74AHC74; 74AHCT74
Dual D-type flip-flop with set and reset; positive-edge trigger
Rev. 8 — 22 April 2020
Product data sheet
1. General description
The 74AHC74; 74AHCT74 is a high-speed Si-gate CMOS device and is pin compatible with
Low-Power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7-A.
The 74AHC74; 74AHCT74 is a dual positive-edge triggered, D-type flip-flop with individual data
inputs (D), clock inputs (CP), set inputs (SD) and reset inputs (RD). It also has complementary
outputs (Q and Q).
The set and reset are asynchronous active LOW inputs that operate independent of the clock
input. Information on the data input is transferred to the Q output on the LOW to HIGH transition
of the clock pulse. The data inputs must be stable one set-up time prior to the LOW to HIGH clock
transition for predictable operation.
Schmitt-trigger action in the clock input makes the circuit highly tolerant to slower clock rise and fall
times.
2. Features and benefits
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Input levels:
• For 74AHC74: CMOS level
• For 74AHCT74: TTL level
ESD protection:
• HBM EIA/JESD22-A114E exceeds 2000 V
• MM EIA/JESD22-A115-A exceeds 200 V
• CDM EIA/JESD22-C101C exceeds 1000 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74AHC74D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
-40 °C to +125 °C
DHVQFN14
plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
SOT762-1
74AHCT74D
74AHC74PW
74AHCT74PW
74AHC74BQ
74AHCT74BQ
74AHC74; 74AHCT74
Nexperia
4. Functional diagram
4
2
3
1D
1CP
1
1SD 2SD
SD
1Q
1D
D
Q
2D
2Q
1CP
CP
2CP
FF
1Q
Q
2Q
RD
Fig. 1.
Q
CP
FF
Q
1Q
1Q
5
6
10
5
9
12
6
8
11
4
1RD
3
2SD
2
1
2D
2CP
SD
D
Q
CP
FF
2Q
9
10
11
Q
2Q
12
8
13
RD
1RD 2RD
1 13
SD
D
RD
4 10
2
12
3
11
1SD
13
mna418
Functional diagram
Fig. 2.
2RD
5
C1
1D
6
R
S
9
C1
1D
8
R
mna420
Logic symbol
mna419
Fig. 3.
IEC logic symbol
Q
C
C
S
C
C
C
C
D
Q
C
RD
C
SD
CP
mna421
C
C
Fig. 4.
Logic diagram (one flip-flop)
74AHC_AHCT74
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 15
74AHC74; 74AHCT74
Nexperia
5. Pinning information
5.1. Pinning
1
terminal 1
index area
1D
2
13 2RD
1CP
3
12 2D
1SD
4
11 2CP
1Q
5
10 2SD
1Q
6
9
2Q
GND
7
8
2Q
1SD
4
11 2CP
1Q
5
1Q
6
GND(1)
13 2RD
10 2SD
9
2Q
001aac450
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aac449
Fig. 5.
12 2D
8
14 VCC
3
2Q
1
2
7
1RD
1D
1CP
GND
74AHC74
74AHCT74
14 VCC
1RD
74AHC74
74AHCT74
Pin configuration SOT108-1 (SO14) and
SOT402-1 (TSSOP14)
Fig. 6.
Pin configuration SOT762-1 (DHVQFN14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1RD
1
asynchronous reset direct input (active LOW)
1D
2
data input
1CP
3
clock input (LOW to HIGH, edge-triggered)
1SD
4
asynchronous set direct input (active LOW)
1Q
5
true flip-flop output
1Q
6
complement flip-flop output
GND
7
ground (0 V)
2Q
8
2Q
9
2SD
10
2CP
11
2D
12
data input
2RD
13
VCC
14
supply voltage
74AHC_AHCT74
Product data sheet
3 / 15
74AHC74; 74AHCT74
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care;
↑ = LOW to HIGH transition; Qn+1 = state after the next LOW to HIGH CP transition.
Control
Input
Output
nSD
nRD
nCP
nD
nQ
nQ
nQn+1
nQn+1
L
H
X
X
H
L
H
L
X
X
L
H
L
L
X
X
H
H
H
H
L
L
H
H
H
H
H
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
[1]
-20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
-20
+20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
-25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C.
8. Recommended operating conditions
Table 5. Operating conditions
Symbol Parameter
Conditions
74AHC74
74AHCT74
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
Δt/ΔV
input transition rise and fall rate VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
VCC
supply voltage
VI
74AHC_AHCT74
Product data sheet
+125 °C
4 / 15
74AHC74; 74AHCT74
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC74
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
μA
CI
input
capacitance
VI = VCC or GND
3
10
10
10
pF
74AHCT74
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -50 μA
4.4
4.5
4.4
4.4
V
IO = -8.0 mA
3.94
3.80
3.70
V
LOW-level
output voltage
IO = 50 μA
0.1
0.1
V
IO = 8.0 mA
0.36
0.44
0.55
V
VOL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VCC = 5.5 V
2.0
μA
74AHC_AHCT74
Product data sheet
5 / 15
74AHC74; 74AHCT74
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
ΔICC
additional
supply current
per input pin; VI = VCC - 2.1 V;
other pins at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
VI = VCC or GND
3
10
10
10
pF
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit, see Fig. 9.
Symbol Parameter Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ [1]
Max
Min
Max
Min
Max
Unit
74AHC74
tpd
[2]
propagation nCP to nQ, nQ; see Fig. 7
delay
VCC = 3.0 V to 3.6 V; CL = 15 pF
5.2
11.9
1.0
14.0
1.0
15.0 ns
VCC = 3.0 V to 3.6 V; CL = 50 pF
7.4
15.4
1.0
17.5
1.0
19.5 ns
VCC = 4.5 V to 5.5 V; CL = 15 pF
3.7
7.3
1.0
8.5
1.0
9.5
VCC = 4.5 V to 5.5 V; CL = 50 pF
5.2
9.3
1.0
10.5
1.0
12.0 ns
5.4
12.3
1.0
14.5
1.0
15.5 ns
7.7
15.8
1.0
18.0
1.0
20.0 ns
3.7
7.7
1.0
9.0
1.0
10.0 ns
5.3
9.7
1.0
11.0
1.0
12.5 ns
80
125
70
70
MHz
50
75
45
45
MHz
130
170
110
110
MHz
90
115
75
75
MHz
6.0
7.0
7.0
ns
5.0
5.0
5.0
ns
6.0
7.0
7.0
ns
5.0
5.0
5.0
ns
0.5
0.5
0.5
ns
0.5
0.5
0.5
ns
ns
nSD, nRD to nQ, nQ; see Fig. 8
fmax
tW
tsu
th
maximum
frequency
see Fig. 7
pulse width CP HIGH or LOW; nSD, nRD LOW;
see Fig. 7 and Fig. 8
set-up time nD to nCP; see Fig. 7
hold time
74AHC_AHCT74
Product data sheet
6 / 15
74AHC74; 74AHCT74
Nexperia
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ [1]
Max
Min
Max
Min
Max
5.0
5.0
5.0
ns
3.0
3.0
3.0
ns
[3]
12
pF
[2]
delay
3.3
7.8
1.0
9.0
1.0
10.0 ns
4.8
8.8
1.0
10.0
1.0
11.0 ns
3.7
10.4
1.0
12.0
1.0
13.0 ns
5.3
11.4
1.0
13.0
1.0
14.5 ns
100
160
80
80
MHz
80
140
65
65
MHz
tW
5.0
5.0
5.0
ns
tsu
set-up time nD to nCP; VCC = 4.5 V to 5.5 V;
see Fig. 7
5.0
5.0
5.0
ns
th
hold time
see Fig. 7
ns
trec
recovery
time
nRD to nCP; VCC = 4.5 V to 5.5 V;
see Fig. 8
3.5
3.5
3.5
ns
CPD
power
fi = 1 MHz; VI = GND to VCC
dissipation
capacitance
16
pF
trec
recovery
time
CPD
nRD to nCP; see Fig. 8
power
dissipation
capacitance
74AHCT74
tpd
fmax
[1]
[2]
[3]
maximum
frequency
see Fig. 7
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of the outputs.
74AHC_AHCT74
Product data sheet
7 / 15
74AHC74; 74AHCT74
Nexperia
10.1. Waveforms
VI
VM
nD input
GND
th
t su
1/fmax
t su
th
VI
VM
nCP input
GND
tW
t PHL
t PLH
VOH
VM
nQ output
VOL
VOH
nQ output
VM
VOL
t PLH
mna422
t PHL
Measurement points are given in Table 8.
The shaded areas indicate when the input is permitted to change for predictable output performance.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Clock pulse width, maximum frequency, set-up times, hold times and input to output propagation delays
VI
VM
nCP input
GND
t rec
VI
VM
nSD input
GND
tW
tW
VI
VM
nRD input
GND
t PLH
t PHL
VOH
nQ output
VM
VOL
VOH
VM
nQ output
VOL
t PHL
t PLH
mna423
Fig. 8.
Set and reset pulse widths, recovery time and input to output propagation delays
74AHC_AHCT74
Product data sheet
8 / 15
74AHC74; 74AHCT74
Nexperia
Table 8. Measurement points
Type
Input
Output
VM
VM
74AHC74
0.5 × VCC
0.5 × VCC
74AHCT74
1.5 V
0.5 × VCC
VI
negative
pulse
VM
tf
tr
tr
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
For test data, see Table 9.
Definitions for test circuit:
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig. 9.
Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74AHC74
VCC
≤ 3.0 ns
50 pF, 15 pF
tPLH, tPHL
74AHCT74
3.0 V
≤ 3.0 ns
50 pF, 15 pF
tPLH, tPHL
74AHC_AHCT74
Product data sheet
9 / 15
74AHC74; 74AHCT74
Nexperia
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT108-1 (SO14)
74AHC_AHCT74
Product data sheet
10 / 15
74AHC74; 74AHCT74
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 11. Package outline SOT402-1 (TSSOP14)
74AHC_AHCT74
Product data sheet
11 / 15
74AHC74; 74AHCT74
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
SOT762-1
References
IEC
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 12. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT74
Product data sheet
12 / 15
74AHC74; 74AHCT74
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AHC_AHCT74 v.8
20200422
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 5.1: Corrected pin configuration drawings (errata).
Table 4: Derating values for Ptot total power dissipation updated.
Fig. 12: Package outline drawing SOT762-1 (DHVQFN14) updated.
74AHC_AHCT74 v.7
20150421
Modifications:
74AHC_AHCT74 v.6
20141020
Modifications:
74AHC_AHCT74 v.5
20080609
Modifications:
74AHC_AHCT74 v.7
Product data sheet
74AHC_AHCT74 v.6
Table 7: minimum fmax values at 3.0 V to 3.6 V for 74AHC74 corrected (errata).
Product data sheet
74AHC_AHCT74 v.5
74AHC_AHCT74 v.4
Table 3 corrected (errata).
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Table 6: the conditions for input leakage current have been changed.
74AHC_AHCT74 v.4
20050207
Product data sheet
74AHC_AHCT74 v.3
74AHC_AHCT74 v.3
20040429
Product specification
74AHC_AHCT74 v.2
74AHC_AHCT74 v.2
19990923
74AHC_AHCT74 v.1
74AHC_AHCT74 v.1
19990805
74AHC_AHCT74
Product data sheet
13 / 15
74AHC74; 74AHCT74
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AHC_AHCT74
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74AHC74; 74AHCT74
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms.................................................................8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 April 2020
74AHC_AHCT74
Product data sheet
15 / 15
