2PB710ARL; 2PB710ASL
50 V, 500 mA PNP general-purpose transistors
Rev. 01 — 29 October 2008
Product data sheet
1. Product profile
1.1 General description
PNP general-purpose transistors in a small SOT23 (TO-236AB) Surface-Mounted
Device (SMD) plastic package.
Table 1.
Product overview
Type number[1]
2PB710ARL
Package
NPN complement
Nexperia
JEDEC
SOT23
TO-236AB
2PD602ARL
2PB710ASL
2PD602ASL
2PB710ARL/DG
SOT23
TO-236AB
2PD602ARL/DG
2PB710ASL/DG
[1]
2PD602ASL/DG
/DG: halogen-free
1.2 Features
n
n
n
n
General-purpose transistors
Two current gain selections
AEC-Q101 qualified
Small SMD plastic package
1.3 Applications
n General-purpose switching and amplification
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
−50
V
IC
collector current
−500
mA
hFE group R
120
240
hFE group S
170
340
hFE
[1]
DC current gain
Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
VCE = −10 V;
IC = −150 mA
[1]
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
1
base
2
emitter
3
collector
Simplified outline
Graphic symbol
3
3
1
1
2
2
sym013
3. Ordering information
Table 4.
Type number[1]
2PB710ARL
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT23
2PB710ASL
2PB710ARL/DG
2PB710ASL/DG
[1]
/DG: halogen-free
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
2PB710ARL
SE*
2PB710ASL
SD*
2PB710ARL/DG
SU*
2PB710ASL/DG
ST*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
2PB710AXL_1
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 9
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
−60
V
VCEO
open base
−50
V
VEBO
emitter-base voltage
open collector
−5
V
IC
collector current
−500
mA
ICM
peak collector current
single pulse;
tp ≤ 1 ms
−1
A
IBM
peak base current
single pulse;
tp ≤ 1 ms
−200
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
250
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
6. Thermal characteristics
Table 7.
Symbol
Parameter
Rth(j-a)
[1]
Conditions
thermal resistance from junction in free air
to ambient
[1]
Min
Typ
Max
Unit
500
K/W
Typ
Max
Unit
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
ICBO
collector-base cut-off
current
IEBO
hFE
VCEsat
Conditions
VCB = −60 V; IE = 0 A
−10
nA
VCB = −60 V; IE = 0 A;
Tj = 150 °C
−5
µA
nA
emitter-base cut-off current VEB = −5 V; IC = 0 A
−10
40
DC current gain
VCE = −10 V;
IC = −500 mA
[1]
hFE group R
VCE = −10 V;
IC = −150 mA
[1]
120
240
hFE group S
VCE = −10 V;
IC = −150 mA
[1]
170
340
IC = −300 mA;
IB = −30 mA
[1]
−600
collector-emitter saturation
voltage
2PB710AXL_1
Product data sheet
Min
mV
3 of 9
Nexperia
Table 8.
Characteristics …continued
Symbol
Parameter
Conditions
VBEsat
base-emitter saturation
voltage
IC = −300 mA;
IB = −30 mA
fT
transition frequency
VCE = −10 V;
IC = −50 mA;
f = 100 MHz
[1]
hFE group R
hFE group S
collector capacitance
Cc
[1]
VCB = −10 V;
IE = ie = 0 A;
f = 1 MHz
Min
Typ
Max
Unit
−1.5
V
120
MHz
140
MHz
15
pF
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
Dimensions in mm
Fig 1.
0.15
0.09
04-11-04
Package outline SOT23 (TO-236AB)
2PB710AXL_1
Product data sheet
0.48
0.38
4 of 9
Nexperia
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number[2]
2PB710ARL
Package
Description
SOT23
Packing quantity
4 mm pitch, 8 mm tape and reel
3000
10000
-215
-235
2PB710ASL
2PB710ARL/DG
2PB710ASL/DG
[1]
For further information and the availability of packing methods, see Section 14.
[2]
/DG: halogen-free
11. Soldering
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
Fig 2.
Reflow soldering footprint SOT23 (TO-236AB)
2PB710AXL_1
Product data sheet
sot023_fr
5 of 9
Nexperia
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
Fig 3.
Wave soldering footprint SOT23 (TO-236AB)
2PB710AXL_1
Product data sheet
sot023_fw
6 of 9
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
2PB710AXL_1
20081029
Product data sheet
2PB710AXL_1
Product data sheet
7 of 9
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
2PB710AXL_1
Product data sheet
8 of 9
Nexperia
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description. . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Quick reference data. . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics. . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Test information . . . . . . . . . . . . . . . . . . . . . . . . .
Quality information . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Packing information. . . . . . . . . . . . . . . . . . . . . .
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Contact information. . . . . . . . . . . . . . . . . . . . . .
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Date of release: 29 October 2008
1
1
1
1
1
2
2
2
3
3
3
4
4
4
5
5
7
8
8
8
8
8
8
9
很抱歉,暂时无法提供与“2PB710ASL,235”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.3854610000+0.05002
- 20000+0.3497020000+0.04538
- 30000+0.3314730000+0.04301
- 50000+0.3109850000+0.04035
- 70000+0.2988370000+0.03878
- 100000+0.28704100000+0.03725
- 国内价格
- 1000+0.48137
- 10000+0.40115
- 100000+0.40115
- 国内价格 香港价格
- 1+2.296141+0.29793
- 10+1.3958410+0.18111
- 100+0.86549100+0.11230
- 500+0.63446500+0.08232
- 1000+0.559661000+0.07262
- 2000+0.496512000+0.06443
- 5000+0.427935000+0.05553
