2PA1576R,135
2PA1576R,135
    NEXPERIA(安世)
    SOT-323
    通用的开关和放大器
2PA1576R,135 数据手册
2PA1576 PNP general-purpose transistor Rev. 06 — 17 November 2009 Product data sheet 1. Product profile 1.1 General description PNP transistor in a SOT323 (SC-70) plastic package. The NPN complement is 2PC4081. 1.2 Features „ Low current (max. 150 mA) „ Low voltage (max. 50 V) „ Low collector capacitance (typ. 2.5 pF) 1.3 Applications „ General-purpose switching and amplification 2. Pinning information Table 1. Pinning Pin Description 1 base 2 emitter 3 collector Simplified outline Symbol 3 3 1 1 2 2 sym013 3. Ordering information Table 2. Ordering information Type number 2PA1576Q 2PA1576R 2PA1576S Package Name Description Version SC-70 plastic surface mounted package; 3 leads SOT323 2PA1576 Nexperia PNP general-purpose transistor 4. Marking Table 3. Marking codes Type number Marking code[1] 2PA1576Q F*Q 2PA1576R F*R 2PA1576S F*S [1] * = -: made in Hong Kong * = t: made in Malaysia 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Conditions Min Max Unit VCBO Symbol Parameter collector-base voltage open emitter - −60 V VCEO collector-emitter voltage open base - −50 V VEBO emitter-base voltage open collector - −6 V IC collector current (DC) - −150 mA ICM peak collector current - −200 mA IBM peak base current - −200 mA - 200 mW Ptot total power dissipation Tamb ≤ 25 °C [1] Tstg storage temperature −65 +150 °C Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C [1] Transistor mounted on an FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient [1] Conditions Min Typ Max Unit - - 625 K/W Transistor mounted on an FR4 printed-circuit board, single-sided copper, tin-plated and standard footprint. 2PA1576 Product data sheet [1] © Nexperia B.V. 2009. All rights reserved. Rev. 06 — 17 November 2009 2 of 7 2PA1576 Nexperia PNP general-purpose transistor 7. Characteristics Table 6. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions ICBO collector-base cut-off current IE = 0 A; VCB = −30 V IE = 0 A; VCB = −30 V; Tj = 150 °C IEBO emitter-base cut-off current IC = 0 A; VEB = −4 V hFE DC current gain IC = −1 mA; VCE = −6 V Min Typ Max Unit - - −100 nA - - −5 μA - - −100 nA 2PA1576Q 120 - 270 2PA1576R 180 - 390 270 - 560 - - −500 mV 2PA1576S VCEsat collector-emitter saturation voltage IC = −50 mA; IB = −5 mA Cc collector capacitance IE = ie = 0 A; VCB = −12 V; f = 1 MHz - 2.5 3.5 pF fT transition frequency IC = −2 mA; VCE = −12 V; f = 100 MHz 100 - - MHz [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 2PA1576 Product data sheet [1] © Nexperia B.V. 2009. All rights reserved. Rev. 06 — 17 November 2009 3 of 7 2PA1576 Nexperia PNP general-purpose transistor 8. Package outline Plastic surface-mounted package; 3 leads SOT323 D E B A X HE y v M A 3 Q A A1 c 1 2 e1 bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w mm 1.1 0.8 0.1 0.4 0.3 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.23 0.13 0.2 0.2 OUTLINE VERSION REFERENCES IEC JEDEC SOT323 Fig 1. JEITA SC-70 EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 Package outline SOT323 (SC-70) 2PA1576 Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 06 — 17 November 2009 4 of 7 2PA1576 Nexperia PNP general-purpose transistor 9. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes 2PA1576 20091117 Product data sheet - 2PA1576_5 Modifications: • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • Figure 1 “Package outline SOT323 (SC-70)”: updated 2PA1576_5 20041124 Product data sheet - 2PA1576_4 2PA1576_4 19990531 Product specification - 2PA1576_3 2PA1576_3 19970328 Objective specification - 2PA1576_2 2PA1576_2 19931213 n.a. - n.a. 2PA1576 Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 06 — 17 November 2009 5 of 7 2PA1576 Nexperia PNP general-purpose transistor 10. Legal information 10.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 10.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 10.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 10.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 2PA1576 Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 06 — 17 November 2009 6 of 7 2PA1576 Nexperia PNP general-purpose transistor 11. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 8 9 10 10.1 10.2 10.3 10.4 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 1 2 2 2 3 4 5 6 6 6 6 6 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2009. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 November 2009 Document identifier: 2PA1576
2PA1576R,135 价格&库存
很抱歉,暂时无法提供与“2PA1576R,135”相匹配的价格&库存,您可以联系我们找货
2PA1576R,135
    2PA1576R,135
    • 10000+0.2753510000+0.03573
