7B19200026
7B19200026
    TXC(台晶)
    SMD5032_4P
    无源晶振 19.2MHz 25Ω 8.8pF ±10ppm -20℃~+75℃ SMD5032_4P
7B19200026 数据手册
SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0*3.2 NOMINAL FREQ. : 19.200000MHz TXC P/N : 7B19200026 REVISION : A7 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 03.09'06 VER.D PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0*3.2 NOMINAL FREQ. : 19.200000MHz TXC P/N : 7B19200026 REVISION : A7 PE/RD QA MFG 28-Nov-07 18-Dec-07 3-Dec-07 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D TXC P/N: 7B19200026 REVISION: A7 PAGE: 1 Date Ref.No. Reviser Initial released 16-Mar-05 N/A Yachuan Miao 3 Suggested Reflow Profile Change 27-Mar-05 ECN-05P050501 Yachuan Miao 1 客戶回簽頁新增:Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. 2-Aug-05 DCN-05P062302 Yachuan Miao Rev Revise page A1 N/A A2 A3 3,4 Revise contents 圖面角位修正 25-Aug-05 ECN-05P081002 ECN-05P081601 Yachuan Miao 4 STRUCTURE ILLUSTRATION原物料名稱異動 A4 - Document version chang C to D 21-Jun-06 DCN-06P030701 Yachuan Miao A5 2 SPEC Change 15-Feb-07 ECN-07P021503 Yachuan Miao A6 2 C0值修正:2.0pF(Max) to 2.3pF(typ) 20-Apr-07 DCN-07P041902 Yachuan Miao A7 2 CL,C0,TS Change 27-Nov-07 ECN-07P112705 Yachuan Miao FMT-DOC024 Issue Date: 03.09'06 VER.D TXC P/N: 7B19200026 REVISION: A7 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.046±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 19.200000 MAX Notes UNITS MHz - - Fundamental - - CL 8.8 pF - 4 Frequency Tolerance - ±10 ppm at 25 ℃ ± 3 ℃ 5 Frequency Tolerance - ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance 8 Drive Level DL ±10 -20 ~ 75 ±2 - ppm 100 - - ℃ 1st Year uW - 9 Effective Resistance Rr Rr - - 25 Ω - 10 Shunt Capacitance C0 C0 - 1.85 - pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ - ppm - - ppm/pF - 13 Frequency Perturbation 14 Pullability FMT-DOC024 TS ±1 - 30 at DC 100V Issue Date: 03.09'06 VER.D 7B19200026 TXC P/N: REVISION: ■ DIMENSIONS A7 PAGE: 3 Unit:mm 0.9 ± 0.15 3.2 0.15 5 0.15 ■ MARKING   TXC □□□□ TXC Logo Pin 1 Location ■ Frequency Code ex:14.318180 MHz=14.3 □□□□ Lot Code Date Code Line Code Production location: China or Taiwan MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location: China or Taiwan ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. (℃) 10 sec 260 Solder melting point :220 ℃ 220 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Date: 03.09'06 VER.D TXC P/N: 7B19200026 REVISION: A7 PAGE: 4 ■ STRUCTURE ILLUSTRATION 5 4 6 1 2 3 NO COMPONENTS MATERIALS QTY 1 FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu 1 Color black 3 PAD Au Tungsten metalize 4 - + Ni plating + Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 4 Silicon resin 6 Electrode Noble Metal 2 - FMT-DOC024 Issue Date: 03.09'06 VER.D TXC P/N: 7B19200026 REVISION: A7 PAGE: 5 ■ PACKING : (EIA-481-2) F G E B H INDEX MARK C A DIMENSIONS D Feeding A B C D E F G H 1.40 5.40 3.60 8.00 12.00 4.00 1.55 1.75 (UNIT : mm) REMARK : Empty Sealed Parts Trailer 160mm(Min) 160mm(Min) Leader 230mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L L1 W W1 pcs / Reel (UNIT : mm) 180 13 16.5 12 Standard Reel Quantity is 1,000 pcs per reel Issue Date: 03.09'06 VER.D TXC P/N: 7B19200026 REVISION: A7 PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test REF.DOC Test Methods JIS C6701 75 cm height,3 times on concrete floor . 1.2 Mechanical Shock 1.3 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours MIL-STD-202F MIL-STD-883E (Total test time 12 hours) 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm 2 1.5 Fine Leak Helium Bombing 4.5 Kgf / cm2 for 2 hr 1.6 Solderability MIL-STD-883E Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 hours 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 hours REF. DOC MIL-STD-202F MIL-STD-883E Total 100 cycles of the following temperature cycle 1 cycle 125 ± 3 ℃ 2.4 Thermal Shock MIL-STD-883E 25 ℃ -55 ± 3 ℃ 10 min. 10 min. 10 min. max. 2.5 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000Hrs JIS C5023 2.6 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 FMT-DOC024 Issue Date: 03.09'06 VER.D
7B19200026 价格&库存
很抱歉,暂时无法提供与“7B19200026”相匹配的价格&库存,您可以联系我们找货
