US1AF THRU US1MF
SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
• For surface mounted applications
• L ow pro fil e pac k age
• Glass Passivated Chip Juntion
• Easy to pick and place
• Hi gh efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: US1A~US1M
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL - STD - 750, M e th o d 2026
• A pprox. Weight: 27mg 0.00086oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase half-wave 60 Hz, resistive or inductive load
for capacitive load current derate by 20 %.
Symbols
Parameter
U1AF U1BF
U1DF
U1GF
U1JF
U1KF
U1MF Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at Ta = 65 °C
I F(AV)
1.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
25
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current
at Rated DC Blocking Voltage
Ta = 25 °C
Ta =125 °C
Maximum Reverse Recovery Time
1)
Typical Thermal Resistance
Operating and Storage Temperature Range
1.0
1.7
5
100
IR
t rr
RθJA
50
T j , T stg
-55 ~ +150
1 of 3
V
μA
75
50
1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A
REV.08
1.4
ns
°C/W
°C
US1AF THRU US1MF
Fig.2 Typical Reverse Characteristics
1.2
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
1.0
0.8
0.6
0.4
0.2
0.0
25
75
50
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Ambient Temperature (°C)
T J =25°C
pulse with 300μs
1% duty cycle
1.0
0.1
0.01
0.0
US1AF~US1DF
US1GF
US1JF~US1MF
0.5
1.0
1.5
2.0
60
80
100
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
00
1
2.5
Instaneous Forward Voltage (V)
REV.08
40
Fig.4 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
10
Number of Cycles
2 of 3
100
US1AF THRU US1MF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
2.2( 86)
1.6(63)
1.8(71)
1.6(63)
Unit:mm(mil)
REV.08
3 of 3
很抱歉,暂时无法提供与“US1BF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08565
- 500+0.06772
- 3000+0.05336
- 6000+0.04742
- 24000+0.04223
- 51000+0.03942
