VBL1615
VBL1615
    VBSEMI(微碧)
    TO-263(D²Pak)
    MOS管 N-Channel VDS=60V VGS=±20V ID=75A RDS(ON)=11mΩ@10V TO263
VBL1615 数据手册
VBL1615 www.VBsemi.com N-Channel 60-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS 60 RDS(on) VGS = 10 V 11 V mΩ RDS(on) VGS = 4.5 V 12 mΩ ID 75 • 175 °C Junction Temperature • TrenchFET® Power MOSFET A Single Configuration D D2PAK (TO-263) G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) Parameter Gate-Source Voltage Continuous Drain Current (TJ = 175 °C)b TC = 25 °C TC = 100 °C Symbol Limit Unit VGS ± 20 V 75 ID 50a IDM Pulsed Drain Current 200 Continuous Source Current (Diode Conduction) IS 50 Avalanche Current IAS 50 EAS 125 Single Avalanche Energy (Duty Cycle  1 %) Maximum Power Dissipation L = 0.1 mH TC = 25 °C TA = 25 °C mJ 136 PD W 3b, 8.3b, c TJ, Tstg Operating Junction and Storage Temperature Range A a - 55 to 175 °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambienta Maximum Junction-to-Case Symbol t  10 sec Steady State RthJA RthJC Typical Maximum 15 18 40 50 0.85 1.1 Unit °C/W Notes: a. Package limited. b. Surface mounted on 1" x 1" FR4 board. c. t  10 s. 1 VBL1615 www.VBsemi.com SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min. Typ.a Max. Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current On-State Drain Currentb Drain-Source On-State Resistanceb VDS VGS = 0 V, ID = 250 µA 60 VGS(th) VDS = VGS, ID = 250 µA 1 IGSS VDS = 0 V, VGS = ± 20 V ± 100 VDS = 60 V, VGS = 0 V 1 IDSS ID(on) RDS(on) VDS = 60 V, VGS = 0 V, TJ = 125 °C 50 VDS = 60 V, VGS = 0 V, TJ = 175 °C 250 VDS =5 V, VGS = 10 V gfs Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Chargec Qg Gate-Source Gate-Drain Chargec Chargec Turn-On Delay Timec Rise Timec Turn-Off Delay Timec Fall Timec Qgs VGS = 10 V, ID = 20 A 0.011 0.016 VGS = 10 V, ID = 20 A, TJ = 175 °C 0.020 0.012 60 S pF 470 225 47 VDS = 30 V, VGS = 10 V, ID = 50 A nC 10 12 td(on) td(off)  4300 VGS = 0 V, VDS = 25 V, f = 1 MHz Qgd tr µA A VGS = 10 V, ID = 20 A, TJ = 125 °C VDS = 15 V, ID = 20 A nA 60 VGS = 4.5 V, ID = 15 A Forward Transconductanceb Dynamic V 3 VDD = 30 V, RL = 0.6  ID  50 A, VGEN = 10 V, Rg = 2.5  tf 10 20 15 25 35 50 20 30 ns Source-Drain Diode Ratings and Characteristics (TC = 25 °C) A Pulsed Current ISM Diode Forward Voltage VSD IF = 20 A, VGS = 0 V 1 1.5 V Reverse Recovery Time trr IF = 20 A, di/dt = 100 A/µs 45 100 ns 60 Notes: a. For design aid only; not subject to production testing. b. Pulse test; pulse width  300 µs, duty cycle  2 %. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 VBL1615 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C unless noted) 100 200 VGS = 10 thru 5 V 80 4V I D - Drain Current (A) I D - Drain Current (A) 160 120 80 60 40 TC = 125 °C 20 40 25 °C 2 V, 3 V 0 0 0 2 4 6 8 10 - 55 °C 0 1 2 3 4 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 120 5 0.015 TC = - 55 °C 0.012 25 °C VGS = 10 V 80 0.009 125 °C 60 0.006 R DS(on) - g fs - Transconductance (S) 100 40 0.003 20 0 0 10 20 30 I D - Drain Current (A) 40 50 0.000 0 45 85 40 50 RDS(on) vs. Drain Current 10 4000 3000 VGS - Gate-to-Source Voltage (V) 3500 C - Capacitance (pF) 75 65 ID - Drain Current (A) Transconductance Ciss 2500 2000 1500 1000 Coss 500 0 55 Crss 0 10 20 30 40 50 VDS - Drain-to-Source Voltage (V) Capacitance 60 VDS = 30 V ID = 50 A 8 6 4 2 0 0 10 20 30 Qg - Total Gate Charge (nC) Gate Charge 3 VBL1615 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C unless noted) 100 2.0 VGS = 10 V ID = 20 A I S - Source Current (A) RDS(on) - On-Resistance (Normalized) 2.5 1.5 1.0 TJ = 150 °C TJ = 25 °C 10 0.5 0.0 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 175 1 0 0.3 0.6 0.9 1.2 1.5 VSD - Source-to-Drain Voltage (V) Source-Drain Diode Forward Voltage 4 VBL1615 www.VBsemi.com THERMAL RATINGS 1000 60 Limited by RDS(on)* 100 I D - Drain Current (A) I D - Drain Current (A) 50 40 30 20 10 1 ms 10 ms 100 ms DC 1 TC = 25 °C Single Pulse 0.1 10 0 10 µs 100 µs 0 25 50 75 100 125 TA - Ambient Temperature (°C) 150 175 0.01 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum V GS at which R DS(on) is specified Maximum Drain Current vs. Ambient Temperature Safe Operating Area 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10- 4 10- 3 10- 2 10- 1 1 Square Wave Pulse Duration (s) 10 100 Normalized Thermal Transient Impedance, Junction-to-Case 5 VBL1615 www.VBsemi.com TO-263AB (HIGH VOLTAGE) A (Datum A) 3 4 L1 A 4 E A B c2 H Gauge plane 4 0° to 8° D 1 L2 B 2 C 3 C H 5 B Detail A Seating plane L L3 A1 L4 Detail “A” Rotated 90° CW scale 8:1 B A 2 x b2 c 2xb 0.010 M A M B E ± 0.004 M B 2xe Plating 5 b1, b3 Base metal c1 (c) D1 4 5 (b, b2) Lead tip MILLIMETERS DIM. MIN. 4 E1 Section B - B and C - C Scale: none View A - A INCHES MILLIMETERS MAX. MIN. MAX. DIM. MIN. INCHES MAX. MIN. MAX. A 4.06 4.83 0.160 0.190 D1 6.86 - 0.270 - A1 0.00 0.25 0.000 0.010 E 9.65 10.67 0.380 0.420 6.22 - 0.245 - b 0.51 0.99 0.020 0.039 E1 b1 0.51 0.89 0.020 0.035 e b2 1.14 1.78 0.045 0.070 H 14.61 15.88 0.575 0.625 b3 1.14 1.73 0.045 0.068 L 1.78 2.79 0.070 0.110 2.54 BSC 0.100 BSC c 0.38 0.74 0.015 0.029 L1 - 1.65 - 0.066 c1 0.38 0.58 0.015 0.023 L2 - 1.78 - 0.070 c2 1.14 1.65 0.045 0.065 L3 D 8.38 9.65 0.330 0.380 L4 0.25 BSC 4.78 5.28 0.010 BSC 0.188 0.208 ECN: S-82110-Rev. A, 15-Sep-08 DWG: 5970 Notes 1. Dimensioning and tolerancing per ASME Y14.5M-1994. 2. Dimensions are shown in millimeters (inches). 3. Dimension D and E do not include mold flash. Mold flash shall not exceed 0.127 mm (0.005") per side. These dimensions are measured at the outmost extremes of the plastic body at datum A. 4. Thermal PAD contour optional within dimension E, L1, D1 and E1. 5. Dimension b1 and c1 apply to base metal only. 6. Datum A and B to be determined at datum plane H. 7. Outline conforms to JEDEC outline to TO-263AB. 6 VBL1615 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead 0.420 0.355 0.635 (16.129) (9.017) (10.668) 0.145 (3.683) 0.135 (3.429) 0.200 0.050 (5.080) (1.257) Recommended Minimum Pads Dimensions in Inches/(mm) 7 VBL1615 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability, including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be R oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. 8
VBL1615 价格&库存
很抱歉,暂时无法提供与“VBL1615”相匹配的价格&库存,您可以联系我们找货
