SR102 0 THRU SR102 00
10.0 AMP.Schottky Barrier Rectifiers
Features
· Metal silicon rectifier,majority carrier conduction
DO-201AD
· Guard ring for transient protection
· Low power loss,high efficiency
· High surge capability
0.96(24.5)
MIN.
· High current capability,low VF
· For use in low voltage,high frequency inverters,free
DIA.
wheeling,and polarity protection applications
· Plastic material-UL flammability 94V-0
Mechanical Data
0.96(24.5)
DIA.
MIN.
· Case: Molded plastic DO-201AD
· Polarity: Color band dentes cathode end
· Mounting Position: Any
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified
Single phase,half wave,60Hz,resistive or inductive load
For capacitive load derate current by 20%
Type Number
SYMBOL
Maximum Recurrent Peak Reverse Voltage
VRRM
SR
SR
SR
SR
SR SR SR SR SR SR
Unit
1020 1030 1040 1045 1050 1060 1080 10100 10150 10200
40
45
50
60
80
100
150
200
V
28
31.5
35
42
56
70
105
140
V
40
45
50
60
80
100
150
200
V
Maximum RMS Voltage
VRMS
14
21
Maximum DC Blocking Voltage
VDC
Maximum Average Forward Rectified
IF(AV)
Current.375"(9.5mm) lead length@TL =100℃
Peak Forward Surge Current 8.3ms Single half
sine-wave superimposed on rated load (JEDEC IFSM
Method)
I2t Rating for Fusing (t < 8.3ms)
I 2t
Forward Voltage
@IF=10.0A(Note 1)
Peak Reverse Current
@TA=25℃
At Rated DC Blocking Voltage @TA=100℃
Typical Junction Capacitance (Note2)
Typical Thermal Resistance Junction to case
Operating Temperature Range
/Storage Temperature Range
VFM
A
150
A
93.375
A2s
0.7
0.55
IR
10.0
0.92
0.85
0.3
0.05
10
5
V
mA
CJ
450
pF
RθJA
3.0
℃/W
TJ
-55 to +150
T STG
-55 to +150
Note:1. 300us Pulse Width,2%Duty Cycle
2. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
FIG.2-TYPICAL FORWARD CHARACTERISTICS
100
12
INSTANTANEOUS FORWARD CURRENT(A)
AVERAGE FORWARD CURRENT AMPERES (A)
FIG.1-FORWARD CURRENT DERATING CURVE
10
8
6
4
2
75
100
125
150
175
SR1020-SR1045
10
SR1050-SR106
SR1080-SR10100
1
SR10150-SR1020
TJ=25℃
PULSE WIDTH 300US
2%DUTY CYCLE
0.1
0.2
LEAD TEMPERATURE( OC)
160
120
80
8.3Single Half-Sine-Wave
(JEDEC METOD)
10
100
INSTANTANEOUS REVERSE CURRENT(mA)
PEAK FORWARD SURGE CURRENT AMPERES (A)
200
2
0.7
0.8
1.2
1.0
0.9
100
10
TA=100℃
1
0.1
TA=50℃
0.01
TA=25℃
NUMBER OF CYCLES AT 60Hz
ht t p : //
0.6
FIG.4-TYPICAL REVERSE CHARACTERISTICS
240
1
0.5
INSTANTANEOUS FORWARD ( V )
FIG.3-MAXIMUM NON-REPETITVE SURGE
40
0.4
0.3
75
100
125
150
175
PERCENT OF RATED PEAK REVERSE ( % )
www.lgesemi .c o m
很抱歉,暂时无法提供与“SR10200”相匹配的价格&库存,您可以联系我们找货
