379-020-544-107
379-020-544-107
    插件,P=3.81mm
    3.81MM P数:20
379-020-544-107 数据手册
Mounting Option 02-.128 (3.25) Dia. Mounting Holes Contact Detail 521-P.C. Tail .025 Sq.(0.64 Sq.) - Tail LG=.150(3.81) .150 [3.81] Contact Spacing x .200 [5.08] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .375 9.53 Card Slot Accepts .054 [1.37] to .070 (1.78) Thick P.C. Board .150 3.81 1.040 26.42 1.200 30.48 .330 8.38 Card Slot 1.510 38.35 .350 8.89 .600 15.24 SECTION A-A A .160 4.06 Point of Contact A 379 Series Card Edge Connector Part Number: 379-006-521-102 See Accompanying Page for: • Bend Detail • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 379 Assembly 379 ENG MASTER DATE: OCT. 14/09 DATE: SHEET 1 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .120 3.05 .095 2.41 .245 6.22 1 .165 4.19 .170 4.32 .375 9.53 .125 [3.18] to .210 [5.33] Outside Tails .125 [3.18] to .185 [4.70] Outside Tails .045 [1.14] to .060 [1.52] Between Tails .045 [1.14] to .060 [1.52] Between Tails 555 Contact Code ORIGINAL 556 Contact Code .125 [3.18] to .210 [5.33] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 560 Contact Code 379 Series Card Edge Connector Contact Bend Detail EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 379 Assembly 379 ENG MASTER DATE: OCT. 14/09 DATE: SHEET 2 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .010 [0.25] Radial Float ORIGINAL 1 .116 2.95 I.D. Floating Eyelets .128 [3.25] x .146 [3.71] Slot .156 [3.96] Dia Through Holes M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert .250 6.35 Dia. .005 .13 .348 8.84 Code x01 Code x02 Code x03 Code x04 Code x07 Code x08 379 Series Card Edge Connector Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 379 Assembly 379 ENG MASTER DATE: OCT. 14/09 DATE: SHEET 3 OF 3 ISSUE 1
379-020-544-107
1. 物料型号:379-006-521-102 2. 器件简介:文档中没有提供详细的器件简介,但提到了该连接器是卡边连接器,通常用于电子设备中作为数据传输和电源连接。 3. 引脚分配:文档中提到了接触细节,如接触点间距、行间距等,但没有提供具体的引脚分配图或列表。 4. 参数特性:文档中提到了一些尺寸参数,如安装孔直径、卡槽接受的PCB厚度等,但没有提供完整的参数特性表。 5. 功能详解:文档中没有提供功能详解,但提到了连接器的一些设计细节,如浮动眼圈、通孔等。 6. 应用信息:文档中没有明确提供应用信息,但根据连接器的描述,可以推断它可能用于需要数据传输和电源连接的电子设备。 7. 封装信息:文档中提供了一些关于封装的尺寸信息,如安装孔直径、卡槽尺寸等。
379-020-544-107 价格&库存
很抱歉,暂时无法提供与“379-020-544-107”相匹配的价格&库存,您可以联系我们找货
