74ALVC374D,118
74ALVC374D,118
    NEXPERIA(安世)
    SOIC20_300MIL
    八进制D型触发器;正边缘触发;三态
74ALVC374D,118 数据手册
74ALVC374 Octal D-type flip-flop; positive-edge trigger; 3-state Rev. 3 — 30 April 2021 Product data sheet 1. General description The 74ALVC374 is an octal positive-edge triggered D-type flip-flop with 3-state outputs. The device features a clock (CP) and output enable (OE) inputs. The flip-flops will store the state of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops . This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 1.65 V to 3.6 V 3.6 V tolerant inputs/outputs CMOS low power consumption Direct interface with TTL levels (2.7 V to 3.6 V) Power-down mode Latch-up performance exceeds 250 mA Complies with JEDEC standards: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8B (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114E exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ALVC374D -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74ALVC374PW -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74ALVC374BQ -40 °C to +85 °C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 × 4.5 × 0.85 mm SOT764-1 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 4. Functional diagram 1 EN 11 11 3 CP 3 4 7 8 13 14 17 18 D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 Q7 OE 1 Fig. 1. C1 2 2 1D 4 5 6 7 6 9 8 9 12 13 12 14 15 17 16 18 19 5 15 16 19 mna891 mna196 Logic symbol Fig. 2. IEC logic symbol 3 D0 Q0 2 4 D1 Q1 5 7 D2 Q2 6 8 D3 Q3 9 13 D4 14 D5 17 D6 Q6 16 18 D7 Q7 19 FF1 to FF8 3-STATE OUTPUTS Q4 12 Q5 15 11 CP 1 OE mna892 Fig. 3. Functional diagram D0 D1 D Q D2 D CP Q D CP FF1 D3 Q D CP FF2 D4 Q D CP FF3 D5 Q D CP FF4 D6 Q D CP FF5 D7 Q D CP FF6 Q CP FF7 FF8 CP OE Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 mna893 Fig. 4. Logic diagram 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 2 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 5. Pinning information 5.1. Pinning 1 OE terminal 1 index area 2 19 Q7 D0 3 18 D7 D1 4 17 D6 Q1 5 16 Q6 15 Q5 1 20 VCC Q2 6 Q0 2 19 Q7 D0 3 18 D7 D2 7 D1 4 17 D6 D3 8 Q1 5 16 Q6 Q3 9 Q2 6 15 Q5 D2 7 14 D5 D3 8 13 D4 Q3 9 12 Q4 GND 10 11 CP 14 D5 GND(1) 13 D4 12 Q4 GND 10 OE aaa-032672 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. aaa-032671 Fig. 5. Q0 CP 11 74ALVC374 20 VCC 74ALVC374 Pin configuration SOT163-1 (SO20) and SOT360-1 (TSSOP20) Fig. 6. Pin configuration SOT764-1 (DHVQFN20) 5.2. Pin description Table 2. Pin description Symbol Pin Description D0, D1, D2, D3, D4, D5, D6, D7 3, 4, 7, 8, 13, 14, 17, 18 data input CP 11 clock input (LOW to HIGH, edge-triggered) OE 1 output enable input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 2, 5, 6, 9, 12, 15, 16, 19 3-state flip-flop output VCC 20 supply voltage GND 10 ground (0 V) 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 3 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW to HIGH CP transition L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW to HIGH CP transition Z = high-impedance OFF-state; ↑ = LOW to HIGH clock transition Operating mode Load and read register Load register and disable outputs Internal flip-flop Output Input OE CP Dn Qn L ↑ l L L L ↑ h H H H ↑ l L Z H ↑ h H Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V -50 - -0.5 +4.6 V - ±50 mA -0.5 VCC + 0.5 V output 3-state -0.5 +4.6 V power-down mode; VCC = 0 V -0.5 +4.6 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW state VI < 0 V [1] IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] VO = 0 V to VCC [1] mA Tamb = -40 °C to +85 °C The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Min Max Unit 1.65 3.6 V 0 3.6 V output HIGH or LOW state 0 VCC V output 3-state 0 3.6 V power-down mode; VCC = 0 V 0 3.6 V -40 +85 °C VCC = 1.65 V to 2.7 V - 20 ns/V VCC = 2.7 V to 3.6 V - 10 ns/V Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 4 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage VIL LOW-level input voltage VOH HIGH-level output voltage Conditions LOW-level output voltage Unit Min Typ [1] Max 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC - 0.2 - - V IO = -6 mA; VCC = 1.65 V 1.25 1.51 - V IO = -12 mA; VCC = 2.3 V 1.8 2.10 - V IO = -18 mA; VCC = 2.3 V 1.7 2.01 - V IO = -12 mA; VCC = 2.7 V 2.2 2.53 - V IO = -18 mA; VCC = 3.0 V 2.4 2.76 - V IO = -24 mA; VCC = 3.0 V 2.2 2.68 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - - 0.2 V IO = 6 mA; VCC = 1.65 V - 0.11 0.3 V IO = 12 mA; VCC = 2.3 V - 0.17 0.4 V IO = 18 mA; VCC = 2.3 V - 0.25 0.6 V IO = 12 mA; VCC = 2.7 V - 0.16 0.4 V IO = 18 mA; VCC = 3.0 V - 0.23 0.4 V VCC = 1.65 V to 1.95 V 0.35 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 3.6 V VOL -40 °C to +85 °C VI = VIH or VIL IO = 24 mA; VCC = 3.0 V - 0.30 0.55 V II input leakage current VCC = 3.6 V; VI = 3.6 V or GND - ±0.1 ±5 μA IOZ OFF-state output current VI = VIH or VIL; VCC = 1.65 V to 3.6 V; VO = 3.6 V or GND - ±0.1 ±10 μA IOFF power-off leakage supply VCC = 0 V; VI or VO = 0 V to 3.6 V - ±0.1 ±10 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 10 μA ΔICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 750 μA CI input capacitance - 3.5 - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 5 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 10. Symbol Parameter tpd propagation delay ten enable time tdis disable time tW pulse width tsu set-up time th hold time fmax maximum frequency CPD [1] [2] power dissipation capacitance Conditions -40 °C to +85 °C Unit Min Typ [1] Max VCC = 1.65 V to 1.95 V 1.0 3.1 6.4 ns VCC = 2.3 V to 2.7 V 1.0 2.3 3.9 ns VCC = 2.7 V 1.0 2.5 3.6 ns VCC = 3.0 V to 3.6 V 1.0 2.5 3.6 ns VCC = 1.65 V to 1.95 V 1.0 3.2 6.4 ns VCC = 2.3 V to 2.7 V 1.0 2.6 4.5 ns VCC = 2.7 V 1.0 3.2 4.6 ns VCC = 3.0 V to 3.6 V 1.0 2.4 4.0 ns VCC = 1.65 V to 1.95 V 1.5 3.6 7.0 ns VCC = 2.3 V to 2.7 V 1.0 2.3 4.4 ns VCC = 2.7 V 1.5 2.9 4.4 ns VCC = 3.0 V to 3.6 V 1.0 2.8 4.4 ns VCC = 1.65 V to 1.95 V 3.8 1.1 - ns VCC = 2.3 V to 2.7 V 3.3 0.9 - ns VCC = 2.7 V 3.3 0.8 - ns VCC = 3.0 V to 3.6 V 3.3 1.2 - ns VCC = 1.65 V to 1.95 V 0.8 -0.1 - ns VCC = 2.3 V to 2.7 V 0.8 0.1 - ns VCC = 2.7 V 0.8 0.3 - ns VCC = 3.0 V to 3.6 V 0.8 0.0 - ns VCC = 1.65 V to 1.95 V 0.8 -0.1 - ns VCC = 2.3 V to 2.7 V 0.8 0.1 - ns VCC = 2.7 V 0.8 0.4 - ns VCC = 3.0 V to 3.6 V 0.7 -0.1 - ns VCC = 2.3 V to 2.7 V 100 200 - MHz VCC = 2.7 V 100 200 - MHz VCC = 3.0 V to 3.6 V 150 300 - MHz outputs HIGH or LOW state - 21 - pF outputs 3-state - 13 - pF CP to Qn; see Fig. 7 OE to Qn; see Fig. 8 OE to Qn; see Fig. 8 [2] [2] [2] clock (CP) HIGH or LOW; see Fig. 7 Dn to CP; see Fig. 9 Dn to CP; see Fig. 9 see Fig. 7 per flip-flop; VI = GND to VCC; VCC = 3.3 V [3] Typical values are measured at Tamb = 25 °C tpd is the same as tPHL and tPLH. 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 6 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state [3] ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs 10.1. Waveforms and test circuit 1/f max VI CP input VM GND tW t PHL t PLH VOH VM Qn output VOL mna894 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 7. Clock (CP) to output (Qn) propagation delays, the clock pulse width and the maximum frequency VI OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ VOH output HIGH-to-OFF OFF-to-HIGH tPZH VY VM GND outputs enabled outputs disabled outputs enabled mna644 Measurement points are given in Table 8. VOL and VOH are the typical output voltage drops that occur with the output load. Fig. 8. Enable and disable times 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 7 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state VI VM CP input GND tsu tsu th th VI VM Dn input GND VOH VM Qn output VOL mna202 Measurement points are given in Table 8. VOL and VOH are the typical output voltage drops that occur with the output load. The shaded areas indicate when the input is permitted to change for predicable output performance. Fig. 9. Data set-up and hold times for the Dn input to the CP input Table 8. Measurement points Supply voltage Input Output VCC VM VM Vx Vy 1.65 V to 1.95 V 0.5VCC 0.5VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V 0.5VCC 0.5VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 8 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 6V GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 6V GND 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 9 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 11. Package outline SOT163-1 (SO20) 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 10 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 12. Package outline SOT360-1 (TSSOP20) 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 11 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- sot764-1_po European projection Issue date 03-01-27 14-12-12 Fig. 13. Package outline SOT764-1 (DHVQFN20) 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 12 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVC374 v.3 20210430 Product data sheet - Modifications: • • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 updated. Section 2: Reference to JESD36 removed. Section 7: Derating values for Ptot total power dissipation removed (errata). Package outline drawing SOT764-1 (DHVQFN20) updated. 74ALVC374 v.2 20071017 Modifications: • • • • • 74ALVC374 v.1 74ALVC374 Product data sheet 74ALVC374 v.2 Product data sheet - 74ALVC374 v.1 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Section 3: DHVQFN20 package added. Section 7: derating values added for DHVQFN20 package. Section 11: outline drawing added for DHVQFN20 package. 20020227 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 - © Nexperia B.V. 2021. All rights reserved 13 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ALVC374 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 14 / 15 74ALVC374 Nexperia Octal D-type flip-flop; positive-edge trigger; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline........................................................ 10 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 April 2021 74ALVC374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 30 April 2021 © Nexperia B.V. 2021. All rights reserved 15 / 15
74ALVC374D,118 价格&库存
很抱歉,暂时无法提供与“74ALVC374D,118”相匹配的价格&库存,您可以联系我们找货
