VBMB1615
www.VBsemi.com
N-Channel 60-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
60
RDS(on) ()
ID (A)a
0.010 at VGS = 10 V
70
0.012 at VGS = 4.5 V
55
• 175 °C Junction Temperature
• TrenchFET® Power MOSFET
• Material categorization:
TO-220 FULLPAK
D
G
GDS
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
Parameter
Gate-Source Voltage
Continuous Drain Current (TJ = 175 °C)b
TC = 25 °C
TC = 100 °C
Symbol
Limit
Unit
VGS
± 20
V
70
ID
50a
IDM
200
Continuous Source Current (Diode Conduction)
IS
50
Avalanche Current
IAS
50
EAS
125
Pulsed Drain Current
Single Avalanche Energy (Duty Cycle 1 %)
Maximum Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
mJ
136
PD
TJ, Tstg
Operating Junction and Storage Temperature Range
A
a
W
3b, 8.3b, c
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta
Maximum Junction-to-Case
Symbol
t 10 sec
Steady State
RthJA
RthJC
Typical
15
40
Maximum
18
50
0.85
1.1
Unit
°C/W
Notes:
a. Package limited.
b. Surface mounted on 1" x 1" FR4 board.
c. t 10 s.
1
VBMB1615
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
60
VGS(th)
VDS = VGS, ID = 250 µA
1
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.a
Max.
2
3
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
IDSS
ID(on)
On-State Drain Currentb
1
VDS = 60 V, VGS = 0 V, TJ = 125 °C
50
VDS = 60 V, VGS = 0 V, TJ = 175 °C
250
VDS = 5 V, VGS = 10 V
VGS = 10 V, ID = 20 A
Drain-Source On-State Resistanceb
RDS(on)
± 100
Forward Transconductance
Dynamic
gfs
0.010
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
Gate-Drain Charge
Qgd
c
Turn-On Delay Timec
0.016
VGS = 10 V, ID = 20 A, TJ = 175 °C
0.020
Turn-Off Delay Time
c
Fall Timec
td(off)
0.012
60
S
2650
VGS = 0 V, VDS = 25 V, f = 1 MHz
470
pF
225
47
VDS = 30 V, VGS = 10 V, ID = 50 A
70
10
nC
12
td(on)
tr
Rise Timec
µA
0.012
VGS = 10 V, ID = 20 A, TJ = 125 °C
VDS = 15 V, ID = 20 A
nA
A
60
VGS = 4.5 V, ID = 15 A
b
V
VDD = 30 V, RL = 0.6
ID 50 A, VGEN = 10 V, Rg = 2.5
tf
10
25
35
50
Source-Drain Diode Ratings and Characteristics (TC = 25 °C)
ISM
Pulsed Current
70
ns
A
Diode Forward Voltage
VSD
IF = 20 A, VGS = 0 V
1
1.5
V
Reverse Recovery Time
trr
IF = 20 A, di/dt = 100 A/µs
45
100
ns
Notes:
a. For design aid only; not subject to production testing.
b. Pulse test; pulse width 300 µs, duty cycle 2 %.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VBMB1615
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C unless noted)
100
200
VGS = 10 thru 5 V
80
4V
I D - Drain Current (A)
160
120
80
60
40
TC = 125 °C
25 °C
2 V, 3 V
4
6
8
10
- 55 °C
2
3
4
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
120
5
0.020
TC = - 55 °C
0.016
VGS = 4.5 V
25 °C
80
0.012
125 °C
60
RDS(on) -
g fs - Transconductance (S)
100
40
ID - Drain Current (A)
40
50
VGS = 10 V
0.008
0.004
0.000
80
100
On-Resistance vs. Drain Current
10
4000
3000
V GS - Gate-to-Source Voltage (V)
3500
C - Capacitance (pF)
40
Transconductance
Ciss
2500
2000
1500
1000
Coss
500
Crss
40
50
Capacitance
60
VDS = 30 V
ID = 50 A
8
6
4
2
40
50
Qg - Total Gate Charge (nC)
Gate Charge
3
VBMB1615
www.VBsemi.com
100
2.0
VGS = 10 V
ID = 20 A
I S - Source Current (A)
RDS(on) - On-Resistance (Normalized)
2.5
1.5
1.0
TJ = 150 °C
TJ = 25 °C
10
0.5
0.0
- 50
- 25
50
75 100 125 150 175
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
4
1
0.6
0.9
1.2
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
1.5
VBMB1615
www.VBsemi.com
THERMAL RATINGS
1000
60
Limited by
RDS(on)*
100
50
40
30
100 µs
10
1 ms
10 ms
100 ms
DC
1
TC = 25 °C
Single Pulse
0.1
10
10 µs
50
75
100
125
150
175
TA - Ambient Temperature (°C)
Maximum Drain Current vs. Ambient Temperature
0.01
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
1
Square Wave Pulse Duration (s)
10
100
Normalized Thermal Transient Impedance, Junction-to-Case
5
VBMB1615
www.VBsemi.com
TO-220 FULLPAK (HIGH VOLTAGE)
E
A
A1
ØP
n
d1
d3
D
u
L1
V
L
b3
A2
b2
c
b
e
DIM.
A
A1
A2
b
b2
b3
c
D
d1
d3
E
e
L
L1
n
ØP
u
v
ECN: X09-0126-Rev. B, 26-Oct-09
DWG: 5972
MIN.
4.570
2.570
2.510
0.622
1.229
1.229
0.440
8.650
15.88
12.300
10.360
13.200
3.100
6.050
3.050
2.400
0.400
MILLIMETERS
2.54 BSC
MAX.
4.830
2.830
2.850
0.890
1.400
1.400
0.629
9.800
16.120
12.920
10.630
MIN.
0.180
0.101
0.099
0.024
0.048
0.048
0.017
0.341
0.622
0.484
0.408
13.730
3.500
6.150
3.450
2.500
0.500
0.520
0.122
0.238
0.120
0.094
0.016
Notes
1. To be used only for process drawing.
2. These dimensions apply to all TO-220, FULLPAK leadframe versions 3 leads.
3. All critical dimensions should C meet Cpk > 1.33.
4. All dimensions include burrs and plating thickness.
5. No chipping or package damage.
6
INCHES
0.100 BSC
MAX.
0.190
0.111
0.112
0.035
0.055
0.055
0.025
0.386
0.635
0.509
0.419
0.541
0.138
0.242
0.136
0.098
0.020
VBMB1615
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
