VBC6P3033
VBC6P3033
    VBSEMI(微碧)
    TSSOP8_3X4.4MM
    MOS管 Dual P-Channel VDS=30V VGS=±20V ID=4.1A RDS(ON)=36mΩ@10V TSSOP8
VBC6P3033 数据手册
VBC6P3033 www.VBsemi.com Dual P-Channel 30-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) - 30 RDS(on) (Ω) ID (A) 0.036 at V GS = - 10 V - 5.2 0.055 at V GS = - 4.5 V - 4.2 • Halogen-free • TrenchFET® Power MOSFETs RoHS COMPLIANT APPLICATIONS • Load Switch • Battery Switch S1 S2 TSSOP-8 D1 1 S1 2 S1 3 G1 4 G1 8 D2 7 S2 G2 6 S2 5 G2 Top View D1 D2 P-Channel MOSFET P-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Parameter Symbol 10 s Steady State Drain-Source Voltage VDS - 30 Gate-Source Voltage VGS ± 20 Continuous Drain Current (TJ = 150 °C)a TA = 25 °C TA = 70 °C Continuous Source Current (Diode Conduction)a IS TA = 25 °C TA = 70 °C PD - 4.1 - 4.2 - 3.6 - 30 - 1.0 - 0.70 1.14 0.83 0.73 0.53 TJ, Tstg Operating Junction and Storage Temperature Range V - 5.2 IDM Pulsed Drain Current (10 µs Pulse Width) Maximum Power Dissipationa ID Unit - 55 to 150 A W °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambienta Maximum Junction-to-Foot Symbol t ≤ 10 s Steady State Steady State RthJA RthJF Typical Maximum 86 110 124 150 52 65 Unit °C/W Notes: a. Surface Mounted on 1" x 1" FR4 board. 1 VBC6P3033 www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. - 1.0 Typ. Max. Unit Static VGS(th) VDS = VGS, ID = - 250 µA Gate-Body Leakage IGSS VDS = 0 V, VGS = ± 20 V Zero Gate Voltage Drain Current IDSS On-State Drain Currenta ID(on) Gate Threshold Voltage Drain-Source On-State Resistancea Diode Forward Voltage a V nA VDS = - 30 V, VGS = 0 V -1 VDS = - 30 V, VGS = 0 V, TJ = 55 °C - 10 VDS ≥ - 5 V, VGS = - 10 V RDS(on) Forward Transconductancea - 3.0 ± 100 µA - 15 A VGS = - 10 V, ID = - 4.7 A 0.036 VGS = - 4.5 V, ID = - 3.8 A 0.055 Ω gfs VDS = - 15 V, ID = - 4.7 A 14 VSD IS = - 1.0 A, VGS = 0 V - 0.74 - 1.1 13 20 S V Dynamicb Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg VDS = - 15 V, VGS = - 4.5 V, ID = - 4.7 A 3 f = 1.0 MHz VDD = - 15 V, RL = 15 Ω ID ≅ - 1 A, VGEN = - 10 V, RG = 6 Ω tr td(off) Turn-Off Delay Time Fall Time tf Source-Drain Reverse Recovery Time trr Ω 4.6 td(on) Turn-On Delay Time Rise Time nC 5.8 IF = - 1.0 A, dI/dt = 100 A/µs 13 20 14 22 52 80 26 40 40 60 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 30 30 TC = - 55 °C VGS = 10 thru 5 V 24 I D - Drain Current (A) I D - Drain Current (A) 25 °C 4V 24 18 12 6 125 °C 18 12 6 3V 0 0 2 1 2 3 4 5 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 4.0 4.5 VBC6P3033 www.VBsemi.com 0.11 2000 0.09 1600 C - Capacitance (pF) RDS(on) - On-Resistance (Ω) TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 0.07 VGS = 4.5 V 0.05 VGS = 10 V 1200 Ciss 800 0.03 400 0.01 0 Coss Crss 0 5 10 15 20 25 30 0 5 10 ID - Drain Current (A) 20 25 30 VDS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current Capacitance 1.60 6 VGS = 10 V ID = 4.7 A VDS = 15 V ID = 4.7 A 5 4 3 2 (Normalized) 1.40 RDS(on) - On-Resistance V GS - Gate-to-Source Voltage (V) 15 1.20 1.00 0.80 1 0.60 - 50 0 0 3 6 9 12 15 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) Qg - Total Gate Charge (nC) Gate Charge On-Resistance vs. Junction Temperature 0.15 30 TJ = 150 °C RDS(on) - On-Resistance (Ω) IS - Source Current (A) 10 TJ = 25 °C 1 0.1 0.0 0.12 ID = 4.7 A 0.09 0.06 0.03 0.00 0.3 0.6 0.9 1.2 VSD - Source-to-Drain Voltage (V) Source-Drain Diode Forward Voltage 1.5 0 2 4 6 8 10 VGS - Gate-to-Source Voltage (V) On-Resistance vs. Gate-to-Source Voltage 3 VBC6P3033 www.VBsemi.com 0.6 100 0.4 80 ID = 250 µA Power (W) V GS(th) Variance (V) TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 0.2 0.0 60 40 20 - 0.2 - 0.4 - 50 - 25 0 25 50 75 100 125 0 0.001 150 0.01 0.1 1 10 TJ - Temperature (°C) Time (s) Threshold Voltage Single Pulse Power, Junction-to-Ambient 100 Limited by R DS (on)* I D - Drain Current (A) 10 1 ms 10 ms 1 100 ms 0.1 0.01 0.1 TC = 25 °C Single Pulse 1s 10 s DC 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area, Junction-to-Case 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 Notes: 0.1 PDM 0.1 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = RthJA = 124 °C/W 0.02 3. TJM - TA = PDMZthJA(t) Single Pulse 4. Surface Mounted 0.01 10 -4 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) 10 Normalized Thermal Transient Impedance, Junction-to-Ambient 4 100 600 VBC6P3033 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10 -3 10 -2 10 -1 1 10 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Foot 5 VBC6P3033 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBC6P3033 价格&库存
很抱歉,暂时无法提供与“VBC6P3033”相匹配的价格&库存,您可以联系我们找货
