SR2100S
SR2100S
    LGE(鲁光)
    DO-41(DO-204AL)
    鲁光 DO-41 Io: 2A IR: 1mA VF: 0.85V
SR2100S 数据手册
SR220S-SR2200S 2.0 AMP Schottky Barrier Rectifiers VOLTAGE RANGE: 20 --- 200 V CURRENT: 2.0 A Features — — — — — Metal-Semiconductor junction with guard ring Epitaxial construction Low forward voltage drop,low switching losses DO-41 High surge capability For use in low voltage,high frequency inverters free wheeling,and polarity protection applications — The plastic material carries U/L recognition 94V-0 Mechanical Data — Case:JEDEC DO--15,molded plastic — Terminals: Axial lead ,solderable per MIL- STD-750,Method 2026 — Polarity: Color band denotes cathode — Weight: 0.014ounces,0.39 grams — Mounting position: Any .028(.71) .027(.69) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%. SR220S SR230S SR240S SR250S SR260S SR280SSR2100S SR2150S SR2200S UNITS Maximum recurrent peak reverse voltage VRRM 20 30 40 50 60 80 100 100 100 V Maximum RMS voltage VRMS 14 21 28 35 42 56 70 70 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 100 100 100 V Maximum average forw ard rectified current 9.5mm lead length, @TA=75 IF(AV) 2.0 A IFSM 50.0 A Peak forw ard surge current 8.3ms single half-sine-w ave superimposed on rated load @TJ =125 Maximum instantaneous forw ard voltage @ 2.0A (Note 1) Maximum reverse current VF @TA=25 0.55 0.85 1.0 IR at rated DC blocking voltage @TA=100 0.7 10.0 Typical junction capacitance (Note2) CJ 170 Typical thermal resistance (Note3) RθJA 35 TJ - 55 ---- + 150 TSTG - 55 ---- + 150 Operating junction temperature range Storage temperature range V mA pF /W NOTE: 1. Pulse test:300us pulse width,1% duty cy cle. 2. Measured at 1.0MHz and applied rev erse v oltage of 4.0V DC. 3.Thermal resistance junction to ambient ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SR220S-SR2200S 2.0 AMP Schottky Barrier Rectifiers Ratings AND Charactieristic Curves FIG.2 -- PEAK FORWARD SURGE CURRENT 1.5 Resistive or Inductive Load 0.375"(9.5mm) Lead Length 1.0 0.5 0 0 25 50 75 100 125 150 175 50 40 AMPERES PEAK FORWARD SURGE CURRENT 2.0 AMPERES AVERAGE FORWARD RECTIFIED CURRENT FIG.1 -- FORWARD CURRENT DERATING CURVE 30 20 10 0 1 LEAD TEMPERATURE, 10 100 NUMBER OF CYCLES AT 60Hz FIG.3 -- TYPICAL INSTANTANEOUS FORWARD XXXXXXXXX----CHARACTERISTICS FIG.4 -- TYPICAL JUNCTION CAPACITANCE 50 SR220S - SR240S 400 SR280S - SR2200S 1 SR250S - SR260S 0.1 Pulse Width=300µs 1% DUTY CYCLE 0.01 0 0.2 0.4 0.6 0.8 1.0 100 TJ=25℃ f=1.0MHz Vsig=50mVp-p 10 0.1 1 10 100 1.2 1.4 1.6 REVERSE VOLTAGE,VOLTS INSTANTANEOUS FORWARD VOLTAGE, VOLTS PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG DO-41 5000/AMMO 50000 42X28X31 14.00 12.00 ht t p : // Revision:20170701-P1 CAPACITANCE,pF 10 AMPERES INSTANTANEOUS FORWARD CURRENT TJ=TJMAX 8.3ms Single Half Sine-Wave www.lgesemi .c o m mail:lge@lgesemi.com
SR2100S 价格&库存
很抱歉,暂时无法提供与“SR2100S”相匹配的价格&库存,您可以联系我们找货
