MBR1035CT-MBR10200CT
10.0AMP. Schottky Barrier Rectifiers
TO-220AB
Features
Plastic material used carries Underwriters
Laboratory Classifications 94V-0
Metal silicon junction, majority carrier conduction
Low power loss, high efficiency
High current capability, low forward voltage drop
High surge capability
For use in low voltage, high frequency inverters, free
wheeling, and polarity protection applications
Guardring for overvoltage protection
High temperature soldering guaranteed:
260oC/10 seconds,0.25”(6.35mm)from case
Mechanical Data
Cases: JEDEC TO-220AB molded plastic body
Polarity: As marked
Mounting position: Any
Mounting torque: 5 in. - lbs. max
Weight: 0.08 ounce, 2.24 grams
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
at Tc=125OC
Peak Repetitive Forward Current (Rated VR,
Square Wave, 20KHz) at Tc=125oC
Peak Forward Surge Current, 8.3 ms Single Half
Sine-wave Superimposed on Rated Load
(JEDEC method )
Peak Repetitive Reverse Surge Current (Note 1)
Maximum Instantaneous Forward Voltage at:
(Note 2)
IF=5A, TC=25oC
IF=5A, TC=125oC
o
IF=10A, TC=25 C
IF=10A, TC=125oC
Maximum Instantaneous Reverse Current
@ Tc =25 oC at Rated DC Blocking Voltage
(Note 2)
@ Tc=125 oC
Symbol
VRRM
VRMS
VDC
I(AV)
50
35
50
60
42
60
90
63
90
10
100
70
100
150
105
150
200
140
200
V
V
V
A
A
IFSM
120
A
IRRM
VF
1.0
0.70
0.57
0.80
0.67
0.80
0.65
0.90
0.75
15
10
IR
dV/dt
RθJC
TJ
TSTG
Notes:
45
31
45
32
Maximum Typical Thermal Resistance (Note 3)
Storage Temperature Range
35
24
35
Units
IFRM
Voltage Rate of Change (Rated VR)
Operating Junction Temperature Range
MBR MBR MBR MBR MBR MBR MBR MBR
1035 1045 1050 1060 1090 10100 10150 10200
CT
CT
CT
CT
CT
CT
CT
CT
0.5
0.85
0.75
0.95
0.85
0.88
0.78
0.98
0.88
0.1
10,000
1.5
-65 to +150
-65 to +175
2.0
A
V
mA
mA
V/uS
o
C/W
o
C
o
C
1. 2.0us Pulse Width, f=1.0 KHz
2. Pulse Test: 300us Pulse Width, 1% Duty Cycle
3. Thermal Resistance from Junction to Case Per Leg, Mount on Heatsink Size of 2 in x 3 in x 0.25in
Al-Plate.
- 108 -
RATINGS AND CHARACTERISTIC CURVES (MBR1035CT THRU MBR10200CT)
FIG.1- FORWARD CURRENT DERATING CURVE
FIG.2- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
180
RESISTIVE OR
INDUCTIVE LOAD
PEAK FORWARD SURGE CURRENT. (A)
AVERAGE FORWARD CURRENT. (A)
6
5
4
3
2
1
Tj=Tj max.
8.3ms Single Half Sine-Wave
JEDEC Method
150
120
90
60
30
100
o
CASE TEMPERATURE. ( C)
100
NUMBER OF CYCLES AT 60Hz
FIG.3- TYPICAL FORWARD CHARACTERISTICS
FIG.4- TYPICAL REVERSE CHARACTERISTICS
200
50
MBR1035CT-1045CT
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
10
INSTANTANEOUS REVERSE CURRENT. (mA)
100
INSTANTANEOUS FORWARD CURRENT. (A)
10
1
150
50
10
MBR1050CT-1060CT
MBR1090CT-10100CT
5
1
MBR1035CT-1045CT
MBR10150CT-10200CT
Tj=125 0C
MBR1050CT-1060CT
1
Tj=75 0C
0.1
0.01
MBR1090CT-10200CT
Tj=25 0C
0.1
0.001
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
FORWARD VOLTAGE. (V)
FIG.6- TYPICAL TRANSIENT THERMAL
CHARACTERISTICS PER LEG
FIG.5- TYPICAL JUNCTION CAPACITANCE
TRANSIENT THERMAL IMPEDANCE. ( OC/W)
JUNCTION CAPACITANCE.(pF)
5,000
Tj=25 0C
f=1.0MHz
Vsig=50mVp-p
1,000
500
100
0.1
1.0
10
REVERSE VOLTAGE. (V)
100
100
10.0
1
0.1
0.01
0.1
1
T, PULSE DURATION. (sec)
10
100
很抱歉,暂时无法提供与“MBR10150CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.78416
- 50+1.38824
- 150+1.23660
- 500+1.04750
- 2500+0.96326
- 5000+0.91260
