MB8S
MB8S
    SK(時科)
    MBS
    30A 5uA@800V 1V@800mA 800mA 800V -55℃~+150℃@(Tj) MBS
MB8S 数据手册
MB1S THRU MB10S 0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: • Glass Passivated Chip Junction • Reverse Voltage - 100 to 1000 V • Forward Current - 0.8 A • High Surge Current Capability • Designed for Surface Mount Application MECHANICAL DATA • Case: MBS • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 100mg /0.0035oz Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase half-wave half wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols MB1S MB2S MB4S MB6S MB8S MB10S Units Maximum Repetitive Peak Reverse Voltage VRRM 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 100 200 400 600 800 1000 V Average Rectified Output Current at Ta = 50 °C IO 0.8 A IFSM 30 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) at 0.4 A 1.0 VF Maximum Forward Voltage V 1.1 at 0.8 A Maximum DC Reverse Current at Rated DC Blocking Voltage @TA=25 °C 5 IR Typical Junction Capacitance(Note1) Cj 13 RθJA 95 RθJL 30 Tj, Tstg -55 ~ +150 Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. REV.08 μA 40 @TA=125 °C 1 of 3 pF ℃/W ℃ 2. Mounted on glass epoxy PC board with 44×(5×5mm2 )copper pad. MB1S THRU MB10S REV.08 2 of 3 MB1S THRU MB10S PACKAGE OUTLINE Plastic surface mounted package; 4 leads REV.08 MBS mechanical data 3 of 3
很抱歉,暂时无法提供与“MB8S”相匹配的价格&库存,您可以联系我们找货
MB8S
    • 3000+0.06578
    库存:18000
    MB8S
    • 20+0.09900
    • 100+0.09000
    • 500+0.08400
    • 1000+0.07800
    • 5000+0.07080
    • 10000+0.06780
    库存:1490
    MB8S
    • 20+0.16017
    • 200+0.12702
    • 600+0.10865
    • 3000+0.08527
    • 9000+0.07572
    • 21000+0.07050
    库存:488
    MB8S
      • 3000+0.06578
      库存:36000
