1N4003F
1N4003F
    SK(時科)
    SMAF
    时科 SMAF VF: 1.1V Io: 1A Ir: 5uA
1N4003F 数据手册
1N4001F THRU 1N4007F Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V Forward Current - 1 A PINNING FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Juntion • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives PIN MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 27mg / 0.00095oz DESCRIPTION 1 Cathode 2 Anode 1 2 Simplified outline SMAF and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols 1N4001F 1N4002F 1N4003F 1N4004F 1N4005F 1N4006F 1N4007F Units Parameter Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Ta = 65 °C I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF 1.1 V IR 5 50 μA Cj 9 pF RθJA 115 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage Typical Junction Capacitance Typical Thermal Resistance Ta = 25 °C Ta =125 °C 1) 2) Operating and Storage Temperature Range 1)Measured at 1 MHz and applied reverse voltage of 4 V D.C 2)P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. REV.08 1 of 3 1N4001F THRU 1N4007F Fig.2 Typical Instaneous Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current ( μ A) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 Single phase half-wave 60 Hz resistive or inductive load 0.2 0.0 25 75 50 100 125 150 175 100 T J =150°C 10 T J =125°C T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 Junction Capacitance ( pF) 2 5° C 00 TJ = =1 TJ =1 25 °C °C 0.5 TJ Instaneous Forward Current (A) 1.0 0.8 0.9 0.2 1.0 1.1 Peak Forward Surage Current (A) 10 T J =25°C 35 30 25 20 15 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 1.0 10 Reverse Voltage (V) 100 Number of Cycles REV.08 100 0.1 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 1 800 1 0.7 Instaneous Forward Voltage (V) 05 600 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 0.1 0.6 400 200 Instaneous Reverse Voltage (V) Ambient Temperature (°C) 2 of 3 100 1N4001F THRU 1N4007F PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View mil Bottom View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad D E A V M 7° The recommended mounting pad size Marking Type number 2.2 (86) 1.6 (63) 1.8 (71) 1.6 (63) mm Unit : (mil) REV.08 ∠ 3 of 3 Marking code 1N4001F M1 1N4002F M2 1N4003F M3 1N4004F M4 1N4005F M5 1N4006F M6 1N4007F M7
1N4003F 价格&库存
很抱歉,暂时无法提供与“1N4003F”相匹配的价格&库存,您可以联系我们找货
