VBC8338
www.VBsemi.com
N- and P-Channel 30-V (D-S) MOSFET
N-CH BVDSS
▼ Simple Drive Requirement
▼ Lower Gate Charge
RDS(ON)
▼ Fast Switching Performance
ID
22mΩ
6.2A
P-CH BVDSS
▼ RoHS Compliant & Halogen-Free
30V
-30V
RDS(ON)
45mΩ
ID
-5.0A
D2
D1
G2
G1
S2
S1
Absolute Maximum Ratings
Symbol
Parameter
Rating
N-channel
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
Units
P-channel
30
-30
V
+20
+20
V
3
6.2
-5.0
A
3
5.0
-4.0
A
A
Continuous Drain Current
1
IDM
Pulsed Drain Current
PD@TA=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
1.35
W
Thermal Data
Symbol
Rthj-a
Parameter
Maximum Thermal Resistance, Junction-ambient
3
Value
Unit
90
℃/W
1
VBC8338
www.VBsemi.com
o
N-CH Electrical Characteristics@Tj=25 C(unless otherwise specified)
Symbol
BVDSS
RDS(ON)
Parameter
Test Conditions
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance
Min.
Typ.
30
V
VGS=10V, ID=6A
22
mΩ
VGS=4.5V, ID=4A
30
mΩ
VGS=0V, ID=250uA
2
Max. Units
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250uA
1
3
V
gfs
Forward Transconductance
VDS=10V, ID=6A
14
S
IDSS
Drain-Source Leakage Current
VDS=24V, VGS=0V
1
uA
IGSS
Gate-Source Leakage
VGS=+20V, VDS=0V
+100
nA
Qg
Total Gate Charge
ID=6A
7
11
nC
Qgs
Gate-Source Charge
VDS=15V
2
nC
Qgd
Gate-Drain ("Miller") Charge
VGS=4.5V
4
nC
td(on)
Turn-on Delay Time
VDS=15V
6
ns
tr
Rise Time
ID=1A
6
ns
td(off)
Turn-off Delay Time
RG=3.3Ω
17
ns
tf
Fall Time
VGS=10V
4
ns
Ciss
Input Capacitance
VGS=0V
550
pF
Coss
Output Capacitance
VDS=15V
105
pF
Crss
Rg
Reverse Transfer Capacitance
f=1.0MHz
90
pF
Gate Resistance
f=1.0MHz
1.7
Ω
Min.
Typ.
Source-Drain Diode
Symbol
2
Parameter
2
Test Conditions
Max. Units
VSD
Forward On Voltage
IS=1.2A, VGS=0V
1.2
V
trr
Reverse Recovery Time
IS=6A, VGS=0V,
15
ns
Qrr
Reverse Recovery Charge
dI/dt=100A/µs
7
nC
VBC8338
www.VBsemi.com
o
P-CH Electrical Characteristics@Tj=25 C(unless otherwise specified)
Symbol
BVDSS
RDS(ON)
Parameter
Test Conditions
Min.
Typ.
-30
V
VGS=-10V, ID=-5A
45
mΩ
VGS=-4.5V, ID=-3A
66
mΩ
VGS=0V, ID=-250uA
2
Max. Units
VGS(th)
VDS=VGS, ID=-250uA
-1
-3
V
gfs
VDS=-10V, ID=-5A
18
S
IDSS
VDS=-24V, VGS=0V
-1
uA
IGSS
Gate-Source Leakage
VGS=+20V, VDS=0V
+100
nA
Qg
Total Gate Charge
ID=-5A
14.4
23
nC
Qgs
Gate-Source Charge
VDS=-15V
5.5
nC
Qgd
VGS=-4.5V
5
nC
td(on)
Turn-on Delay Time
VDS=-15V
7
ns
tr
Rise Time
ID=-1A
6.5
ns
td(off)
Turn-off Delay Time
RG=3.3Ω
36
ns
tf
Fall Time
VGS=-10V
28
ns
Ciss
Input Capacitance
VGS=0V
960
pF
Coss
Output Capacitance
VDS=-15V
190
pF
Crss
Rg
f=1.0MHz
170
pF
Gate Resistance
f=1.0MHz
6
Ω
Min.
Typ.
Source-Drain Diode
Symbol
Parameter
2
Test Conditions
Max. Units
VSD
Forward On Voltage
IS=-1.2A, VGS=0V
-1.2
V
trr
IS=-5A, VGS=0V,
19
ns
Qrr
dI/dt=100A/µs
9
nC
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 copper pad of FR4 board , t
很抱歉,暂时无法提供与“VBC8338”相匹配的价格&库存,您可以联系我们找货
