US1AG THRU US1MG
SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: US1AG ~US1MG
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load,
for capacitive load current derate by 20 %.
Symbols
Parameter
US1AG US1BG
US1DG
US1GG
US1JG
US1KG US1MG Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
(2)
Typical Junction Capacitance
(3)
Operating and Storage Temperature Range
1.0
1.65
5
100
IR
t rr
V
μA
75
50
ns
RθJA
75
°C/W
Cj
15
pF
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
(3)Measured at 1 MHz and applied reverse voltage of 4 V D.C
REV.08
1.3
1 of 3
US1AG THRU US1MG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
10
T J =25°C
1.0
US1AG~US1DG
US1GG
US1JG~US1MG
0.01
0.001
1.0
1.5
2.0
100
120
140
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
Fig.5- Typical Transient Thermal Impedance
Fig.6 Typical Junction Capacitance
100
Junction Capacitance ( pF)
Transient Thermal Impedance( °C /W)
80
35
2.5
10
100
T J=25°C
10
1
0.1
1
10
0.1
100
1.0
10
Reverse Voltage (V)
t, Pulse Duration(sec)
REV.08
60
40
Instaneous Forward Voltage (V)
1
0.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
0.1
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
2 of 3
100
US1AG THRU US1MG
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
a
0.3
12
Marking
Type number
2.4
(94)
mm
Unit :
(mil)
REV.08
US1AG
US1A
US1BG
US1B
US1DG
US1D
US1GG
US1G
US1JG
US1J
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
3 of 3
US1KG
US1K
US1MG
US1M
很抱歉,暂时无法提供与“US1AG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06329
- 500+0.04968
- 1500+0.04212
- 5000+0.03597
- 25000+0.03208
- 50000+0.02992
