74ALVCH16841
20-bit bus interface D-type latch; 3-state
Rev. 3 — 12 September 2018
Product data sheet
1. General description
The 74ALVCH16841 has two 10-bit D-type latch featuring separate D-type inputs for each latch
and 3-state outputs for bus oriented applications. The two sections of each register are controlled
independently by the latch enable (nLE) and output enable (nOE) control gates.
When nOE is LOW, the data in the registers appears at the outputs. When nOE is HIGH the
outputs are in High-impedance OFF state. Operation of the nOE input does not affect the state of
the flip-flops.
The 74ALVCH16841 has active bus hold circuitry which is provided to hold unused or floating
data inputs at a valid logic level. This feature eliminates the need for external pull-up or pull-down
resistors.
2. Features and benefits
Wide supply voltage range of 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Current drive ±24 mA at VCC = 3.0 V
MULTIBYTE flow-through standard pin-out architecture
Low inductance multiple VCC and GND pins for minimize noise and ground bounce
All data inputs have bushold
Output drive capability 50 Ω transmission lines at 85 °C
3-state non-inverting outputs for bus oriented applications
Complies with JEDEC standards:
• JESD8-5 (2.3 V to 2.7 V)
• JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
• HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V
• CDM JESD22-C101E exceeds 1000 V
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
74ALVCH16841DGG −40 °C to +85 °C
TSSOP56
Description
Version
plastic thin shrink small outline package; 56 leads; SOT364-1
body width 6.1 mm
74ALVCH16841
Nexperia
4. Functional diagram
1OE
1
1D0
1D1
1D2
1D3
1D4
1D5
1D6
1D7
1D8
1D9
2D0
2D1
2D2
2D3
2D4
2D5
2D6
2D7
2D8
2D9
1OE
2OE
1LE
28
55
2
54
3
52
5
2OE
1Q0
1Q1
51
6
49
8
48
9
47
10
45
12
44
13
43
14
42
15
41
16
40
17
38
19
37
21
34
23
33
24
31
26
30
27
56
2LE
1Q2
1D0
1Q3
1D1
1Q4
1D2
1Q5
1D3
1Q6
1D4
1Q7
1D5
1Q8
1D6
1Q9
1D7
2Q0
1D8
2Q1
1D9
2Q2
2D0
2Q3
2D1
2Q4
2D2
2Q5
2D3
2Q6
2D4
2Q7
2D5
2Q8
2D6
2Q9
2D7
2D8
29
2D9
1LE
Fig. 1.
2LE
29
55
54
C1
EN4
C3
1D
2
Q
2
3
52
5
51
6
49
8
48
9
47
10
45
12
44
13
43
14
42
41
3D
4
15
16
40
17
38
19
37
21
34
23
33
24
31
26
30
27
1Q0
1Q1
1Q2
1Q3
1Q4
1Q5
1Q6
1Q7
1Q8
1Q9
2Q0
2Q1
2Q2
2Q3
2Q4
2Q5
2Q6
2Q7
2Q8
2Q9
aaa-029041
Fig. 2.
D
28
EN2
aaa-029040
Logic symbol
1D0
1
56
1Q0
2D0
IEC logic symbol
D
LATCH
1
LE
Q
2Q0
LATCH
11
LE
1LE
2LE
1OE
2OE
to 9 other channels
to 9 other channels
aaa-029042
Fig. 3.
Logic diagram
VCC
data
input
to internal circuit
mna004
Fig. 4.
Bushold circuit
74ALVCH16841
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 12
74ALVCH16841
Nexperia
5. Pinning information
5.1. Pinning
74ALVCH16841
1OE
1
56 1LE
1Q0
2
55 1D0
1Q1
3
54 1D1
GND
4
53 GND
1Q2
5
52 1D2
1Q3
6
51 1D3
VCC
7
50 VCC
1Q4
8
49 1D4
1Q5
9
48 1D5
1Q6 10
47 1D6
GND 11
46 GND
1Q7 12
45 1D7
1Q8 13
44 1D8
1Q9 14
43 1D9
2Q0 15
42 2D0
2Q1 16
41 2D1
2Q2 17
40 2D2
GND 18
39 GND
2Q3 19
38 2D3
2Q4 20
37 2D4
2Q5 21
36 2D5
VCC 22
35 VCC
2Q6 23
34 2D6
2Q7 24
33 2D7
GND 25
32 GND
2Q8 26
31 2D8
2Q9 27
30 2D9
2OE 28
29 2LE
aaa-029043
Fig. 5.
Pin configuration SOT364-1 (TSSOP56)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7, 1D8, 1D9
55, 54, 52, 51, 49, 48, 47, 45, 44, 43
data input
2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7, 2D8, 2D9
42, 41, 40, 38, 37, 36, 34, 33, 31, 30
data input
1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7, 1Q8, 1Q9
2, 3, 5, 6, 8, 9, 10, 12, 13, 14
data output
2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7, 2Q8, 2Q9
15, 16, 17, 19, 20, 21, 23, 24, 26, 27
data output
1OE, 2OE
1, 28
output enable inputs
(active-LOW)
1LE, 2LE
56, 29
latch enable inputs
GND
4, 11, 18, 25, 32, 39, 46, 53
ground (0 V)
VCC
7, 22, 35, 50
supply voltage
74ALVCH16841
Product data sheet
3 / 12
74ALVCH16841
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Outputs
Inputs
nOE
nLE
nDn
nQn
L
H
L
L
L
H
H
H
L
L
X
Q0
H
X
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
-0.5
+4.6
V
For control pins
[1]
-0.5
+4.6
V
For data inputs
[1]
-0.5
VCC + 0.5
V
[1]
-0.5
VCC + 0.5
V
VO
output voltage
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO > VCC or VO < 0 V
±50
mA
IO
output current
VO = 0 V to VCC
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
600
mW
[1]
[2]
Tamb = -40 °C to +85 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
Above 55 °C the value of Ptot derates linearly with 8 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
Min
Max
Unit
for maximum speed performance; 30 pF output load
2.3
2.7
V
for maximum speed performance; 50 pF output load
3.0
3.6
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
-40
+85
°C
Δt/ΔV
input transition rise and fall rate VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
10
ns/V
74ALVCH16841
Product data sheet
in free air
4 / 12
74ALVCH16841
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Tamb = -40 °C to +85 °C
Symbol
Parameter
Conditions
Min
Typ[1]
Max
VIH
HIGH-level
input voltage
VCC = 2.3 V to 2.7 V
1.7
1.2
V
VCC = 2.7 V to 3.6 V
2.0
1.5
V
LOW-level
input voltage
1.2
0.7
V
1.5
0.8
V
HIGH-level
output voltage
VI = VIH or VIL
IO = -100 μA; VCC = 2.3 V to 3.6 V
VCC - 0.2
VCC
V
IO = -6 mA; VCC = 2.3 V
VCC - 0.3
VCC - 0.08
V
IO = -12 mA; VCC = 2.3 V
VCC - 0.6
VCC - 0.26
V
IO = -12 mA; VCC = 2.7 V
VCC - 0.5
VCC - 0.14
V
IO = -12 mA; VCC = 3.0 V
VCC - 0.6
VCC - 0.09
V
IO = -24 mA; VCC = 3.0 V
VCC - 1.0
VCC - 0.28
V
IO = 100 μA; VCC = 2.3 V to 3.6 V
GND
0.20
V
IO = 6 mA; VCC = 2.3 V
0.07
0.40
V
IO = 12 mA; VCC = 2.3 V
0.15
0.70
V
IO = 12 mA; VCC = 2.7 V
0.14
0.40
V
IO = 24 mA; VCC = 3.0 V
0.27
0.55
V
VIL
VOH
VOL
LOW-level
output voltage
Unit
VI = VIH or VIL
II
input
leakage current
VCC = 2.3 V to 3.6 V; VI = VCC or GND
0.1
5
μA
IOZ
OFF-state
output current
VCC = 2.3 V to 3.6 V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
μA
ICC
supply current
VCC = 2.3 V to 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
40
μA
ΔICC
additional
supply current
VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V;
IO = 0 A
150
750
μA
IBHL
bus hold LOW
current
VCC = 2.3 V; VI = 0.7 V
45
μA
VCC = 3.0 V; VI = 0.8 V
75
150
μA
bus hold HIGH
current
VCC = 2.3 V; VI = 1.7 V
-45
μA
VCC = 3.0 V; VI = 2.0 V
-75
-175
μA
IBHLO
bus hold LOW
overdrive current
VCC = 3.6 V
500
μA
IBHHO
bus hold HIGH
overdrive current
VCC = 3.6 V
-500
μA
CI
input capacitance
5.0
pF
IBHH
[1]
All typical values are measured at Tamb = 25 °C.
74ALVCH16841
Product data sheet
5 / 12
74ALVCH16841
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10;
Symbol Parameter
Conditions
tpd
nDn to nQn; see Fig. 6
propagation delay
Min
Typ[1]
Max
Unit
1.0
2.5
5.0
ns
VCC = 2.7 V
1.0
2.6
4.7
ns
1.0
2.4
3.9
ns
1.0
2.5
5.6
ns
VCC = 2.7 V
1.0
2.6
5.1
ns
1.0
2.4
4.3
ns
1.0
2.7
6.2
ns
VCC = 2.7 V
1.0
3.1
6.0
ns
1.0
2.3
4.9
ns
1.1
2.2
5.3
ns
VCC = 2.7 V
1.3
3.1
4.3
ns
1.3
2.9
4.1
ns
1.3
0.1
ns
VCC = 2.7 V
1.1
0.1
ns
1.0
0.6
ns
1.4
0.3
ns
VCC = 2.7 V
1.7
0.2
ns
1.4
0.2
ns
3.3
1.5
ns
outputs enabled
19
pF
outputs disabled
3
pF
[2]
nLE to nQn; see Fig. 7
ten
enable time
nOE to nQn; see Fig. 9
[3]
tdis
disable time
tsu
set-up time
th
hold time
nDn to nLE; see Fig. 8
tW
pulse width
nLE HIGH; VCC = 2.3 V to 3.6 V; see Fig. 7
CPD
power dissipation
capacitance
per latch; VI = GND to VCC
[1]
[2]
[3]
[4]
[5]
[4]
[5]
Typical values are measured at Tamb = 25 °C
Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V.
Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
N = total load switching outputs;
2
∑(CL × VCC × fo) = sum of outputs.
74ALVCH16841
Product data sheet
6 / 12
74ALVCH16841
Nexperia
10.1. Waveforms and test circuit
VI
VI
VM
nDn input
nLE input
VM
GND
GND
tPHL
tPLH
nQn output
VM
tPLH
VM
VOL
001aam011
001aam012
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that
occur with the output load.
Fig. 6.
VM
VM
VM
VOL
VM
tW
tPHL
VOH
VOH
nQn output
VM
Fig. 7.
Input (nDn) to output (nQn) propagation delays
Latch enable input (nLE) to data output (nQn)
propagation delays and pulse width (nLE)
VI
nDn input
VM
GND
th
th
tsu
VI
nLE input
tsu
VM
GND
001aam013
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 8.
Data setup and hold times for input (nDn) to input (nLE)
VI
nOE input
VM
VM
GND
tPLZ
nQn output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPZH
tPHZ
nQn output
HIGH-to-OFF
OFF-to-HIGH
VOH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aal795
VOL and VOH are typical output levels that occur with the output load.
Fig. 9.
3-State enable and disable times
74ALVCH16841
Product data sheet
7 / 12
74ALVCH16841
Nexperia
Table 8. Measurement points
Input
Output
VCC
VI
VM
VM
Vx
Vy
< 2.3 V
VCC
0.5VCC
0.5VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5VCC
0.5VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance;
CL = Load capacitance including jig and probe capacitance;
RT = Termination resistance should be equal to output impedance Zo of the pulse generator;
VEXT = External voltage for measuring switching times.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Input
Load
VEXT
VCC
VI
tr, tf
RL
CL
tPHZ, tPZH
tPLZ, tPZL
tPLH, tPHL
< 2.3 V
VCC
≤ 2.0 ns
500 Ω
30 pF
GND
2 × VCC
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
500 Ω
30 pF
GND
2 × VCC
open
2.7 V
2.7 V
≤ 2.5 ns
500 Ω
50 pF
GND
2 × VCC
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
500 Ω
50 pF
GND
2 × VCC
open
74ALVCH16841
Product data sheet
8 / 12
74ALVCH16841
Nexperia
11. Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 11. Package outline SOT364-1 (TSSOP56)
74ALVCH16841
Product data sheet
9 / 12
74ALVCH16841
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVCH16841 v.3
20180912
Product data sheet
74ALVCH16841 v.2
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74ALVCH16841 v.2
19980727
Product specification
74ALVCH16841 v.1
19980727
74ALVCH16841
Product data sheet
74ALVCH16841 v.1
10 / 12
74ALVCH16841
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVCH16841
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
74ALVCH16841
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 September 2018
74ALVCH16841
Product data sheet
12 / 12
