Mounting Option
02-.128 (3.25) Dia. Mounting Holes
Contact Detail
521-P.C. Tail .025 Sq.(0.64 Sq.) - Tail LG=.150(3.81)
.150 [3.81] Contact Spacing x .200 [5.08] Row Spacing
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
.375 9.53
Card Slot Accepts .054 [1.37]
to .070 (1.78) Thick P.C. Board
.150 3.81
1.040 26.42
1.200 30.48
.330 8.38
Card Slot
1.510 38.35
.350 8.89
.600 15.24
SECTION A-A
A
.160 4.06
Point of Contact
A
379 Series Card Edge Connector
Part Number: 379-006-521-102
See Accompanying Page for:
Bend Detail
Mounting Options
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
379 Assembly
379 ENG MASTER
DATE: OCT. 14/09
DATE:
SHEET 1 OF 3
ISSUE
1
ISSUE NUMBER
.120 3.05
.095 2.41
.245 6.22
1
.165 4.19
.170 4.32
.375 9.53
.125 [3.18] to .210 [5.33]
Outside Tails
.125 [3.18] to .185 [4.70]
Outside Tails
.045 [1.14] to .060 [1.52]
Between Tails
Between Tails
555 Contact Code
ORIGINAL
556 Contact Code
Outside Tails
Between Tails
560 Contact Code
Contact Bend Detail
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
379 Assembly
379 ENG MASTER
DATE: OCT. 14/09
DATE:
SHEET 2 OF 3
ISSUE
1
ISSUE NUMBER
.010 [0.25]
Radial Float
ORIGINAL
1
.116 2.95 I.D.
Floating Eyelets
.128 [3.25] x
.146 [3.71] Slot
.156 [3.96] Dia
Through Holes
M3-0.5 Metric
Threaded Insert
#4-40 UNC
Threaded Insert
.250 6.35 Dia.
.005 .13
.348 8.84
Code x01
Code x02
Code x03
Code x04
Code x07
Code x08
Mounting Options
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
379 Assembly
379 ENG MASTER
DATE: OCT. 14/09
DATE:
SHEET 3 OF 3
ISSUE
1
很抱歉,暂时无法提供与“379-032-524-103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+137.0460225+17.73056
