SS36F
SS36F
    SK(時科)
    SMAF(DO-214AD)
    特性:金属硅结,多数载流子传导。 适用于表面贴装应用。 低功耗,高效率。 高正向浪涌电流能力。 适用于低电压、高频逆变器、续流和极性保护应用
SS36F 数据手册
SS32F THRU SS320F Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200 V Forward Current - 3.0A FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications MECHANICAL DATA • Case: SMAF 750, Method 2026 • Terminals: Solderable per MIL-STD-750, • Approx. Weight: 27mg 0.00086oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. REV.08 2) P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 1 of 3 SS32F THRU SS320F REV.08 2 of 3 SS32F THRU SS320F PACKAGE OUTLINE Plastic surface mounted package; 2 leads REV.08 SMAF 3 of 3
SS36F 价格&库存
很抱歉,暂时无法提供与“SS36F”相匹配的价格&库存,您可以联系我们找货
SS36F
    • 3000+0.09406
    库存:64800
    SS36F
      • 3000+0.09406
