74AUP1G175GW,125
74AUP1G175GW,125
    NEXPERIA(安世)
    SOT-363
    Nexperia SC-88 1Channel 1.4μA 3.6V 2.20 x 1.35mm
74AUP1G175GW,125 数据手册
74AUP1G175 Low-power D-type flip-flop with reset; positive-edge trigger Rev. 5 — 3 July 2012 Product data sheet 1. General description The 74AUP1G175 provides a low-power, low-voltage positive-edge triggered D-type flip-flop with individual data (D) input, clock (CP) input, master reset (MR) input, and Q output. The master reset (MR) is an asynchronous active LOW input and operates independently of the clock input. Information on the data input is transferred to the Q output on the LOW-to-HIGH transition of the clock pulse. The D input must be stable one set-up time prior to the LOW-to-HIGH clock transition, for predictable operation. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C Downloaded from Arrow.com. 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1G175GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1G175GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP1G175GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP1G175GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP1G175GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AUP1G175GW aT 74AUP1G175GM aT 74AUP1G175GF aT 74AUP1G175GN aT 74AUP1G175GS aT [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 6 3 MR FF 1 1 D Q 4 3 CP 6 CP D MR 001aaa468 Fig 1. Logic symbol 74AUP1G175 Product data sheet Downloaded from Arrow.com. 4 Q 001aaa469 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 2 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger C CP C C Q C C C C C D C C MR Fig 3. 001aaa466 Logic diagram 6. Pinning information 6.1 Pinning 74AUP1G175 74AUP1G175 CP 1 6 CP 1 6 MR GND 2 5 VCC 74AUP1G175 MR GND 2 5 VCC D 3 4 Q D 4 Q 1 6 MR GND 2 5 VCC D 3 4 Q 001aae246 001aab657 Transparent top view Transparent top view 001aaa467 Fig 4. Pin configuration SOT363 3 CP Fig 5. Pin configuration SOT886 Fig 6. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description CP 1 clock input (LOW-to-HIGH, edge-triggered) GND 2 ground (0 V) D 3 data input Q 4 flip-flop output VCC 5 supply voltage MR 6 master reset input (active LOW) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 3 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 7. Functional description Table 4. Function table[1] Operating mode Input Output MR CP D Q Reset (clear) L X X L Load ‘1’ H  h H Load ‘0’ H  l L [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition;  = LOW-to-HIGH CP transition; X = don’t care. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 +4.6 V - 20 mA VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW Tamb = 40 C to +125 C [2] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 4 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC Conditions Min Max Unit supply voltage 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C - 200 ns/V Typ Max Unit Tamb ambient temperature t/V input transition rise and fall rate VCC = 0.8 V to 3.6 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74AUP1G175 Product data sheet Downloaded from Arrow.com. VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V VI = VIH or VIL IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 5 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.8 - pF CO output capacitance VO = GND; VCC = 0 V - 1.7 - pF VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - V V [1] Tamb = 40 C to +85 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage - VCC = 3.0 V to 3.6 V 2.0 - - VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V - - 0.5 A VI = VIH or VIL VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 6 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A [1] Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage LOW-level output voltage VOL VCC = 0.8 V 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A [1] [1] One input at VCC  0.6 V, other input at VCC or GND. 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 7 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 21.1 - - - - ns VCC = 1.1 V to 1.3 V 2.4 5.9 11.7 2.2 11.9 12.0 ns VCC = 1.4 V to 1.6 V 2.0 4.1 6.8 1.8 7.3 7.6 ns VCC = 1.65 V to 1.95 V 1.6 3.3 5.4 1.3 5.9 6.2 ns VCC = 2.3 V to 2.7 V 1.3 2.5 3.6 1.1 4.0 4.2 ns 1.2 2.1 2.9 1.0 3.3 3.5 ns - 17.4 - - - - ns 2.4 5.2 9.7 2.2 10.0 12.0 ns CL = 5 pF tpd propagation delay CP to Q; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V MR to Q; see Figure 8 VCC = 0.8 V VCC = 1.1 V to 1.3 V fmax maximum frequency 74AUP1G175 Product data sheet Downloaded from Arrow.com. [2] VCC = 1.4 V to 1.6 V 2.3 3.8 5.2 2.1 6.4 6.6 ns VCC = 1.65 V to 1.95 V 1.8 3.1 4.9 1.7 5.4 5.6 ns VCC = 2.3 V to 2.7 V 1.8 2.6 3.6 1.5 4.0 4.0 ns VCC = 3.0 V to 3.6 V 1.6 2.4 3.1 1.3 3.3 3.6 ns VCC = 0.8 V - 50 - - - - MHz VCC = 1.1 V to 1.3 V - 200 - 170 - - MHz VCC = 1.4 V to 1.6 V - 345 - 310 - - MHz CP; see Figure 7 VCC = 1.65 V to 1.95 V - 435 - 400 - - MHz VCC = 2.3 V to 2.7 V - 550 - 490 - - MHz VCC = 3.0 V to 3.6 V - 615 - 550 - - MHz All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 8 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 24.7 - - - - ns 2.6 6.8 13.3 2.4 13.6 13.6 ns CL = 10 pF tpd propagation delay CP to Q; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 2.3 4.8 7.9 2.0 8.4 8.7 ns VCC = 1.65 V to 1.95 V 2.1 3.9 6.1 1.8 6.6 6.9 ns VCC = 2.3 V to 2.7 V 1.7 3.0 4.3 1.5 4.7 5.0 ns 1.6 2.7 3.6 1.3 4.0 4.2 ns - 21.0 - - - - ns VCC = 1.1 V to 1.3 V 2.6 6.2 11.5 2.6 11.7 13.6 ns VCC = 1.4 V to 1.6 V 2.5 4.4 6.1 2.4 7.6 7.8 ns VCC = 3.0 V to 3.6 V MR to Q; see Figure 8 [2] VCC = 0.8 V fmax maximum frequency VCC = 1.65 V to 1.95 V 2.5 3.7 5.7 2.2 6.3 6.3 ns VCC = 2.3 V to 2.7 V 2.1 3.2 4.3 1.9 4.7 4.9 ns VCC = 3.0 V to 3.6 V 2.0 3.0 3.9 1.8 4.1 4.3 ns CP; see Figure 7 VCC = 0.8 V - 50 - - - - MHz VCC = 1.1 V to 1.3 V - 190 - 150 - - MHz VCC = 1.4 V to 1.6 V - 320 - 280 - - MHz VCC = 1.65 V to 1.95 V - 420 - 310 - - MHz VCC = 2.3 V to 2.7 V - 485 - 370 - - MHz VCC = 3.0 V to 3.6 V - 550 - 410 - - MHz CL = 15 pF tpd propagation delay CP to Q; see Figure 7 [2] - 28.1 - - - - ns VCC = 1.1 V to 1.3 V VCC = 0.8 V 3.0 7.6 14.8 2.8 15.2 15.4 ns VCC = 1.4 V to 1.6 V 2.7 5.3 8.7 2.3 9.4 9.9 ns VCC = 1.65 V to 1.95 V 2.3 4.4 6.8 2.1 7.4 7.9 ns VCC = 2.3 V to 2.7 V 2.1 3.5 5.0 1.9 5.3 5.6 ns VCC = 3.0 V to 3.6 V 2.0 3.1 4.3 1.7 4.7 4.9 ns - 24.6 - - - - ns VCC = 1.1 V to 1.3 V 3.2 7.0 13.2 2.9 13.5 15.2 ns VCC = 1.4 V to 1.6 V 3.1 5.0 6.8 2.6 8.6 9.1 ns VCC = 1.65 V to 1.95 V 2.5 4.3 6.5 2.5 7.2 7.4 ns VCC = 2.3 V to 2.7 V 2.6 3.7 5.0 2.2 5.4 5.5 ns VCC = 3.0 V to 3.6 V 2.4 3.5 4.4 2.1 4.8 5.0 ns MR to Q; see Figure 8 VCC = 0.8 V 74AUP1G175 Product data sheet Downloaded from Arrow.com. [2] All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 9 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter fmax maximum frequency 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) VCC = 0.8 V - 50 - - - - MHz VCC = 1.1 V to 1.3 V - 180 - 120 - - MHz VCC = 1.4 V to 1.6 V - 300 - 190 - - MHz CP; see Figure 7 VCC = 1.65 V to 1.95 V - 405 - 240 - - MHz VCC = 2.3 V to 2.7 V - 420 - 300 - - MHz VCC = 3.0 V to 3.6 V - 480 - 320 - - MHz - 38.4 - - - - ns VCC = 1.1 V to 1.3 V 3.6 9.8 19.5 3.4 20.6 21.0 ns VCC = 1.4 V to 1.6 V 3.3 6.9 11.2 3.2 12.4 13.0 ns VCC = 1.65 V to 1.95 V 3.1 5.7 8.8 2.9 9.6 10.2 ns VCC = 2.3 V to 2.7 V 3.0 4.6 6.4 2.6 6.9 7.3 ns 2.8 4.2 5.7 2.5 6.5 6.9 ns CL = 30 pF tpd propagation delay CP to Q; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V MR to Q; see Figure 8 VCC = 0.8 V fmax maximum frequency 74AUP1G175 Product data sheet Downloaded from Arrow.com. [2] - 35.1 - - - - ns VCC = 1.1 V to 1.3 V 3.9 9.3 18.0 3.7 18.6 19.8 ns VCC = 1.4 V to 1.6 V 3.9 6.6 8.9 3.6 11.6 12.2 ns VCC = 1.65 V to 1.95 V 3.6 5.6 8.6 3.4 9.6 9.7 ns VCC = 2.3 V to 2.7 V 3.5 4.8 6.4 2.9 7.2 7.2 ns VCC = 3.0 V to 3.6 V 3.3 4.6 5.7 3.1 6.4 6.9 ns VCC = 0.8 V - 35 - - - - MHz VCC = 1.1 V to 1.3 V - 130 - 70 - - MHz VCC = 1.4 V to 1.6 V - 200 - 120 - - MHz VCC = 1.65 V to 1.95 V - 240 - 150 - - MHz VCC = 2.3 V to 2.7 V - 275 - 190 - - MHz VCC = 3.0 V to 3.6 V - 300 - 200 - - MHz CP; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 10 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) VCC = 0.8 V - 5.25 - - - - ns VCC = 1.1 V to 1.3 V - 1.6 - 1.5 - - ns VCC = 1.4 V to 1.6 V - 1.0 - 0.9 - - ns VCC = 1.65 V to 1.95 V - 0.75 - 0.7 - - ns VCC = 2.3 V to 2.7 V - 0.6 - 0.4 - - ns VCC = 3.0 V to 3.6 V - 0.55 - 0.4 - - ns VCC = 0.8 V - 9.0 - - - - ns VCC = 1.1 V to 1.3 V - 3.0 - 4.9 - - ns CL = 5 pF, 10 pF, 15 pF and 30 pF tW pulse width CP; HIGH or LOW; see Figure 7 MR; LOW; see Figure 8 trec tsu(H) tsu(L) recovery time set-up time HIGH set-up time LOW 74AUP1G175 Product data sheet Downloaded from Arrow.com. VCC = 1.4 V to 1.6 V - 1.75 - 2.5 - - ns VCC = 1.65 V to 1.95 V - 1.35 - 1.8 - - ns VCC = 2.3 V to 2.7 V - 0.9 - 1.1 - - ns VCC = 3.0 V to 3.6 V - 0.8 - 0.8 - - ns VCC = 0.8 V - - - - - - ns VCC = 1.1 V to 1.3 V - 1.1 - 1.2 - - ns VCC = 1.4 V to 1.6 V - 2.0 - 0.8 - - ns VCC = 1.65 V to 1.95 V - 0.5 - 0.7 - - ns VCC = 2.3 V to 2.7 V - 0.9 - 0.4 - - ns VCC = 3.0 V to 3.6 V - 1.0 - 0.2 - - ns MR; see Figure 8 D to CP; see Figure 7 VCC = 0.8 V - - - - - - ns VCC = 1.1 V to 1.3 V - 0.5 - 1.2 - - ns VCC = 1.4 V to 1.6 V - 0.4 - 0.8 - - ns VCC = 1.65 V to 1.95 V - 0.3 - 0.6 - - ns VCC = 2.3 V to 2.7 V - 0.3 - 0.5 - - ns VCC = 3.0 V to 3.6 V - 0.2 - 0.5 - - ns VCC = 0.8 V - - - - - - ns VCC = 1.1 V to 1.3 V - 0.8 - 1.7 - - ns VCC = 1.4 V to 1.6 V - 0.6 - 1.1 - - ns VCC = 1.65 V to 1.95 V - 0.4 - 0.9 - - ns VCC = 2.3 V to 2.7 V - 0.4 - 0.9 - - ns VCC = 3.0 V to 3.6 V - 0.5 - 0.9 - - ns D to CP; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 11 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter th hold time 25 C Conditions power dissipation capacitance Max Min Max (85 C) Max (125 C) VCC = 0.8 V - - - - - - ns VCC = 1.1 V to 1.3 V - 0.7 - 0.2 - - ns VCC = 1.4 V to 1.6 V - 0.5 - 0 - - ns VCC = 1.65 V to 1.95 V - 0.5 - 0 - - ns VCC = 2.3 V to 2.7 V - 0.3 - 0 - - ns - 0.4 - 0 - - ns VCC = 0.8 V - 1.6 - - - - pF VCC = 1.1 V to 1.3 V - 1.7 - - - - pF VCC = 1.4 V to 1.6 V - 1.8 - - - - pF D to CP; see Figure 7 [3] fi = 1 MHz; VI = GND to VCC VCC = 1.65 V to 1.95 V - 1.9 - - - - pF VCC = 2.3 V to 2.7 V - 2.2 - - - - pF VCC = 3.0 V to 3.6 V - 2.7 - - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] Unit Min VCC = 3.0 V to 3.6 V CPD 40 C to +125 C Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 12 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 12. Waveforms VI VM D input GND th th tsu tsu 1/fmax VI CP input VM GND tW tPHL tPLH VOH VM Q output VOL 001aaa465 Measurement points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage drop that occur with the output load. Fig 7. The clock input (CP) to output (Q) propagation delays, the clock pulse width, the D to CP set-up, the CP to D hold times and the maximum input clock frequency VI VM MR input GND tW t rec VI CP input VM GND t PHL VOH VM Q output VOL 001aaa464 Measurement points are given in Table 9. VOL and VOH are typical output voltage drop that occur with the output load. Fig 8. Table 9. The master reset (MR) input to output (Q) propagation delays, the master reset pulse width and the MR to CP recovery time Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5  VCC 0.5  VCC VCC  3.0 ns 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 13 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger VCC VEXT 5 kΩ G VI VO DUT RT CL RL 001aac521 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Table 10. Test circuit for measuring switching times Test data Supply voltage Load VEXT VCC CL 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M [1] RL [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2  VCC For measuring enable and disable times RL = 5 k, for measuring propagation delays, setup and hold times and pulse width RL = 1 M. 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 14 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 10. Package outline SOT363 (SC-88) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 15 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig 11. Package outline SOT886 (XSON6) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 16 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig 12. Package outline SOT891 (XSON6) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 17 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig 13. Package outline SOT1115 (XSON6) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 18 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig 14. Package outline SOT1202 (XSON6) 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 19 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 14. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1G175 v.5 20120703 Product data sheet - 74AUP1G175 v.4 Modifications: 74AUP1G175 v.4 Modifications: • Package outline drawing of SOT886 (Figure 11) modified. 20111124 • Product data sheet - 74AUP1G175 v.3 Product data sheet - 74AUP1G175 v.2 Legal pages updated. 74AUP1G175 v.3 20100930 74AUP1G175 v.2 20080228 Product data sheet - 74AUP1G175 v.1 74AUP1G175 v.1 20061115 Product data sheet - - 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 20 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AUP1G175 Product data sheet Downloaded from Arrow.com. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 21 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AUP1G175 Product data sheet Downloaded from Arrow.com. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 July 2012 © Nexperia B.V. 2017. All rights reserved 22 of 23 74AUP1G175 Nexperia Low-power D-type flip-flop with reset; positive-edge trigger 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 20 Legal information. . . . . . . . . . . . . . . . . . . . . . . 21 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 21 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Contact information. . . . . . . . . . . . . . . . . . . . . 22 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 July 2012 Downloaded from Arrow.com.
74AUP1G175GW,125 价格&库存
很抱歉,暂时无法提供与“74AUP1G175GW,125”相匹配的价格&库存,您可以联系我们找货
