MBR10200CT
MBR10200CT
    LGE(鲁光)
    TO220AB
    电压:200V 电流:10A
MBR10200CT 数据手册
MBR1035CT-MBR10200CT 10.0AMP. Schottky Barrier Rectifiers TO-220AB Features         Plastic material used carries Underwriters Laboratory Classifications 94V-0 Metal silicon junction, majority carrier conduction Low power loss, high efficiency High current capability, low forward voltage drop High surge capability For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Guardring for overvoltage protection High temperature soldering guaranteed: 260oC/10 seconds,0.25”(6.35mm)from case Mechanical Data      Cases: JEDEC TO-220AB molded plastic body Polarity: As marked Mounting position: Any Mounting torque: 5 in. - lbs. max Weight: 0.08 ounce, 2.24 grams Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25 oC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at Tc=125OC Peak Repetitive Forward Current (Rated VR, Square Wave, 20KHz) at Tc=125oC Peak Forward Surge Current, 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method ) Peak Repetitive Reverse Surge Current (Note 1) Maximum Instantaneous Forward Voltage at: (Note 2) IF=5A, TC=25oC IF=5A, TC=125oC o IF=10A, TC=25 C IF=10A, TC=125oC Maximum Instantaneous Reverse Current @ Tc =25 oC at Rated DC Blocking Voltage (Note 2) @ Tc=125 oC Symbol VRRM VRMS VDC I(AV) 50 35 50 60 42 60 90 63 90 10 100 70 100 150 105 150 200 140 200 V V V A A IFSM 120 A IRRM VF 1.0 0.70 0.57 0.80 0.67 0.80 0.65 0.90 0.75 15 10 IR dV/dt RθJC TJ TSTG Notes: 45 31 45 32 Maximum Typical Thermal Resistance (Note 3) Storage Temperature Range 35 24 35 Units IFRM Voltage Rate of Change (Rated VR) Operating Junction Temperature Range MBR MBR MBR MBR MBR MBR MBR MBR 1035 1045 1050 1060 1090 10100 10150 10200 CT CT CT CT CT CT CT CT 0.5 0.85 0.75 0.95 0.85 0.88 0.78 0.98 0.88 0.1 10,000 1.5 -65 to +150 -65 to +175 2.0 A V mA mA V/uS o C/W o C o C 1. 2.0us Pulse Width, f=1.0 KHz 2. Pulse Test: 300us Pulse Width, 1% Duty Cycle 3. Thermal Resistance from Junction to Case Per Leg, Mount on Heatsink Size of 2 in x 3 in x 0.25in Al-Plate. - 108 - MBR1035CT-MBR10200CT 10.0AMP. Schottky Barrier Rectifiers RATINGS AND CHARACTERISTIC CURVES (MBR1035CT THRU MBR10200CT) FIG.1- FORWARD CURRENT DERATING CURVE FIG.2- MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 180 RESISTIVE OR INDUCTIVE LOAD PEAK FORWARD SURGE CURRENT. (A) AVERAGE FORWARD CURRENT. (A) 6 5 4 3 2 1 Tj=Tj max. 8.3ms Single Half Sine-Wave JEDEC Method 150 120 90 60 30 0 0 0 50 100 o CASE TEMPERATURE. ( C) 100 NUMBER OF CYCLES AT 60Hz FIG.3- TYPICAL FORWARD CHARACTERISTICS FIG.4- TYPICAL REVERSE CHARACTERISTICS 200 50 MBR1035CT-1045CT Tj=25oC Pulse Width=300 s 1% Duty Cycle 10 INSTANTANEOUS REVERSE CURRENT. (mA) 100 INSTANTANEOUS FORWARD CURRENT. (A) 10 1 150 50 10 MBR1050CT-1060CT MBR1090CT-10100CT 5 1 MBR1035CT-1045CT MBR10150CT-10200CT Tj=125 0C MBR1050CT-1060CT 1 Tj=75 0C 0.1 0.01 MBR1090CT-10200CT Tj=25 0C 0.1 0.001 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE. (%) FORWARD VOLTAGE. (V) FIG.6- TYPICAL TRANSIENT THERMAL CHARACTERISTICS PER LEG FIG.5- TYPICAL JUNCTION CAPACITANCE TRANSIENT THERMAL IMPEDANCE. ( OC/W) JUNCTION CAPACITANCE.(pF) 5,000 Tj=25 0C f=1.0MHz Vsig=50mVp-p 1,000 500 100 0.1 1.0 10 REVERSE VOLTAGE. (V) 100 100 10.0 1 0.1 0.01 0.1 1 T, PULSE DURATION. (sec) 10 100
