74ALVT162821DGGS
74ALVT162821DGGS
    NEXPERIA(安世)
    TSSOP56
    20位总线接口D型触发器;带30的正边缘触发器Ω 终端电阻器;三态 TSSOP56
74ALVT162821DGGS 数据手册
74ALVT162821 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state Rev. 5 — 19 October 2020 Product data sheet 1. General description The 74ALVT162821 is a 20-bit positive-edge triggered D-type flip-flop with 30 Ω termination resistors and 3-state outputs The device can be used as two 10-bit flip-flops or one 20-bit flip-flop. The device features two clocks (1CP and 2CP) and two output enables (1OE and 2OE), each controlling 10-bits. The flip-flops will store the state of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (nCP) transition. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state. Operation of the nOE input does not affect the state of the flip-flops. Bus hold data inputs eliminate the need for external pull-up resistors to define unused inputs 2. Features and benefits • • • • • • • • • • • • • • • • • • Wide supply voltage range from 2.3 V to 3.6 V Overvoltage tolerant inputs to 5.5 V BiCMOS high speed and output drive Outputs include series resistance of 30 Ω making external termination resistors unnecessary No bus current loading when output is tied to 5 V bus Direct interface with TTL levels IOFF circuitry provides partial Power-down mode operation 20-bit positive-edge triggered register 5 V I/O compatible Multiple VCC and GND pins minimize switching noise Bus hold on data inputs Live insertion and extraction permitted Power-up reset Power-up 3-state Output capability: +12 mA and -12 mA Latch-up protection: • JESD17: exceeds 500 mA ESD protection: • MIL STD 883, method 3015: exceeds 2000 V • MM: exceeds 200 V Specified from -40 °C to 85 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range 74ALVT162821DGG -40 °C to +85 °C Name Description Version TSSOP56 plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 4. Functional diagram 1OE 1CP 1 56 EN2 C1 28 2OE 29 2CP 55 54 52 51 49 48 47 45 44 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 1D8 1D9 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 2D8 2D9 43 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 1D8 1D9 56 1CP 1 1OE 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 1Q8 1Q9 2 3 5 6 8 9 10 12 13 14 42 41 40 38 37 36 34 33 31 30 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 2D8 2D9 29 2CP 28 2OE 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 2Q8 2Q9 15 16 17 19 20 21 23 24 26 27 EN4 C3 55 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 30 1D 2 3D 4 Logic symbol nD0 Fig. 2. nD1 nD2 nD3 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 1Q8 1Q9 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 2Q8 2Q9 001aad155 001aad153 Fig. 1. 2 3 5 6 8 9 10 12 13 14 15 16 17 19 20 21 23 24 26 27 nD4 IEC logic symbol nD5 nD6 nD7 nD8 nD9 D D D D D D D D D D CP Q CP Q CP Q CP Q CP Q CP Q CP Q CP Q CP Q CP Q nCP nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 nQ8 nQ9 001aad156 Fig. 3. Logic diagram VCC VCC 27 Ω output 27 Ω 001aac372 Fig. 4. Schematic of each output 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 2 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 5. Pinning information 5.1. Pinning 74ALVT162821 1OE 1 56 1CP 1Q0 2 55 1D0 1Q1 3 54 1D1 GND 4 53 GND 1Q2 5 52 1D2 1Q3 6 51 1D3 VCC 7 50 VCC 1Q4 8 49 1D4 1Q5 9 48 1D5 1Q6 10 47 1D6 GND 11 46 GND 1Q7 12 45 1D7 1Q8 13 44 1D8 1Q9 14 43 1D9 2Q0 15 42 2D0 2Q1 16 41 2D1 2Q2 17 40 2D2 GND 18 39 GND 2Q3 19 38 2D3 2Q4 20 37 2D4 2Q5 21 36 2D5 VCC 22 35 VCC 2Q6 23 34 2D6 2Q7 24 33 2D7 GND 25 32 GND 2Q8 26 31 2D8 2Q9 27 30 2D9 2OE 28 29 2CP aaa-028101 Fig. 5. Pin configuration SOT364-1 (TSSOP56) 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 3 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description 1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7, 1D8, 1D9 55, 54, 52, 51, 49, 48, 47, 45, 44, 43 data inputs 1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7, 1Q8, 1Q9 2, 3, 5, 6, 8, 9, 10, 12, 13, 14 data outputs 2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7, 2D8, 2D9 42, 41, 40, 38, 37, 36, 34, 33, 31, 30 data inputs 2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7, 2Q8, 2Q9 15, 16, 17, 19, 20, 21, 23, 24, 26, 27 data outputs 1OE, 2OE 1, 28 output enable inputs (active LOW) 1CP, 2CP 56, 29 clock pulse inputs (active rising edge) GND 4, 11, 18, 25, 32, 39, 46, 53 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; NC = no change; X = don’t care; Z = high-impedance OFF-state; ↑ = LOW-to-HIGH clock transition. Operating mode Load and read register Internal register Output Input nOE nCP nDn nQn L ↑ l L L L ↑ h H H Hold L NC X NC NC Disable outputs H NC X NC Z H ↑ nDn nDn Z 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 4 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V [1] -1.2 +7.0 V [1] VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state -0.5 +7.0 V IIK input clamping current VI < 0 V - -50 mA IOK output clamping current VO < 0 V - -50 mA IO output current output in LOW-state - 128 mA output in HIGH-state - -64 mA -65 +150 °C - 150 °C Tstg storage temperature Tj junction temperature [1] [2] [2] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC = 2.5 V ± 0.2 V VCC = 3.3 V ± 0.3 V Unit Min Max Min Max 2.3 2.7 3.0 3.6 V VCC supply voltage VI input voltage 0 5.5 0 5.5 V IOH HIGH-level output current - -8 - -12 mA IOL LOW-level output current none - 12 - 12 mA Δt/ΔV input transition rise and fall rate outputs enabled - 10 - 10 ns/V Tamb ambient temperature free-air -40 +85 -40 +85 °C 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; Tamb = -40 °C to +85 °C; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit - -0.85 -1.2 V VCC = 2.5 V ± 0.2 V VIK input clamping voltage VCC = 2.3 V; IIK = -18 mA VIH HIGH-level input voltage 1.7 - - V VIL LOW-level input voltage - - 0.7 V VOH HIGH-level output voltage VCC = 2.3 V to 3.6 V; IO = -100 μA VCC - 0.2 VCC - V 1.8 2.1 - V LOW-level output voltage VCC = 2.3 V; IO = 100 μA - 0.07 0.2 V VCC = 2.3 V; IO = 24 mA - 0.3 0.5 V VCC = 2.3 V; IO = 8 mA - - 0.4 V - - 0.55 V VCC = 2.3 V; IO = -8 mA VOL VOL(pu) power-up LOW-level output voltage 74ALVT162821 Product data sheet VCC = 2.7 V; IO = 1 mA; VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 [2] © Nexperia B.V. 2020. All rights reserved 5 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state Symbol Parameter Conditions II all input pins input leakage current Min Typ[1] Max - 0.1 10 μA - 0.1 ±1 μA VCC = 2.7 V; VI = VCC - 0.1 1 μA VCC = 2.7 V; VI = 0 V - 0.1 -5 μA VCC = 0 V or 2.7 V; VI = 5.5 V Unit control pins VCC = 2.7 V; VI = VCC or GND data pins; [3] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V - 0.1 ±100 μA IBHL bus hold LOW current data inputs; VCC = 2.3 V; VI = 0.7 V - 90 - μA IBHH bus hold HIGH current data inputs; VCC = 2.3 V; VI = 1.7 V - -10 - μA IEX external current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 2.3 V - 10 125 μA - 1 ±100 μA output HIGH-state; VO = 2.3 V - 0.5 5 μA output LOW-state; VO = 0.5 V - 0.5 -5 μA outputs HIGH-state - 0.04 0.1 mA outputs LOW-state - 2.3 4.5 mA 0.04 0.1 mA - 0.04 0.4 mA IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ VCC = 2.7 V; VI = VIL or VIH ICC OFF-state output current supply current [4] VCC = 2.7 V; VI = GND or VCC; IO = 0 A outputs disabled [5] ΔICC additional supply current per input pin; VCC = 2.3 V to 2.7 V; one input at VCC - 0.6 V; other inputs at VCC or GND [6] CI input capacitance VI = 0 V or VCC - 3 - pF CO output capacitance VO = 0 V or VCC - 9 - pF VCC = 3.0 V; IIK = -18 mA - -0.85 -1.2 V VCC = 3.3 V ± 0.3 V VIK input clamping voltage VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V VOH HIGH-level output voltage VCC = 3.0 V to 3.6 V; IO = -100 μA VCC - 0.2 VCC - V 2.0 2.3 - V IO = 100 μA - 0.07 0.2 V IO = 16 mA - 0.25 0.4 V IO = 32 mA - 0.3 0.5 V IO = 64 mA - 0.4 0.55 V - - 0.55 V VCC = 3.0 V; IO = -32 mA VOL VOL(pu) LOW-level output voltage VCC = 3.0 V power-up LOW-level output voltage 74ALVT162821 Product data sheet VCC = 3.6 V; IO = 1 mA; VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 [2] © Nexperia B.V. 2020. All rights reserved 6 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state Symbol Parameter Conditions II all input pins; input leakage current Min Typ[1] Max - 0.1 10 μA - 0.1 ±1 μA VCC = 3.6 V; VI = VCC - 0.5 1 μA VCC = 3.6 V; VI = 0 V - 0.1 -5 μA VCC = 0 V or 3.6 V; VI = 5.5V Unit control pins VCC = 3.6 V; VI = VCC or GND data pins; [3] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V - 0.1 ±100 μA IBHL bus hold LOW current data inputs; VCC = 3 V; VI = 0.8 V 75 130 - μA IBHH bus hold HIGH current data inputs; VCC = 3 V; VI = 2.0 V -75 -140 - μA IBHLO bus hold LOW overdrive current data inputs; VCC = 3.6 V; VI = 0 V to 3.6 V [7] 500 - - μA IBHHO bus hold HIGH overdrive current data inputs; VCC = 3.6 V; VI = 0 V to 3.6 V [7] -500 - - μA IEX external current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V - 10 125 μA - 1 ±100 μA output HIGH-state; VO = 3.0 V - 0.5 5 μA output LOW-state; VO = 0.5 V - 0.5 -5 μA outputs HIGH-state - 0.07 0.1 mA outputs LOW-state - 5.1 7 mA [5] - 0.07 0.1 mA [6] - 0.04 0.4 mA IO(pu/pd) power-up/power-down output current VCC ≤ 1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ VCC = 3.6 V; VI = VIL or VIH OFF-state output current ICC supply current [8] VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs disabled ΔICC additional supply current per input pin; VCC = 3 V to 3.6 V; one input at VCC - 0.6 V; other inputs at VCC or GND CI input capacitance VI = 0 V or VCC - 3 - pF CO output capacitance VO = 0 V or VCC - 9 - pF [1] [2] [3] [4] [5] [6] [7] [8] All typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C. All typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C. For valid test results, data must not be loaded into the flip-flops (or latches) after applying power. Unused pins at VCC or GND. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to (2.5 ± 0.2) V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. ICC with outputs disabled is measured with outputs pulled to VCC or GND. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. This is the bus hold overdrive current required to force the input to the opposite logic state. This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1,2 V to (3.3 ± 0.3) V a transition time of 100 μs is permitted. This parameter is valid for Tamb = 25 °C only. 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 7 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); Tamb = -40 °C to +85 °C; for test circuit see Fig. 9. Symbol Parameter Conditions Min Typ[1] Max Unit VCC = 2.5 V ± 0.2 V tPLH LOW to HIGH propagation delay nCP to nQn; see Fig. 6 1.0 4.4 7.0 ns tPHL HIGH to LOW propagation delay nCP to nQn; see Fig. 6 1.0 3.8 6.4 ns tPZH OFF-state to HIGH propagation delay nOE to nQn; see Fig. 8 1.5 4.6 7.5 ns tPZL OFF-state to LOW propagation delay nOE to nQn; see Fig. 8 1.0 2.8 4.6 ns tPHZ HIGH to OFF-state propagation delay nOE to nQn; see Fig. 8 1.5 3.5 5.5 ns tPLZ LOW to OFF-state propagation delay nOE to nQn; see Fig. 8 1.0 3.7 5.7 ns tsu set-up time nDn to nCP HIGH; see Fig. 7 1.5 0.1 - ns nDn to nCP LOW; see Fig. 7 2.0 0.5 - ns nDn to nCP HIGH; see Fig. 7 0.3 -0.5 - ns nDn to nCP LOW; see Fig. 7 0.5 -0.1 th hold time ns tW pulse width nCP HIGH or LOW; see Fig. 6 1.5 - - ns fmax maximum frequency nCP; see Fig. 6 150 - - MHz VCC = 3.3 V ± 0.3 V tPLH LOW to HIGH propagation delay nCP to nQn; see Fig. 6 1.0 3.2 5.0 ns tPHL HIGH to LOW propagation delay nCP to nQn; see Fig. 6 1.0 3.2 4.7 ns tPZH OFF-state to HIGH propagation delay nOE to nQn; see Fig. 8 1.0 3.4 5.6 ns tPZL OFF-state to LOW propagation delay nOE to nQn; see Fig. 8 0.5 2.3 3.7 ns tPHZ HIGH to OFF-state propagation delay nOE to nQn; see Fig. 8 1.5 3.7 5.4 ns tPLZ LOW to OFF-state propagation delay nOE to nQn; see Fig. 8 1.5 3.0 4.3 ns tsu set-up time nDn to nCP HIGH or LOW; see Fig. 7 1.5 0.1 - ns th hold time HIGH nDn to nCP HIGH or LOW; see Fig. 7 0.5 0.1 - ns tW pulse width nCP HIGH or LOW; see Fig. 6 1.5 - - ns fmax maximum frequency nCP; see Fig. 6 150 - - MHz [1] All typical values for VCC = 2.5 V ± 0.2 V are measured at VCC = 2.5 V and Tamb = 25 °C. All typical values for VCC = 3.3 V ± 0.3 V are measured at VCC = 3.3 V and Tamb = 25 °C. 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 8 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 10.1. Waveforms and test circuit 1/fmax VI nCP input VM VM GND tW t PHL t PLH VOH VM nQn output VOL 001aaa256 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delay clock input (nCP) to output (nQn), clock pulse (nCP) width and maximum clock frequency VI VM nCP input GND t su t su th th VI VM nDn input GND VOH VM nQn output VOL 001aaa257 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig. 7. Set-up times and hold times from input (nDn) to clock (nCP) 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 9 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state VI nOE input VM VM GND tPLZ nQn output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPZH tPHZ nQn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. OFF-state to HIGH and LOW propagation delays and LOW and HIGH to OFF-state propagation delays Table 8. Measurement points VCC Input Output VI VM VM VX VY VCC ≤ 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V VCC ≥ 3.0 V 3.0 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 10 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 9. Test circuit for measuring switching times Table 9. Test data Input VI Load fi 3.0 V or VCC ≤ 10 MHz whichever is less 74ALVT162821 Product data sheet VEXT tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL 500 ns ≤ 2.5 ns 50 pF 500 Ω GND 6 V or VCC x 2 open All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © tPLH, tPHL Nexperia B.V. 2020. All rights reserved 11 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 11. Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 10. Package outline SOT364-1 (TSSOP56) 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 12 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge MIL Military MM Machine Model MOS Metal Oxide Semiconductor 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVT162821 v.5 20201019 Product data sheet - Modifications: • • • 74ALVT162821 v.4 20180124 Modifications: • • 74ALVT162821 v.4 Type number 74ALVT162821DGG (SOT371-1 / SSOP56) removed. Section 1 and Section 2 updated. Table 4: Derating values for Ptot total power dissipation updated. Product data sheet - 74ALVT162821 v.3 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74ALVT162821 v.3 19981002 Product data sheet - 74ALVT162821 v.2 74ALVT162821 v.2 19980213 Product specification - 74ALVT162821 v.1 74ALVT162821 v.1 19971117 Product specification - - 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 13 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ALVT162821 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 14 / 15 74ALVT162821 Nexperia 20-bit bus interface D-type flip-flop; positive-edge trigger with 30 Ω termination resistors; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 4 6. Functional description................................................. 4 7. Limiting values............................................................. 5 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit........................................ 9 11. Package outline........................................................ 12 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 October 2020 74ALVT162821 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2020 © Nexperia B.V. 2020. All rights reserved 15 / 15
74ALVT162821DGGS 价格&库存
很抱歉,暂时无法提供与“74ALVT162821DGGS”相匹配的价格&库存,您可以联系我们找货
