55C12 11.4 12 12.7 5 20 90 1.0 0.1 9.1 BZV55C13 12.4 13 14.1 5 26 110 1.0 0.1 10 BZV55C15 13.8 15 15.6 5 30 110 1.0 0.1 11 BZV55C16 15.3 16 17.1 5 40 170 1.0 0.1 12 BZV55C18 16.8 18 19.1 5 50 170 1.0 0.1 13 BZV55C20 18.8 20 21.1 5 55 220 1.0 0.1 15 BZV55C22 20.8 22 23.3 5 55 220 1.0 0.1 16 BZV55C24 22.8 24 25.6 5 80 220 1.0 0.1 18 BZV55C27 25.1 27 28.9 5 80 220 1.0 0.1 20 BZV55C30 28 30 32 5 80 220 1.0 0.1 22 BZV55C33 31 33 35 5 80 220 1.0 0.1 24 BZV55C36 34 36 38 5 80 220 1.0 0.1 27 BZV55C39 37 39 41 2.5 90 500 0.5 0.1 28 BZV55C43 40 43 46 2.5 90 600 0.5 0.1 32 BZV55C47 44 47 50 2.5 110 700 0.5 0.1 35 BZV55C51 48 51 54 2.5 125 700 0.5 0.1 38 BZV55C56 52 56 60 2.5 135 1,000 0.5 0.1 42 BZV55C62 58 62 66 2.5 150 1,000 0.5 0.1 47 BZV55C68 64 68 72 2.5 160 1,000 0.5 0.1 51 BZV55C75 70 75 80 2.5 170 1,000 0.5 0.1 56 2 Max. Version: G1804 BZV55C2V4 - BZV55C75 Taiwan Semiconductor Notes: 1. The zener voltage (VZ) is tested under pulse condition of 30ms. 2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%. 3. For detailed information on price, availability and delivery of normal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative. 4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK. ORDERING INFORMATION PART NO. (Note 1) PACKAGE PACKING BZV55Cxxx L0 MINI MELF 10K / 13" Reel BZV55Cxxx L0G MINI MELF 10K / 13" Reel BZV55Cxxx L1 MINI MELF 2.5K / 7" Reel BZV55Cxxx L1G MINI MELF 2.5K / 7" Reel Notes: "xxx" defines voltage from 2.4V (BZV55C2V4) to 75V (BZV55C75) 3 Version: G1804 BZV55C2V4 - BZV55C75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Power Dissipation VS. Fig. 2 Total Capacitance Ambient Temperature 1000 600 Total Capacitance (pF) PD-Power dissipation (mW) f=1MHz 500 400 300 200 VR=0V VR=2V 100 VR=5V 10 100 VR=20V 0 1 0 40 80 120 160 200 0 20 40 60 VZ - Reverse Voltage (V) Temperature (oC) Fig. 3 Differential Impedance VS. Zener Voltage 80 Fig.4 Forward Current VS. Forward Voltage 1000 1000 IZ=1mA IZ=2mA 100 Forward Current (mA) Differential Zener Impedance(Ohm) VR=25V IZ=5mA 10 IZ=10mA 100 10 1 1 0.1 0 1 10 0.0 100 VZ - Reverse Voltage (V) 0.2 0.4 0.6 0.8 1.0 1.2 VF - Forward Voltage (mV) 4 Version: G1804 BZV55C2V4 - BZV55C75 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION Mini-MELF DIM. Unit (mm) Unit (inch) Min Max Min Max A 3.30 3.70 0.130 0.146 B 1.40 1.60 0.055 0.063 C 0.20 0.50 0.008 0.020 SUGGEST PAD LAYOUT Unit (mm) Unit (inch) Typ Typ A 1.25 0.049 DIM. 5 B 2.00 0.079 C 2.50 0.098 D 5.00 0.197 Version: G1804 BZV55C2V4 - BZV55C75 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: G1804
BZV55C6V8 L1G 价格&库存
很抱歉,暂时无法提供与“BZV55C6V8 L1G”相匹配的价格&库存,您可以联系我们找货
