BSCY001608082R2MCP
BSCY001608082R2MCP
    CHILISIN(奇力新)
    功率电感 2.2µH ±20% 200mΩ 0603
BSCY001608082R2MCP 数据手册
SMD Multilayer Ferrite Chip Inductors - BSCY Series BSCY Series The SMD multi-layered ferrite chip inductors provide a cost-effective solution for densely packed PC board designs. BSCY series comes in 3 sizes and is suitable for low frequency applications. Features Applications  RoHS compliant  High mounting density of compact circuit due to crosstalk elimination that results from a closed magnetic flux in a ferrite material  Suitable for flow and re-flow soldering  Available in 3 sizes  Personal computers, HDDs, other various electronic devices  Any portable device where compact size and high mounting densities are required Product Identification Shape and Dimensions Recommended Pattern B Ferrite Terminal Electrode D D C A C A B Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C BSCY00160808 1.60.2 0.800.2 0.800.2 0.30.2 BSCL00160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 BSCY00201209 2.00.2 1.250.2 0.900.2 0.50.3 BSCL00201209 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.4 BSCY00201212 2.00.2 1.250.2 1.250.2 0.50.3 BSCL00201212 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 SMD Multilayer Ferrite Chip Inductors – BSCY Series Electrical Characteristics Part Number Inductance (H) Tolerance (±%) Test Frequency (MHz) RDC (Ω) Max Rated Current (mA) Max BSCY001608082R2CP 2.2 30 / 20 1 0.20 1000 BSCY001608084R7CP 4.7 30 / 20 1 0.25 800 BSCY00160808100CP 10 30 / 20 1 0.90 90 Note: When ordering, please specify tolerance code. Tolerance : M=±20% , T=±30%  Operating temperature range-40℃~105℃(Including self - temperature rise)  Rated Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCY Series Electrical Characteristics Part Number Inductance (H) Tolerance (±%) Test Frequency (MHz) RDC (Ω) Max Rated Current (mA) Max BSCY002012092R2CP 2.2 30 / 20 1 0.10 2000 BSCY002012094R7CP 4.7 30 / 20 1 0.30 900 Note: When ordering, please specify tolerance code. Tolerance : M=±20% , T=±30%  Operating temperature range-40℃~105℃(Including self - temperature rise)  Rated Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – BSCY Series Electrical Characteristics Part Number Inductance (H) Tolerance (±%) Test Frequency (MHz) RDC (Ω) Max Rated Current (mA) Max BSCY00201212100CP 10 30 / 20 1 0.50 400 Note: When ordering, please specify tolerance code. Tolerance : M=±20% , T=±30%  Operating temperature range-40℃~105℃(Including self - temperature rise)  Rated Current:Applied the current to coils, the temperature rise shall not be more than 30℃  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Test Instruments:Agilent E4991A Impedance / Material Analyzer Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors - BSCY Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K Tape A B C D PCS / Reel BSCY00160808 1.05 1.85 0.95 8.0 4.0 3.5 - B 178 60 12 1.5 4000 BSCY00201209 1.50 2.30 0.97 8.0 4.0 3.5 - B 178 60 12 1.5 4000 BSCY00201212 1.35 2.25 0.22 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000
BSCY001608082R2MCP 价格&库存
很抱歉,暂时无法提供与“BSCY001608082R2MCP”相匹配的价格&库存,您可以联系我们找货
