SS12FL
SS12FL
    SK(時科)
    SMAF
    时科 SMAF single Io: 1A IR: 0.3mA VF: 0.45V
SS12FL 数据手册
SS12FL THRU SS16FL Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 and 60 V Forward Current - 1.0 A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 27mg 0. 00086oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. REV.08 2) P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 1 of 3 SS12FL THRU SS16FL REV.08 2 of 3 SS12FL THRU SS16FL PACKAGE OUTLINE Plastic surface mounted package; 2 leads REV.08 SMAF 3 of 3
SS12FL 价格&库存
很抱歉,暂时无法提供与“SS12FL”相匹配的价格&库存,您可以联系我们找货
