CD02K032768ADE
CD02K032768ADE
    TKD(泰晶)
    DT-38
    无源晶振 12.5pF 30KΩ ±20ppm -20℃~+70℃ 308 32.768KHz
CD02K032768ADE 数据手册
HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 1 of 7 CRYSTAL SPECIFICATION 客户 : 华强聚丰 客户料号 : 泰晶料号 : 产品类别 日期 CD02K032768ADE TF308-32.768-12.5-20 : 2018.12.28 : CUSTOMER’S APPROVAL (PLEASE RETURN A COPY WITH APPOVAL Hubei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 DESIGNER APPROVED 代 伟 伟 何金玲 SALE Department :TEL :0722-3309660 FAX :0722-3309619 QCD Department : TEL :0722-3308231 FAX :0722-3309768 FAE Department : TEL :0755-27328651 FAX :0755-27328001 HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 2 of 7 REV. Description of Revision History A New revision 2018 年 12 月 28 日 Designer Checked By HE JIN LING Dai Wei HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 3 of 7 CRYSTAL SPECIFICATION 1. 2. 3. 4. 5. 6. Description: Tuning Fork Quartz Crystal Nominal Frequency: 32.768KHz Oscillation Mode: Fundamental Cutting Mode: x +2° cut Measurement Instrument: S&A 250B(Calculated FL) Electrical Characteristics: [1]Operation Conditions: Item Symbol MIN. Operating Temperature Range Topt Storage Temperature Range Tstg TYP. MAX. Unit -20 70 ℃ -40 85 ℃ Load Capacitance CL 12.5 pF Drive Level DL 0.1 uW Condition [2]Frequency Stability: Item Symbol MIN. Tolerance dF/Fo -20 Stability Over Temperature dF/F25 Aging dF/F25 TYP. MAX. Unit Condition 20 ppm Refer to Center Frequency@25±3℃ ppm/℃2 -0.034 -5 5 ppm Refer to Operating Temperature Per Year dF/Fo:Frequency Deviation Refer to Center Frequency dF/F25:Frequency Deviation Refer to 25℃ Frequency [3]Electrical Performance: Item Equivalent Series Resistance Symbol MIN. TYP. ESR Shunt Capacitance C0 Insulation Resistance IR 1.8 500 MAX. Unit 30 KΩ 3 pF MΩ Condition @Series @DC 100 Volt 7. Marking:Laser Marking Generally for empty. Refer to with Customer’s requirement. 32.768 HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 4 of 7 8. Outline drawing (unit:mm) 8.1 Attention 8.2 Not recommended reflow furnace welding,If it is to be used, the maximum temperature shall not exceed 230℃. HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 5 of 7 9. Reliability Specification Test Items Test Method and Condition Vibration (1)Vibration Frequency 10 to 55Hz (2)Vibration Amplitude 1.5mm (3) Cycle Time Shock Hermetic seal Solder ability High temperature Low temperature Humidity Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. 1-2min(10-55-10Hz) (4)Direction (5)Duration Requirements X.Y.Z 2h/each direction 3 Times free drop from 75cm height to hard wooden board of thickness more than 30mm Helium leak detector Checked:before the molded crystal uints Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. less than 1 × 10 EXP(–7) mbar.l/sec. Dip the leads of crystal units into the solution (7-10%) of The dipped surface of the leads should be at rosin 3±0.5s,then dip it into the tank 5-10s. least 95% covered with continuous new solder Temperature of solder melted tank is coating 245℃±5℃ 96 hours at +100℃±2℃ After 1-2hours past at room temperature from following Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. 72 hours at -40℃±2℃ Frequency Change:±5ppm Max. After 1-2hours past at room temperature from following test. Resistance Change: 5kohm Max. 96 hours at +40℃±2℃,relative humidity 90-95% After 1-2hours past at room temperature from following Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. After supplying the following temperature cycle Frequency Change:±5ppm Max. (50cycles) Resistance Change: 5kohm Max.x. Temperature cycle salt spray test Lead strength On the basis of GB/T10125-1997 In the lead 2.00 Kg tensile force was applied at the end to keep more than 5 seconds Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. Frequency Change:±5ppm Max. Resistance Change: 5kohm Max. HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 6 of 7 10. Handling Notice for Standard Tuning Fork Crystal (Cylindrical Type) 10.1. Shock resistance It may deteriorate the characteristics or cause of no oscillation if excess physical shock given. Please be careful not to drop. Please use under condition to minimize the shocks as much as possible. Please review the conditions if it is used by auto mounting or after the conditions are changed. 10.2. Heat and humidity resistance in storage Storing the crystal products under higher or lower temperature or high humidity for a long period may deteriorate the characteristics of crystal units. Please store and use the crystal products at the normal temperature and humidity. 10.3. Solder heat resistance Standard type crystal products use Material have a 230℃ melting point. Heating up the package more than 230ºC may deteriorate the characteristics or cause of no oscillation the products. If the crystal products need to be soldered at temperature of more than +230ºC, please study heat-resistance products or SMD products. Please review the condition or consult us about flow solder process. Our soldering condition is under 280ºC within 3sec or 320ºC within 2sec for lead parts use the soldering iron . Please don’t solder the crystal unit (case) directly. It may cause of deteriorate the characteristics. 10.4. Mounting method to PCB When the crystal products need to be lay down please fix to PCB securely. If the crystal is used with mechanical vibration location, please put cushion in between PCB or fix with elasticity glue (Silicon etc) as shown in below figure. Please don’t gluing hermetic seal grass. When the crystal products need to be mounted vertically, gap between crystal units and PCB more than 3mm for 3×8 type , more than 2mm for 2×6 type is recommended. 3×8 : 3mmmin 2×6 : 2mmmin 10.5. Lead process When the lead needs to be cut please maintenance the cutter. When the lead needs to be bent or repaired please be careful not to giving excess pressure at the root of the lead to avoid crack of the hermetic seal glass. Also please be careful not to giving excess pressure at sealing to avoid sealing tightness deteriorate. Leave more than 0.5 mm of lead from the case. 10.6 Ultrasonic cleaning and ultrasonic soldering Soldered by ultrasonic cannot be guaranteed, because crystal may be sympathetic vibrated and may damage.Please study at your side about ultrasonic cleaning. 10.7 Drive level Applying excessive drive level to the crystal units may cause deterioration of characteristics or damage. Less then 1.0μW is recommended to this products. More than 2.0μW cannot be guaranteed. HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 7 of 7 11. Packing Desrciption
CD02K032768ADE
1. 物料型号:文档中提到的产品型号为TF308-32.768-12.5-20,客户料号和泰晶料号未提供。
2. 器件简介:文档描述的产品为调谐叉石英晶体,具有基本振荡模式和x+2°切割模式。
3. 引脚分配:文档中没有提供具体的引脚分配图,但提到了晶体的标记方式,通常为空,具体根据客户要求。
4. 参数特性: - 标称频率:32.768KHz - 工作温度范围:-20℃至70℃ - 存储温度范围:-40℃至85℃ - 负载电容:12.5pF - 驱动电平:0.1μW - 频率稳定性:公差为±20ppm,温度稳定性为-0.034ppm/℃²,老化率为±5ppm/年 - 电气性能:等效串联电阻(ESR)最大为30KQ,并联电容(CO)为1.8pF至3pF,绝缘电阻(IR)最小为500MΩ
5. 功能详解:文档中没有提供详细的功能描述,但提供了电气特性和可靠性规范。
6. 应用信息:文档中没有提供具体的应用信息,但提到了晶体的振荡模式和切割模式,这些信息可以帮助确定其在电子设备中的应用。
7. 封装信息:文档提供了外形图,但未提供具体的封装尺寸和类型。文档还提到了一些注意事项,例如不建议回流焊接,如果必须使用,最高温度不应超过230℃。
8. 可靠性规范:文档中列出了振动、冲击、密封性、焊接能力、高温、低温、湿度、温度循环和盐雾测试等可靠性测试项目及其要求。
9. 处理注意事项:文档提供了关于标准调谐叉晶体(圆柱形)的处理注意事项,包括抗冲击性、存储中的耐热性和湿度、焊接热抗性、PCB安装方法、引线处理、超声波清洗和焊接以及驱动电平。
10. 包装描述:文档描述了内部和外部包装的细节,包括产品合格证、防振垫、ROHS标签和采购单号等信息。
CD02K032768ADE 价格&库存
很抱歉,暂时无法提供与“CD02K032768ADE”相匹配的价格&库存,您可以联系我们找货
