SS22F THRU SS220F
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 2.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
MECHANICAL DATA
• Case: SMAF
750, Method 2026
• Terminals: Solderable per MIL-STD-750,
• Approx. Weight: 27mg 0.00086oz
Absolute Maximum Ratings and Electrical characteristics
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS22~SS220
Simplified outline SMAF and symbol
Ratings at 25 °C
C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load,
derate by 20 %
Symbols
Parameter
SS22F
SS24F
SS26F
SS28F
SS210F
SS212F
SS215F
SS220F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance
1)
VF
50
0.55
Operating Junction Temperature Range
Tj
Storage Temperature Range
T stg
0.70
0.85
80
-55 ~ +125
-55 ~ +150
1 of 3
A
0.95
0.3
3
220
1) Measured at 1 MHz and applied reverse voltage of 4 V D.C
REV.08
40
0.5
5
IR
Cj
A
2.0
V
mA
pF
°C
°C
SS22F THRU SS220F
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
10 4
SS22F/SS24F
SS26F-SS220F
10
1
T J =25°C
10 0
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Forward Characteristic
10
1.0
SS22F/SS24F
SS26F/SS28F
SS210F/SS212F
SS215F/SS220F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
60
50
SS22F-SS28F
SS210F-SS220F
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
50
SS22F /SS24F
SS26F -SS220F
10
1
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
40
T J =25°C
200
0.1
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
T J =75°C
10 2
Lead Temperature (°C)
100
Number of Cycles at 60Hz
REV.08
T J =100°C
10 3
2 of 3
100
SS22F THRU SS220F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
VM
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
7°
The recommended mounting pad size
2.2
(86 )
1.6
(63 )
1.8
(71 )
1.6
(63 )
Unit: mm
(mil)
REV.08
3 of 3
很抱歉,暂时无法提供与“SS215F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23100
- 30+0.22275
- 100+0.21450
- 500+0.19800
- 1000+0.18975
- 2000+0.18480
