SS26F
SS26F
    SK(時科)
    SMAF(DO-214AD)
    时科 SMAF single Io: 2A IR: 0.5mA VF: 0.7V
SS26F 数据手册
SS22F THRU SS220F Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200 V Forward Current - 2.0A PINNING PIN Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SMAF 750, Method 2026 • Terminals: Solderable per MIL-STD-750, • Approx. Weight: 27mg 0.00086oz Absolute Maximum Ratings and Electrical characteristics DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SS22~SS220 Simplified outline SMAF and symbol Ratings at 25 °C C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % Symbols Parameter SS22F SS24F SS26F SS28F SS210F SS212F SS215F SS220F Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM Max Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance 1) VF 50 0.55 Operating Junction Temperature Range Tj Storage Temperature Range T stg 0.70 0.85 80 -55 ~ +125 -55 ~ +150 1 of 3 A 0.95 0.3 3 220 1) Measured at 1 MHz and applied reverse voltage of 4 V D.C REV.08 40 0.5 5 IR Cj A 2.0 V mA pF °C °C SS22F THRU SS220F Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 10 4 SS22F/SS24F SS26F-SS220F 10 1 T J =25°C 10 0 0 60 80 100 Fig.4 Typical Junction Capacitance 500 20 Junction Capacitance ( pF) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Forward Characteristic 10 1.0 SS22F/SS24F SS26F/SS28F SS210F/SS212F SS215F/SS220F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 60 50 SS22F-SS28F SS210F-SS220F 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 50 SS22F /SS24F 20 SS26F -SS220F 10 1 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 40 T J =25°C 200 0.1 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) T J =75°C 10 2 Lead Temperature (°C) 100 Number of Cycles at 60Hz REV.08 T J =100°C 10 3 2 of 3 100 SS22F THRU SS220F PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE VM g Top View mil Bottom View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad D E A 7° The recommended mounting pad size 2.2 (86 ) 1.6 (63 ) 1.8 (71 ) 1.6 (63 ) Unit: mm (mil) REV.08 ∠ 3 of 3
SS26F 价格&库存
很抱歉,暂时无法提供与“SS26F”相匹配的价格&库存,您可以联系我们找货
SS26F
  • 5+0.13836
  • 20+0.13589
  • 100+0.13094
库存:2376
SS26F
    • 3000+0.11165
    库存:27000
    SS26F
      • 3000+0.11165
      库存:9000
      SS26F
        • 3000+0.11165
        库存:27000
