OZETGLJANF-0.032768MHz
    TAITIEN(泰艺)
    SMD2016_4P
    有源晶振 15pF ±50ppm 2.8V/3.0V/3.3V SMD2016_4P 32.768KHz
OZETGLJANF-0.032768MHz 数据手册
Low Current Consumption 32.768kHz OZ-I Type 2.0 x 1.6 mm SMD Crystal Oscillator Actual Size FEATURE - Low Power Supply Voltage: 3.3, 2.5, 1.8V Supply Options - Singled-end Output: CMOS - Frequency: 32.768kHz - Low Current Consumption: 18µA Max - Temperature Range: -40oC to 85oC Operation - Pb-free/RoHS Compliant RoHS Compliant TYPICAL APPLICATION - RTC Module - Smartphone - IoT - Wearable Device – Watch, Medical DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ B O T T O M V IE W ] [ TO P VIEW ] 0.1 μF 1.27±0.10 #4 #2 #2 0.47±0.10 1.65±0.10 #1 #1 0.97 #3 #3 0.97±0.10 #4 0.60 2.05±0.10 0.57±0.10 0.75±0.10 [ S ID E V IE W ] 1.27 Pin# 1 2 3 4 Function Tri-state GND Output VDD 0.75 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3V Parameter Supply Voltage Variation (VDD) 2.5V 1.8V Min. Max. Min. Max. Min. Max. VDD-10% VDD+10% VDD-5% VDD+5% VDD-5% VDD+5% Frequency Range 32.768 Supply Current (No Load) Output Level Transition Time (10%90%) Unit V kHz - 18 - 18 - 18 uA Output High 2.97 - 2.25 - 2.25 - V Output Low - 0.33 - 0.25 - 0.25 V Rise Time / Fall Time - 15.0 - 15.0 - 15.0 nSec 45 55 45 55 45 55 % - 20 - 20 - 20 mSec Duty Cycle Startup Time Tri-State Mode Enable 0.7 x VDD - 0.7 x VDD - 0.7 x VDD - (Input to Pin 2) Disable - 0.3 x VDD - 0.3 x VDD - 0.3 x VDD V Stand by Current - 3 - 3 - 3 Output Loading (CMOS) - 15 - 15 - 15 pF Aging (@ 25oC, 1st Year) - ±3 - ±3 - ±3 ppm -55 +125 -55 +125 -55 +125 Storage Temp. Range uA o C FREQ. STABILITY vs. TEMP. RANGE ppm Temp.( oC) -10~+60 -20~+70 -40~+85 ±20 25 50 *O: Available △: Conditional X: Not available *Inclusive of calibration @ 25 oC ,operating temperature rrange,input Voltage variation,load variation,aging (1st year),shock,and vibration Note: not all combination of options are available. Other specifications may be available upon request. 26 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(1)01/2020
OZETGLJANF-0.032768MHz 价格&库存
很抱歉,暂时无法提供与“OZETGLJANF-0.032768MHz”相匹配的价格&库存,您可以联系我们找货
