US1GG
US1GG
    SK(時科)
    SMA(DO-214AC)
    特性:适用于表面贴装应用。低外形封装。玻璃钝化芯片结。易于拾取和放置。高效率。符合欧盟RoHS 2011/65/EU指令的无铅产品
US1GG 数据手册
US1AG THRU US1MG SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 V PINNING Forward Current - 1 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • High efficiency • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: US1AG ~US1MG Simplified outline SMA and symbol MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter US1AG US1BG US1DG US1GG US1JG US1KG US1MG Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 30 A Maximum Instantaneous Forward Voltage at 1 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Typical Junction Capacitance (3) Operating and Storage Temperature Range 1.0 1.65 5 100 IR t rr V μA 75 50 ns RθJA 75 °C/W Cj 15 pF T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. (3)Measured at 1 MHz and applied reverse voltage of 4 V D.C REV.08 1.3 1 of 3 US1AG THRU US1MG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Peak Forward Surage Current (A) Instaneous Forward Current (A) 10 T J =25°C 1.0 US1AG~US1DG US1GG US1JG~US1MG 0.01 0.001 0 0.5 1.0 1.5 2.0 100 120 140 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles Fig.5- Typical Transient Thermal Impedance Fig.6 Typical Junction Capacitance 100 Junction Capacitance ( pF) Transient Thermal Impedance( °C /W) 80 35 2.5 10 100 T J=25°C 10 1 0.1 1 10 0.1 100 1.0 10 Reverse Voltage (V) t, Pulse Duration(sec) REV.08 60 40 Instaneous Forward Voltage (V) 1 0.01 40 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Forward Characteristics 0.1 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 2 of 3 100 US1AG THRU US1MG PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D The recommended mounting pad size a 0.3 12 Marking Type number 2.4 (94) mm Unit : (mil) REV.08 US1AG US1A US1BG US1B US1DG US1D US1GG US1G US1JG US1J 1.8 (71) 1.8 (71) 1.8 (71) Marking code 3 of 3 US1KG US1K US1MG US1M
US1GG 价格&库存
很抱歉,暂时无法提供与“US1GG”相匹配的价格&库存,您可以联系我们找货
US1GG
    • 5000+0.03758
    库存:81000
