SS22G THRU SS220G
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V Forward Current - 2.0A
PINNING
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
PIN
DESCRIPTION
1
Cathode
2
Anode
1
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
2
Top View
Marking Code: SS22~SS220
Simplified outline SMA and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS22G
SS24G
SS26G
SS28G
SS210G
SS212G
SS215G
SS220G
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
50
0.55
0.70
0.3
3
80
A
0.95
0.85
220
V
mA
pF
RθJA
80
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
40
0.5
5
IR
Cj
A
2.0
1 of 3
SS22G THRU SS220G
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
T J =75°C
10 2
SS22G /SS24G
SS26G -SS220G
10
1
T J =25°C
10 0
Case Temperature (°C)
80
100
500
Junction Capacitance ( pF)
1.0
SS22G /SS24G
SS26G /SS28G
SS210G /SS212G
SS215G /SS220G
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS22G /SS24G
SS26G -SS220G
10
1.8
0.1
Transient Thermal Impedance( °C /W)
60
50
SS22G -SS28G
40
SS210G -SS220G
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
Instaneous Forward Voltage (V)
100
Number of Cycles at 60Hz
REV.08
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
T J =100°C
10 3
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2 of 3
100
SS22G THRU SS220G
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
SMA
c
VM
A
HE
e
E
g
A
D
E
HE
c
e
g
max
2.2
4.83
2.9
5.4
0.31
1.7
1.5
min
1.9
4.32
2.3
4.7
0.12
1.2
0.9
max
87
190
114
213
12
67
59
min
75
170
91
185
5
47
35
UNIT
mm
mil
e
g
A
D
The recommended mounting pad size
Marking
Type number
2.2
(86)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
REV.08
3 of 3
Marking code
SS22G
SS22
SS24G
SS24
SS26G
SS26
SS28G
SS28
SS210G
SS210
SS212G
SS212
SS215G
SS215
SS220G
SS220
很抱歉,暂时无法提供与“SS24G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13800
- 500+0.12420
- 5000+0.11500
- 10000+0.11040
- 30000+0.10580
- 50000+0.10304
- 国内价格
- 20+0.27774
- 200+0.22654
- 600+0.19812
- 5000+0.18109
- 10000+0.16631
- 20000+0.15831
