2PD601ARW,115
2PD601ARW,115
    NEXPERIA(安世)
    SOT-323
    通用三极管 NPN Ic=100mA Vceo=50V hfe=210~340 P=200mW SOT323
2PD601ARW,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET 2PD601A series NPN general purpose transistors; 50 V, 100 mA Product data sheet Supersedes data of 2002 Jun 26 2004 Feb 12 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA FEATURES 2PD601A series QUICK REFERENCE DATA • Available in SOT323 (SC-70) and SOT346 (SC-59) packages SYMBOL • Available in three different DC current gain versions (Q, R, S). APPLICATIONS PARAMETER MIN. MAX. UNIT VCEO collector-emitter voltage − 50 V IC collector current (DC) − 100 mA hFE DC current gain group Q 160 260 group R 210 340 group S 290 460 • General purpose switching and amplification. DESCRIPTION NPN general purpose transistors (see “Simplified outline, symbol and pinning” for package details). PRODUCT OVERVIEW PACKAGE TYPE NUMBER MARKING CODE hFE GROUP SC-59 ZQ Q SOT346 SC-59 ZR R SOT346 SC-59 ZS S 2PD601AQW SOT323 SC-70 *6D Q 2PD601ARW SOT323 SC-70 *6E R 2PD601ASW SOT323 SC-70 *6F S PHILIPS EIAJ 2PD601AQ SOT346 2PD601AR 2PD601AS Note 1. * = p: Made in Hong Kong. * = t: Made in Malaysia. * = W: Made in China. SIMPLIFIED OUTLINE, SYMBOL AND PINNING PINNING TYPE NUMBER SIMPLIFIED OUTLINE AND SYMBOL PIN DESCRIPTION 2PD601AQ 1 base 2PD601AR 2 emitter 3 collector handbook, halfpage 3 2PD601AS 3 2PD601AQW 1 2PD601ARW 2PD601ASW 1 2 2 Top view 2004 Feb 12 MAM321 2 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA 2PD601A series ORDERING INFORMATION PACKAGE TYPE NUMBER NAME 2PD601AQ DESCRIPTION VERSION − plastic surface mounted package; 3 leads SOT346 − plastic surface mounted package; 3 leads SOT323 2PD601AR 2PD601AS 2PD601AQW 2PD601ARW 2PD601ASW LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VCBO collector-base voltage open emitter − 60 V VCEO collector-emitter voltage open base − 50 V VEBO emitter-base voltage open collector − 6 V IC collector current (DC) − 100 mA ICM peak collector current − 200 mA Ptot total power dissipation SOT346 − 250 mW SOT323 Tamb ≤ 25 °C; note 1 − 200 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C Tamb operating ambient temperature −65 +150 °C Note 1. Refer to SOT346 (SC-59) and SOT323 (SC-70) standard mounting conditions. THERMAL CHARACTERISTICS SYMBOL Rth(j-a) PARAMETER CONDITIONS VALUE UNIT SOT346 500 K/W SOT323 625 K/W thermal resistance from junction to ambient note 1 Note 1. Refer to SOT346 (SC-59) and SOT323 (SC-70) standard mounting conditions. Soldering Reflow soldering is the only recommended soldering method. 2004 Feb 12 3 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA 2PD601A series CHARACTERISTICS Tamb = 25 °C unless otherwise specified. SYMBOL ICBO PARAMETER collector-base cut-off current CONDITIONS MIN. MAX. UNIT IE = 0; VCB = 60 V − 10 nA IE = 0; VCB = 60 V; Tj = 150 °C − 5 μA nA IEBO emitter-base cut-off current IC = 0; VEB = 5 V − 10 hFE DC current gain IC = 100 mA; VCE = 2 V; note 1 90 − hFE DC current gain IC = 2 mA; VCE = 10 V group Q 160 260 group R 210 340 group S 290 460 VCEsat collector-emitter saturation voltage IC = 100 mA; IB = 10 mA; note 1 − 250 mV Cc collector capacitance IE = ie = 0; VCB = 10 V; f = 1 MHz − 3 pF fT transition frequency IC = 2 mA; VCE = 10 V; f = 100 MHz 100 − MHz Note 1. Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 2004 Feb 12 4 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA 2PD601A series PACKAGE OUTLINES Plastic surface-mounted package; 3 leads SOT346 E D A B X HE v M A 3 Q A A1 1 c 2 e1 bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e e1 HE Lp Q v w mm 1.3 1.0 0.1 0.013 0.50 0.35 0.26 0.10 3.1 2.7 1.7 1.3 1.9 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 OUTLINE VERSION SOT346 2004 Feb 12 REFERENCES IEC JEDEC JEITA TO-236 SC-59A 5 EUROPEAN PROJECTION ISSUE DATE 04-11-11 06-03-16 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA 2PD601A series Plastic surface-mounted package; 3 leads SOT323 D E B A X HE y v M A 3 Q A A1 c 1 2 e1 bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w mm 1.1 0.8 0.1 0.4 0.3 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.23 0.13 0.2 0.2 OUTLINE VERSION SOT323 2004 Feb 12 REFERENCES IEC JEDEC JEITA SC-70 6 EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 NXP Semiconductors Product data sheet NPN general purpose transistors; 50 V, 100 mA 2PD601A series DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. DISCLAIMERS operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and 2004 Feb 12 7 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R75/06/pp8 Date of release: 2004 Feb 12 Document order number: 9397 750 12172
2PD601ARW,115 价格&库存
很抱歉,暂时无法提供与“2PD601ARW,115”相匹配的价格&库存,您可以联系我们找货
