74AHCT1G79GV,125
74AHCT1G79GV,125
    NEXPERIA(安世)
    SC74A
    Nexperia SC-74A 1Channel 40μA 5.5V 3.1 x 1.7mm
74AHCT1G79GV,125 数据手册
74AHC1G79; 74AHCT1G79 Single D-type flip-flop; positive-edge trigger Rev. 7 — 30 August 2021 Product data sheet 1. General description The 74AHC1G79; 74AHCT1G79 is a single positive-edge triggered D-type flip-flop. Data at the D-input that meets the set-up and hold time requirements on the LOW-to-HIGH clock transition will be stored in the flip-flop and appear at the Q output. Inputs are overvoltage tolerant. This feature allows the use of these devices as translators in mixed voltage environments. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 2.0 to 5.5 V Overvoltage tolerant inputs to 5.5 V High noise immunity CMOS low power dissipation Latch-up performance exceeds 100 mA per JESD 78 Class II Level A Symmetrical output impedance Balanced propagation delays Input levels: • For 74AHC1G79: CMOS level • For 74AHCT1G79: TTL level ESD protection: • HBM JESD22-A114F: exceeds 2000 V • MM JESD22-A115-A: exceeds 200 V • CDM JESD22-C101C: exceeds 1000 V Specified from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74AHC1G79GW Temperature range Name Description Version -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 -40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74AHCT1G79GW 74AHC1G79GV 74AHCT1G79GV 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 4. Marking Table 2. Marking codes Type number Marking[1] 74AHC1G79GW AP 74AHCT1G79GW CP 74AHC1G79GV A79 74AHCT1G79GV C79 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1 D Q 4 1 2 2 CP D 4 CP mna441 mna440 Fig. 1. Q Logic symbol Fig. 2. CP IEC logic symbol C C D C C TG TG C Fig. 3. C C Q C TG TG C C mna442 Logic diagram 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 2 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 6. Pinning information 6.1. Pinning 74AHC1G79 74AHCT1G79 D 1 CP 2 GND 3 5 VCC 4 Q 001aaf091 Fig. 4. Pin configuration SOT353-1 (TSSOP5) and SOT753 (SC-74A) 6.2. Pin description Table 3. Pin description Symbol Pin Description D 1 data input CP 2 clock pulse input GND 3 ground (0 V) Q 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH CP transition; X = don’t care; Q + 1 = state after the next LOW-to-HIGH CP transition. Output Inputs CP D Q+1 ↑ L L ↑ H H L X Q 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 3 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Max Unit supply voltage -0.5 +7.0 V VI input voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC -20 - mA - ±20 mA - ±25 mA supply current - 75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [1] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT353-1 (TSSOP5) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT753 (SC-74A) package: Ptot derates linearly with 3.8 mW/K above 85 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC1G79 74AHCT1G79 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and VCC = 3.3 V ± 0.3 V fall rate VCC = 5.0 V ± 0.5 V - - 100 - - - ns/V - - 20 - - 20 ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V 74AHC1G79 VIH VIL HIGH-level input voltage LOW-level input voltage 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 4 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger Symbol Parameter VOH VOL Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VI = VIH or VIL HIGH-level output voltage IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.70 - V VI = VIH or VIL LOW-level output voltage IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 μA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 μA CI input capacitance - 1.5 10 - 10 - 10 pF 74AHCT1G79 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -50 μA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V IO = 8.0 mA - - 0.36 - 0.44 - 0.55 V VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA IO = -8.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 50 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 μA ΔICC additional per input pin; VI = 3.4 V; supply current other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 1.5 10 - 10 - 10 pF 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 5 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf = ≤ 3.0 ns. For test circuit see Fig. 6. For waveform see Fig. 5. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max CL = 15 pF - 4.9 8.4 1.0 9.8 1.0 11.5 ns CL = 50 pF - 6.9 12.0 1.0 14.0 1.0 15.5 ns CL = 15 pF - 3.5 5.6 1.0 7.0 1.0 8.0 ns CL = 50 pF - 5.1 8.0 1.0 10.0 1.0 11.0 ns 74AHC1G79 tpd propagation delay CP to Q [1] VCC = 3.0 V to 3.6 V [2] VCC = 4.5 V to 5.5 V [3] tsu set-up time D to CP 3.0 1.0 - 3.0 - 4.0 - ns th hold time D to CP +2.0 -1.0 - 2.0 - 3.0 - ns tW pulse width clock HIGH or LOW 3.0 - - 3.0 - 4.0 - ns fmax maximum frequency 90 - - 90 - 70 - MHz CPD power per buffer; CL = 50 pF; [4] dissipation f = 1 MHz; VI = GND to VCC capacitance - 15 - - - - - pF - 3.5 5.0 1.0 6.0 1.0 8.0 ns 74AHCT1G79 tpd propagation delay CP to Q [1] VCC = 4.5 V to 5.5 V [3] CL = 15 pF - 5.0 8.0 1.0 10.0 1.0 11.0 ns tsu set-up time D to CP CL = 50 pF 3.0 1.0 - 3.0 - 4.0 - ns th hold time D to CP +2.0 -1.0 - 2.0 - 3.0 - ns tW pulse width clock HIGH or LOW 3.0 - - 3.0 - 4.0 - ns fmax maximum frequency 90 - - 90 - 70 - MHz CPD power per buffer; CL = 50 pF; [4] dissipation f = 1 MHz; VI = GND to VCC capacitance - 16 - - - - - pF [1] [2] [3] [4] tpd is the same as tPLH and tPHL. Typical values are measured at VCC = 3.3 V. Typical values are measured at VCC = 5.0 V. CPD is used to determine the dynamic power dissipation PD (μW). 2 2 PD = CPD x VCC x fi + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volt. 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 6 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 11.1. Waveform and test circuit VI VM D input GND th th t su 1/fmax t su VI CP input VM GND tW t PHL t PLH VOH VM Q output VOL mna647 Measurement points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output. Fig. 5. Clock (CP) to output (Q) propagation delay times, clock pulse width, D to set-up times, the CP to D hold times and maximum clock pulse frequency Table 9. Measurement points Type Inputs Output VI VM VM 74AHC1G79 GND to VCC 0.5 x VCC 0.5 x VCC 74AHCT1G79 GND to 3.0 V 1.5 V 0.5 x VCC VCC PULSE GENERATOR VI DUT VO RT CL mna101 Test data is given in Table 8. Definitions for test circuit: CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig. 6. Test circuit for measuring switching times 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 7 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 12. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 Fig. 7. REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Package outline SOT353-1 (TSSOP5) 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 8 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 Fig. 8. JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Package outline SOT753 (SC-74A) 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 9 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT1G79 v.7 20210830 Product data sheet - Modifications: • • • • 74AHC_AHCT1G79 v.6 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Section 8: Derating values for Ptot total power dissipation updated. 74AHC_AHCT1G79 v.6 20140923 Modifications: • 74AHC_AHCT1G79 v.5 20070702 74AHC_AHCT1G79 v.4 74AHC_AHCT1G79 v.3 - 74AHC_AHCT1G79 v.5 Product data sheet - 74AHC_AHCT1G79 v.4 20020606 Product specification - 74AHC_AHCT1G79 v.3 20020218 Product specification - 74AHC_AHCT1G79 v.2 74AHC_AHCT1G79 v.2 20010222 Product specification - 74AHC_AHCT1G79 v.1 74AHC_AHCT1G79 v.1 19990518 Product specification - - 74AHC_AHCT1G79 Product data sheet Product data sheet Section 4: table note added. All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 10 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AHC_AHCT1G79 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 11 / 12 74AHC1G79; 74AHCT1G79 Nexperia Single D-type flip-flop; positive-edge trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................6 11.1. Waveform and test circuit.......................................... 7 12. Package outline.......................................................... 8 13. Abbreviations............................................................ 10 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 August 2021 74AHC_AHCT1G79 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 August 2021 © Nexperia B.V. 2021. All rights reserved 12 / 12
74AHCT1G79GV,125 价格&库存
很抱歉,暂时无法提供与“74AHCT1G79GV,125”相匹配的价格&库存,您可以联系我们找货
74AHCT1G79GV,125
  • 1+1.587971+0.20636
  • 10+1.0668210+0.13864
  • 25+0.9340325+0.12138
  • 100+0.79495100+0.10331
  • 250+0.72800250+0.09461
  • 500+0.68780500+0.08938
  • 1000+0.654571000+0.08507
库存:1119
74AHCT1G79GV,125
  • 3000+0.566433000+0.07361
  • 6000+0.547626000+0.07117
  • 9000+0.538209000+0.06994
  • 15000+0.5277615000+0.06859
  • 21000+0.5216621000+0.06779
  • 30000+0.5157930000+0.06703
库存:1119
74AHCT1G79GV,125
  • 1+1.65296
  • 10+1.09718
  • 25+0.95584
