DSK12
DSK12
    LGE(鲁光)
    SMF(SOD-123FL)
    鲁光 SOD-123FL Io: 1A IR: 0.5mA VF: 0.55V
DSK12 数据手册
DSK12-DSK120 Surface Mount Schottky Rectifier SOD-123FL Features  Low profile package  Ideal for automated placement  Ultrafast reverse recovery time  Low power losses, high efficiency  Low forward voltage drop  High surge capability  High temperature soldering: 0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70) 0.114(2.9) 0.098(2.5) 0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) 260℃/10 seconds at terminals  Component in accordance to 0.030(0.76) 0.018(0.45) RoHS 2002/95/1 and WEEE 2002/96/EC Mechanical Date  Case: JEDEC SOD-123FL molded plastic 0.154(3.9) 0.138(3.5) body over passivated chip  Dimensions in inches and(millimeters) Terminals: Solder plated, solderable per J-STD-002B and JESD22-B102D  Polarity: Laser band denotes cathode end Maximum Ratings & Thermal Characteristics & Electrical Characteristics (TA = 25 °C unless otherwise noted) SYMBOLS DSK12 DSK13 DSK14 MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C TA=100 C at rated DC blocking voltage Typical junction capacitance (NOTE 1) Operating junction temperature range Storage temperature range VRRM VRMS VDC DSK15 DSK16 DSK17 DSK18 DSK19 DSK110 DSK115 DSK120 20 30 40 50 60 70 80 90 100 150 200 14 21 28 35 42 49 56 63 70 105 140 20 30 40 50 60 70 80 90 100 150 I(AV) 1.0 IFSM 25.0 VF 0.55 CJ 0.85 0.70 5.0 10.0 80 110 TJ TSTG -65 to +125 -65 to +150 -65 to +150 VOLTS VOLTS 200 VOLTS Amp Amps 0.5 IR UNITS 0.95 0.2 2.0 Volts mA pF C C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com DSK12-DSK120 Surface Mount Schottky Rectifier PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Characteristic Curves (TA=25 ℃ unless otherwise noted) FIG. 1- FORWARD CURRENT DERATING CURVE 1 0.8 Single Phase Half Wave 60Hz Resistive or inductive Load 0.6 0.4 DSK12-DSK16 DSK17-DSK120 0.2 0 0 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 25 20 15 10 5.0 2 0 1 AMBIENT TEMPERATURE, C INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE DSK12-DSK14 DSK15-DSK16 DSK17-DSK115 DSK120 0.1 0.01 0.2 0.4 0.6 0.8 1.0 100 10 NUMBER OF CYCLES AT 60 Hz 1.1 FIG. 4-TYPICAL REVERSE CHARACTERISTICS 100 10 TJ=100 C 1 TJ=75 C 0.1 TJ=25 C 0.01 0.001 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 1000 DSK12-DSK14 DSK15-DSK120 100 TJ=25 C 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
DSK12 价格&库存
很抱歉,暂时无法提供与“DSK12”相匹配的价格&库存,您可以联系我们找货
