DSK210
DSK210
    LGE(鲁光)
    SMF(SOD-123FL)
    肖特基二极管 SOD123FL 反向电压 - 20 to 200 V 正向电流 - 3.0 A
DSK210 数据手册
DSK22-DSK220 Surface Mount Schottky Rectifier SOD-123FL Features  Low profile package  Ideal for automated placement  Ultrafast reverse recovery time  Low power losses, high efficiency  Low forward voltage drop  High surge capability  0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70) 0.114(2.9) 0.098(2.5) 0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) High temperature soldering: 260℃/10 seconds at terminals  Component in accordance to 0.030(0.76) 0.018(0.45) RoHS 2002/95/1 and WEEE 2002/96/EC Mechanical Date  Case: JEDEC SOD-123FL molded plastic 0.154(3.9) 0.138(3.5) body over passivated chip  Terminals: Solder plated, solderable per Dimensions in inches and(millimeters) J-STD-002B and JESD22-B102D  Polarity: Laser band denotes cathode end  Weight: 0.017gram Maximum Ratings & Thermal Characteristics & Electrical Characteristics (TA = 25 °C unless otherwise noted) SYMBOLS DSK22 DSK23 DSK24 DSK25 DSK26 DS K27 DSK 28 DSK29 DSK210 DSK215 DSK220 Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Operating junction temperature range Storage temperature range 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 70 49 70 80 56 80 90 63 90 100 70 100 150 83 150 200 90 200 UNITS I(AV) 2.0 VOLTS VOLTS VOLTS Amp IFSM 40.0 Amps VRRM VRMS VDC VF 0.70 0.55 0.85 0.5 IR CJ mA 10.0 5.0 80 pF -65 to +125 -65 to +150 C C 220 TJ TSTG Volts -65 to +150 Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com DSK22-DSK220 Surface Mount Schottky Rectifier Characteristic Curves (TA=25 ℃ unless otherwise noted) PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
DSK210 价格&库存
很抱歉,暂时无法提供与“DSK210”相匹配的价格&库存,您可以联系我们找货
DSK210
    • 1+0.22210
    库存:10
    DSK210
    • 1+0.16119
    • 10+0.14819
    • 30+0.14559
    • 100+0.13779
