SMD Multilayer Ferrite Chip Inductors - BSCY Series
BSCY Series
The SMD multi-layered ferrite chip inductors provide a cost-effective
solution for densely packed PC board designs. BSCY series comes in 3
sizes and is suitable for low frequency applications.
Features
Applications
RoHS compliant
High mounting density of compact circuit due to crosstalk
elimination that results from a closed magnetic flux in a ferrite
material
Suitable for flow and re-flow soldering
Available in 3 sizes
Personal computers, HDDs, other various electronic devices
Any portable device where compact size and high mounting
densities are required
Product Identification
Shape and Dimensions
Recommended Pattern
B
Ferrite
Terminal
Electrode
D
D
C
A
C
A
B
Dimensions in mm
Dimensions in mm
TYPE
A
B
C
D
TYPE
A
B
C
BSCY00160808
1.60.2
0.800.2
0.800.2
0.30.2
BSCL00160808
0.7 ~ 0.8
1.8 ~ 2.0
0.6 ~ 0.8
BSCY00201209
2.00.2
1.250.2
0.900.2
0.50.3
BSCL00201209
1.0 ~ 1.2
2.6 ~ 4.0
1.0 ~ 1.4
BSCY00201212
2.00.2
1.250.2
1.250.2
0.50.3
BSCL00201212
1.0 ~ 1.2
2.6 ~ 4.0
1.0 ~ 1.2
SMD Multilayer Ferrite Chip Inductors – BSCY Series
Electrical Characteristics
Part Number
Inductance
(H)
Tolerance
Test
Frequency
(MHz)
RDC
(Ω) Max
Rated Current
(mA) Max
BSCY001608082R2CP
2.2
30 / 20
1
0.20
1000
BSCY001608084R7CP
4.7
30 / 20
1
0.25
800
BSCY00160808100CP
10
30 / 20
1
0.90
90
Note: When ordering, please specify tolerance code. Tolerance : M=±20% , T=±30%
Operating temperature range-40℃~105℃(Including self - temperature rise)
Rated Current:Applied the current to coils, the temperature rise shall not be more than 30℃
Measure Equipment:
L & Q:HP4291A
SRF:Agilent HP8753D/Agilent E4991A
RDC:HP4338B or CHEN HWA 502
Test Instruments:Agilent E4991A Impedance / Material Analyzer
Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these
specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or
high risk applications without Chilisin approval. Please contact our sales department before ordering.
Part Number
Inductance
(H)
Tolerance
Test
Frequency
(MHz)
RDC
(Ω) Max
Rated Current
(mA) Max
BSCY002012092R2CP
2.2
30 / 20
1
0.10
2000
BSCY002012094R7CP
4.7
30 / 20
1
0.30
900
Measure Equipment:
L & Q:HP4291A
Part Number
Inductance
(H)
Tolerance
Test
Frequency
(MHz)
RDC
(Ω) Max
Rated Current
(mA) Max
BSCY00201212100CP
10
30 / 20
1
0.50
400
Measure Equipment:
L & Q:HP4291A
Packaging Specifications
Tape Dimensions
Tape Material
Reel Dimensions
Dimensions in mm
Tape Dimensions
Reel Dimensions
Quantity
TYPE
A
B
T
W
P
F
K
Tape
A
B
C
D
PCS / Reel
BSCY00160808
1.05
1.85
0.95
8.0
4.0
3.5
B
178
60
12
1.5
4000
BSCY00201209
1.50
2.30
0.97
8.0
4.0
3.5
B
178
60
12
1.5
4000
BSCY00201212
1.35
2.25
0.22
8.0
4.0
3.5
1.35
A
178
60
12
1.5
3000
很抱歉,暂时无法提供与“BSCY001608084R7MCP”相匹配的价格&库存,您可以联系我们找货
