OYETELJANF-0.032768MHz
    TAITIEN(泰艺)
    SMD2520_4P
    有源晶振 15pF ±30ppm 2.8V/3.0V/3.3V SMD2520_4P 32.768KHz
OYETELJANF-0.032768MHz 数据手册
32.768kHz Series OX / OY Type 3.2 x 2.5 / 2.5 x 2.0 mm SMD Oscillator Actual Size Actual Size FEATURE - Tight symmetry (45 to 55%) available. - Operation voltage: 1.8V, 2.5V, 3.3V - Tri-state enable/disable - Built-in ASIC enables reduction of current consumption. TYPICAL APPLICATION - Typically used for real time clock application. - Mobile Phone - DSC,Set-top Box ,HDTV - Car navigation systems. RoHS Compliant DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ TO P VIEW ] 2.10 ± 0.15 1.65 ± 0.15 #2 #2 0.35 0.95 ± 0.15 Pin# 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. 0.1 μF [ B O T T O M V IE W ] 1.625 ± 0.10 #2 #2 #1 0.675 ± 0.10 0.81 ± 0.15 Pin# 1 2 3 4 1.225 #4 0.80 #3 0.57 ± 0.10 1.225 ± 0.10 #3 2.00 ± 0.20 2.50 ± 0.20 0.29 2.10 Function 1 2 3 4 [ TO P VIEW ] #1 #1 0.90 ± 0.15 [ S ID E V IE W ] [ S ID E V IE W ] 0.65 ± 0.15 #1 #4 1.60 #3 #3 2.50 ± 0.15 #4 1.10 3.20 ± 0.15 #4 0.1 μF [ B O T T O M V IE W ] 1.625 0.675 Function 0.90 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION Parameter Min. Supply Voltage Variation (VDD) Supply Current (@ 15pF load) (@ no load) Duty Cycle Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Transition Time:Rise/Fall Time+ Start Time Tri-State(Input to Pin 1) Enable (High voltage or floating) Disable (Low voltage or GND) st Aging (@25 C 1 year) 3.3V VDD-10% - 45 2.97 - 2.31 - Max. VDD+10% 120 80 55 - 0.33 50 2 - 0.99 ±3 Min. 2.5V VDD-10% - 45 2.25 - 1.75 - Max. VDD+10% Min. 1.8V VDD-10% 120 80 55 - 0.25 50 2 - 0.75 ±3 Storage Temp. Range -55 125 -55 125 Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position +Transition times are measured between 10% and 90% of VDD,withan output load of 15pF - 45 1.62 - 1.26 Unit Max. VDD+10% V 120 80 55 % - 0.18 50 2 - 0.54 -55 125 V nSec mSec V ±3 ppm ℃ FREQ. STABILITY vs. TEMP. RANGE Temp. (℃ ) ppm ±20 ±25 ±40 - 1 0 ~+ 6 0 -20~+70 -4 0 ~+8 5 -40~+105 -40~+125 ±50 * O: Available △:Conditional X: Not available *Inclusive of calibration @ 25℃, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration load variation Note: not all combination of options are available. Other specifications may be available upon request. 30 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(8) 05/2020
OYETELJANF-0.032768MHz 价格&库存
很抱歉,暂时无法提供与“OYETELJANF-0.032768MHz”相匹配的价格&库存,您可以联系我们找货
