M3406-ADJ
M3406-ADJ
    AEROSEMI(航天民芯)
    SOT23-5
    1.5MHz、800mA 同步降压型转换器
M3406-ADJ 数据手册
M3406 Rev.V1.3 1.5MHz, 800mA Synchronous Step-Down Converter FEATURES GENERAL DESCRIPTION  High Efficiency: Up to 96%  The M3406 is a constant frequency, current 1.5MHz Constant Frequency Operation  mode step-down converter. 800mA Output Current  integrates a main switch and a synchronous No Schottky Diode Required  rectifier for high efficiency without an 2.0V to 6.0V Input Voltage Range  external Schottky diode. Output Voltage as Low as 0.6V  powering portable equipment that runs from PFM Mode for High Efficiency in a single cell Lithium-Ion (Li+) battery. The Light Load  output voltage can be regulated as low as 100% Duty Cycle in Dropout  0.6V. The M3406 can also run at 100% duty Low Quiescent Current: 20µA  cycle for low dropout operation, extending Slope Compensated Current Mode battery life in portable system. This device Control for Excellent Line and Load offers two operation modes, PWM control Transient Response  and PFM Mode switching control, which Short Circuit Protection  allows a high efficiency over the wider range Thermal Fault Protection  of the load. Inrush Current Limit and Soft Start 
M3406-ADJ 价格&库存
很抱歉,暂时无法提供与“M3406-ADJ”相匹配的价格&库存,您可以联系我们找货
